Old Jan 03, 2013, 04:31 PM
Australia, NSW, Sydney
Joined Jul 2002
Where to buy this type of retract gear
Hi
Am building a motoglider and want to install a retract UC similar to this.I only need the nose wheel assembly.
I thought it was by Lindinger but I contacted them and it is not theirs.
Does anyone know what these are or where I could get them or similar ones. I require it take a wheel from 45mm min to max 70mm. The model will weigh 7lbs max.
clive_fox is offline Find More Posts by clive_fox
Old Jan 04, 2013, 07:49 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Do you mean you only need a single wheel retract ?, if so does this help -
HobbyKing - HobbyKing Retract system for Gliders (0 min 15 sec)
Or do you mean you just need the steerable nose gear ?. If so try the HobbyKing site, just type, retract, in the search box.
eflightray is offline Find More Posts by eflightray
Old Jan 04, 2013, 03:57 PM
Joined Jul 2002
Yes as I said I only require the nose gear assembly – not steerable. It is for a semi scale RF5B Sperber which is a monowheel motorglider. A similar video is where I saw it with the name Lindinger but it is not theirs.
The Hobbyking one is not suitable as it is plastic, has a weight limitation and does not extend down far enough for my model. All the similar glider ones also do not go down far enough either which is why I want to use a nose gear assembly which I can build in to emulate the scale position but not necessarily the action of the real one.
Old Jan 05, 2013, 12:46 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Often a nose wheel retract is just like the mains, but with steering. Can't you use a standard retract ?
There are also the electric retracts, (servoless), might be worth having a look though.
Any thing here -
http://www.nitroplanes.com/relage.html
http://www.horizonhobby.co.uk/aeroon...cts_25_46.html
http://www.stevewebb.co.uk/index.php...del+Aeroplanes
Old Jan 06, 2013, 01:23 AM
Joined Jul 2002
A standard retract with a straight leg has no offset. I want something like these as they have a trailing fork, angles down, that emulates the semi scale action that I am after. I know I can get 1/4 scale ones for the RF4 but these are too big for my model as it is approx 1:6.5 scale
Thanks anyway
Old Jan 06, 2013, 02:37 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
One last try
Try a Google Images search on - scale model landing gear
It pulls up a load of images of landing gear, you may spot something that's usable, the picture will links to a site that may be a supplier or name who's they are.
Old Jan 07, 2013, 01:58 AM
Joined Jul 2002
A bit more searching found these which is what I am after. They are by Dreamworks and it takes a 57mm wheel. Now to find an servoless retract to put it in
Question What Type Servo for Mechanical Gear Retracts? notime_3001 Radios 13 Nov 30, 2012 01:39 PM
Question Where to buy a tank and what type velyter RC Tanks 6 Nov 27, 2012 12:08 PM
Discussion 450 Pro (clone - belt drive) 26T front gear - where to buy? js32257 Mini Helis 6 Jun 10, 2012 11:45 AM
Question heli style gear? where to buy? STANG KILLA SS Multirotor Talk 7 Apr 05, 2012 01:58 PM
Where can I buy retracted gear for park jet flighttosky Electric Plane Talk 0 Oct 06, 2005 02:39 AM
