I have two of them in use right now. No problems at all, they just work. I plug it into a Aux channel and use a switch on the Aux channel to turn the power on or off as needed. The little LED indicator is a nice touch too.
Latest blog entry: My Low Wing plane
http://www.bphobbies.com/view.asp?id...7&pid=F2143792
I use this on small gas plane. You have the kill switch and can run the ignition off the flight battery to save weight. |
I have the Tech Aero iBec on two planes as well. Unfortunately the receivers I had from a popular brand radio control system didn't work with it. But my Futaba Faast receivers had no problem with it at all. So a user should thoroughly test the radio system with the gas engine running too.
You might check your trim setting or end point adjustments for that channel, it could be right on the hairy edge, so to speak. Instead of say 1ms to 2ms, it might be set for 1ms to 1.5ms and thus it is on the border where the switch thinks it is on or off or something.
I bought a brand new AR6210 spektrum receiver and the rcexl kill switch will not work on that one either I have contacted Horizon Hobby and their engineers are looking at the problem,,this kill switch works with every other spektrum receiver I have but it won't work with the AR6210.
I only have one gasser and yes, it works well on my DLE 20.
Latest blog entry: Is it possible to lose weight?
| Thread Tools | |
| Discussion Has anyone mounted an Apple touch to their DX8? | RC_AVIGATOR | Radios | 6 | Jul 06, 2012 08:32 PM |
| Sold 42% Products Opto Ignition Kill Switch and Ignition Regulator | boggintuff | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Apr 20, 2012 11:41 AM |
| Sold 42% Products Opto Gas Engine Kill Switch | Hammbone | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Apr 20, 2012 11:14 AM |
| Discussion Has anyone fitted a slider or rotary flap switch on 6dxi | Greek Steve | Radios | 3 | Apr 15, 2012 01:25 PM |
| For Sale 42% Opto Kill Switch and Ignition Regulator | boggintuff | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Apr 14, 2012 04:58 PM |
