Old Jan 03, 2013, 10:51 PM
Watty is online now
Find More Posts by Watty
Watty's Avatar
Somers, CT USA
Joined May 2004
Do it Yourself Thin Depron Sheet - A Durobatics Substitute
I have developed a method to machine 1mm (0.039-in) Depron foam sheet to remove one side and reduce thickness to about 0.025-in. Most of the weight of 1mm Depron is in the skins, so the weight reduction is significant. Plus, the thinned Depron will bend to a tight radius as one skin has been removed. The resulting material is very similar to Durobatics, which is no longer available.
In a nutshell, I machine the Depron with a Great Planes Power Plane. This is a rotary plane with a cutter that looks like the cutter in a pencil sharpener. Unfortunately, this useful tool has been discontinued, and I haven't been able to find an equivalent. But, there should be a lot of them out there, or maybe you have one.
A more detailed discription of this method is in my blog.
Watty
Watty is online now Find More Posts by Watty
Old Jan 04, 2013, 01:18 AM
Heliman420 is offline
Find More Posts by Heliman420
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
Interesting technique, i can imagine it would be easier to roll fuselages and make curves, than it would be with a sliced equivalent, since slicing leaves a melted skin.. making it quite a bit stiffer, ive sanded pieces of depron before, but could never get uniform thickness over a large area.
Heliman420 is offline Find More Posts by Heliman420
Old Jan 04, 2013, 06:57 AM
rogenstein1983 is offline
Find More Posts by rogenstein1983
rogenstein1983's Avatar
Joined Feb 2012
plantraco have sone durobatics for sale!
I got some durobatics from plantraco a few weeks ago I think thay must have a stockpile or a new maker of it great stuff
rogenstein1983 is offline Find More Posts by rogenstein1983
Old Jan 04, 2013, 07:37 AM
JRuggiero is online now
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Plantraco's Durobatics is the uncoated kind that can't be run through a printer. They are out of stock on the coated stuff.
Jim R.
JRuggiero is online now Find More Posts by JRuggiero
Old Jan 04, 2013, 01:43 PM
Joe Malinchak is offline
Find More Posts by Joe Malinchak
Carbondale PA
Joined Aug 2005
John,
It looks like a good technique for thinning down foam. I would like to try it out. However, I cannot find the Great Planes Power Plane for sale. If anyone has one that they want to sell, I would be interested.
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
Old Jan 04, 2013, 03:46 PM
Petem is offline
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Australia, VIC, Werribee
Joined Jul 2008
Alternative tools?
Would a conventional woodworking power plane, set to a very fine cut, do the job?
Petem is offline Find More Posts by Petem
Old Jan 04, 2013, 07:30 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
harbor freight has a small planer that looks like it might work... only $31
derk is offline Find More Posts by derk
Old Jan 04, 2013, 08:32 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Another way to obtain "Durobatics" equivalent sheets is to wire cut Depron into thinner sheets, resulting in sheets with a skin on just one side. Do some searching in this forum for techniques on how to do it. For example, EPilot (of the former Indoor Flyer) made IFoam this way, which had virtually identical properties to Durobatics. I have not explored any of these techniques personally because I have not exhausted my stash of Durobatics yet.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jan 04, 2013, 11:45 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
the key to getting good cuts seems to be taut wire when hot, and feed speed constacy.
nemoskull is offline Find More Posts by nemoskull
Old Jan 05, 2013, 12:15 AM
Robster is offline
Find More Posts by Robster
RIP Sheba :(
Robster's Avatar
Brentwood, CA
Joined Nov 2002
Slicing sub millimeter sheets with even planarity at .025" doesn't seem to me like an easy process. Bob definitely knew his stuff!
Robster is offline Find More Posts by Robster
Old Jan 05, 2013, 01:22 AM
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
Ive been slicing depron to 025 and thinner.. using my crappy version of the ss foam slicer, i use the foam in my molds, here is the original thread from a few years ago http://www.rcgroups.com/forums/showthread.php?t=1221543
What made Bob's foam unique is he made the stuff himself "apparently".
He was in the foam industry most of his life, and knew the formulations.
His slicing technique was perfect as well.
As i mentioned in my first post, i find the slightly burnt "stringy" skin that's left on the foam after hot wire slicing stiffens the piece, sanding and routing doesn't.
Therefore there is use for both techniques, it is easier to roll the sanded vs sliced. For when i needed slight compound curves in my Durobatics models i sanded the backside to get rid of the"slicing marks" it made it easier to work with without creasing.
Atleast that's what i found.
Old Jan 05, 2013, 08:23 AM
nemoskull's Avatar
Joined Sep 2009
when i need light foam, i get some 1mm and take some 150 grit to it.
Idea 2 sheets 2mm depron insomaniac45 Foamies (Scratchbuilt) 7 Dec 21, 2012 06:04 PM
Discussion Glues for laminating thin sheets of foam TedD60 Scratchbuilt Indoor and Micro Models 7 Oct 20, 2012 07:10 PM
Question Whistling woodies, sheeted vs turbulated vs thin vs thick wings??? Pauliwog Thermal 15 Aug 08, 2012 10:09 PM
I can do thin EPP sheets DrDHalko Foamies (Kits) 7 Jan 14, 2004 02:33 AM
