Old Jan 03, 2013, 08:50 PM
SOOFLY is offline
Find More Posts by SOOFLY
United States, SC, Greer
Joined Nov 2012
How To Make Molds - Composite Gliders
I've been reading up on building composite hotliner style gliders and found some great "how to" videos on youtube created by Jon Finch. However, I can't find a tutorial on how to make the Molds used in the fabrication proces (how to make a female mold from the plug specifically). I have I seen that some are made from aluminum, but others look to be made of a different material. Hoping that these can be made without the need of a CNC machine. Can anyone direct me to some links our give me an explanation? Update - the link that I've posted below is what I was looking for. Maybe after another year worth of reading I'll be able to take a stab at this.
Here is one of the links that I'm currently reading and process I am refering to.
http://www.rcgroups.com/forums/showthread.php?t=534484
SOOFLY is offline Find More Posts by SOOFLY
Old Jan 04, 2013, 02:30 PM
Chris Sutton is offline
Find More Posts by Chris Sutton
Spy's sappin' my thermal!
Chris Sutton's Avatar
United States, WA, Everett
Joined May 2009
Here is another thread with a great explanation of the whole process for a 1-piece DLG fuselage. http://www.rcgroups.com/forums/showthread.php?t=1514414
One of the DLG fliers near me (killercando on this forum) has started building fuselages using the method in that thread. They're coming out pretty nice in the looks department, and feel absolutely rock solid at around 48g.
Good luck with your building, and keep us posted!
Chris Sutton is offline Find More Posts by Chris Sutton
Old Jan 04, 2013, 02:57 PM
SOOFLY is offline
Joined Nov 2012
Thanks for the link I will definitely check it out
Old Jan 04, 2013, 04:07 PM
killercando is online now
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
Here is a couple of threads I am subscribed to that have excellent info on some of the tecniques for molding. I would carefully read all of these and the links they have in them. Also there are probably hundreds of other threads I haven't seen. Then spend a couple hundred hours out in the shop and you could build some sweet top shelf goodies. It is sooo fun but a bit expensive. But sooo fun. Check the jart build for awesome painted in the mold parts. Lee
http://www.rcgroups.com/forums/showthread.php?t=1513273
http://www.rcgroups.com/forums/showthread.php?t=1461579
http://www.rcgroups.com/forums/showthread.php?t=1056468
http://www.rcgroups.com/forums/showthread.php?t=1235624
http://www.rcgroups.com/forums/showthread.php?t=653549
http://www.rcgroups.com/forums/showthread.php?t=851791
http://www.rcgroups.com/forums/showthread.php?t=632908
http://www.rcgroups.com/forums/showthread.php?t=1609029
http://www.rcgroups.com/forums/showthread.php?t=1797942
PS My stuff has a ways to go before they are sweet top shelf goodies. They are still in the middle IMHO
killercando is online now Find More Posts by killercando
Old Jan 04, 2013, 05:04 PM
SOOFLY is offline
Joined Nov 2012
Killercando - I really appreciate you taking the time to post those! Looks like I've got some reading to do
Old Jan 05, 2013, 11:38 AM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
This one may be helpful:
http://www.rcgroups.com/forums/showthread.php?t=1008654
wyowindworks is offline Find More Posts by wyowindworks
Old Jan 05, 2013, 12:51 PM
KevinSharbonda is offline
Find More Posts by KevinSharbonda
Make Flying Fun
United States, CO, Castle Rock
Joined May 2003
KevinSharbonda is offline Find More Posts by KevinSharbonda
Old Jan 10, 2013, 11:51 PM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
You might want to check out The Dance begin's Tango. It's in the slope forum as I just made a current reply about it.
prodjx is offline Find More Posts by prodjx
Old Jan 12, 2013, 04:15 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Choices.
Soof,
You will be presented with many decisions and choices when you read the above links. Choices that apply to your own application. Starting consideration include:
How many models to want to build from the one design? Is it a prototype or proven design?
If it is a prototype and a kind of apprentices first project, consider plaster/hydrocal moulds for the fuselage at least. There are a number of threads here on these forum about plaster/hydrocal moulds. One or a small number of fuses can be successfully built with a plaster based mould. Not a bad way to get started.
Conversely, if it is a proven design and you feel very confident about getting it all right the first attempt, then a fibreglass mould might be justified. This can be epoxy or the cheaper vinylester. I'm building a vinylester mould currently here:
http://www.rcgroups.com/forums/showthread.php?t=1339865
All my plugs for this project are hand shaped and finished. The flying surfaces are hot wire cut foam core vac bagged and hand finished. An insane amount of work!
The top end proffessional builders use more exotic materials and methods.
CNC drawn and built plugs or moulds. Moulds built of Corian and such.
You will no doubt read much about that in due course.
Spend about 2 hours per day for a year (and continue to do so) reading on these forums. They are an incredible repositry of information sharing and expertise.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Jan 20, 2013, 03:31 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Soofly, If you are looking at moulding the wings, you really need to start from the start and learn how to make vacuum bagged wings first, which you will need to make the plugs. This is a whole art in itself, and cutting the cores is another thing to learn again. Making fuselage plugs is easier, and a god place to start as all the shaping can be done by hand and vacuum equipment is not required to make the plug or the finished part.
Not trying to put you off, but its a huge amount of work. I would budget for about at least a year or two to go from the beginning to making moulded gliders. Its very rewarding though and well worth it. Start by learning how to make vacuum bagged wings and fly them for a while. They go great and will allow you to work out what you want for your mouldy project. At least there is a mountain of info out there, its definitely not a 'black art' any more!
Good luck
Josh
josh18 is offline Find More Posts by josh18
Old May 26, 2015, 07:50 AM
Sturme1984 is offline
Find More Posts by Sturme1984
Sturme1984's Avatar
Netherlands
Joined Aug 2013
Thanks guys!! Building a huge BAE Hawk mkII of 1500 mm long
Sturme1984 is offline Find More Posts by Sturme1984
Old May 30, 2015, 02:19 AM
Artful Owl is offline
Find More Posts by Artful Owl
Artful Owl's Avatar
New Zealand, Canterbury, Christchurch
Joined Dec 2011
Is anyone using a 3d printer to make molds?
Artful Owl is offline Find More Posts by Artful Owl
Old Jun 02, 2015, 01:42 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Some posts on here of using one to make plugs. I wouldn't use a standard 3D printer to make molds.
I'd also be leary of 3D printer accuracy, thermal stability and general warping over time.
samc99us is offline Find More Posts by samc99us
Help! Looking for Taboo-style or SuperGee-style pod or mold Wazmo Hand Launch 6 Oct 17, 2012 09:07 AM
Discussion How to make your own molds for making plastic cowls, using Plaster of Paris marc780 Electric Plane Talk 5 Oct 19, 2008 07:00 AM
Discussion THAT isn't how you make a composite plane, THIS is how you make a composite plane! theKM Composites Fabrication 4 May 21, 2008 10:23 PM
Alert Hey, why aren't there any molded-plane style EPP planes yet?! e-sailpilot86 Slope 29 Oct 12, 2002 12:18 AM
