Old Jan 03, 2013, 11:07 AM
Indgroove is offline
Find More Posts by Indgroove
Indgroove's Avatar
United States, TN, Knoxville
Joined Feb 2007
Satori question
Hello. I have question for Satori pilots. When in thermal mode, are the alierons even with the flap camber or does the alierons stay in the normal position (even with wing tip)? Thermal mode only.
Ind
Indgroove is offline Find More Posts by Indgroove
Old Jan 03, 2013, 01:24 PM
rcglider is offline
Find More Posts by rcglider
United States, NY, Hopewell Junction
Joined Sep 2004
Ailerons should follow the flaps in all flight modes except landing.
rcglider is offline Find More Posts by rcglider
Old Jan 03, 2013, 02:09 PM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
This is only true for straight non-turning flight. Inducing a turn changes things and the amount of flap-aileron mixing will vary with a number of factors, including personal taste. Rarely will a TD ship have flaps following ailerons at 100% in all flight modes in all flight regimes.
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Jan 03, 2013, 02:12 PM
ak79 is online now
Find More Posts by ak79
Flightcomp.com
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
Same camber across the whole wing. I flew Satori's for a long time. Great planes. They don't like big camber changes. My max thermal camber was only 2mm droop measured at flap root, anymore and it would get stall happy.
ak79 is online now Find More Posts by ak79
Site Sponsor
Old Jan 03, 2013, 04:14 PM
rcglider is offline
Joined Sep 2004
JT,
I meant that the ailerons should follow flaps in regard to camber across all flight modes except landing. If I was unclear, I apologize.
Old Jan 03, 2013, 04:39 PM
jtlsf5 is offline
jtlsf5's Avatar
Joined Jul 2007
JT,
No problem, just trying to make it real clear for the OP.
JT
Old Jan 04, 2013, 06:14 PM
Indgroove's Avatar
Joined Feb 2007
I maiden the Satori today. Wow!
After 5 handlaunches I went to the hi start. I was instructed on hi start launches
last week. There are not many glider pilots here in Knoxville, Tn. so I am own my own. So today I did my launches with no help and it wet well. It is hard to tell if I need to adjust my launch settings. With everything going on I am not sure about my launch trajectory. I didnt crash and no pop offs so maybe I am okay.
What do I need to look for on launch? Whats too flat? Whats too steep (on launches?)
With the Satori, do some of you guys launch in speed or cruise mode?
Ind
Old Jan 04, 2013, 07:32 PM
ak79 is online now
Flightcomp.com
ak79's Avatar
Joined Apr 2006
I never bungeed my Satori's with any camber, just normal section. If you are going up a winch then make a launch setting, dont worry about it for a bungee.
Site Sponsor
Old Jan 04, 2013, 07:36 PM
rcglider is offline
Joined Sep 2004
Because the typical hi-start launch is considerably less powerful than a winch launch, the launch settings are usually less aggressive. You will need to work up to your optimum launch to find out how much camber you can safely use. I would start with your normal mode and if that is too flat then adjust launch mode to copy your thermal camber. If you still need more, then try adjusting the amount of launch mode camber upward in 1 degree steps.
Note that the power producing elements here are first the strength of the hi-start itself and then then strength of your head wind. Put them together and you see that optimal settings would vary based on the wind strength. You can usually find a compromise setting as long as the wind doesn't vary by great amounts.
Old Jan 04, 2013, 07:44 PM
Indgroove's Avatar
Joined Feb 2007
When you say "normal mode" do you mean cruise mode when I have no camber?
Thank you for the help.
Old Jan 04, 2013, 10:03 PM
rcglider is offline
Joined Sep 2004
Yes, normal mode and cruise mode are usually the same. With the Satori, line up the flaps with the matching section on the fuselage. Then, line up the ailerons with the flaps and this is your "normal" mode.
Your reflex mode would be up 1.5 to 2 mm on the flaps and ailerons measured from "normal", while thermal camber mode would be down on the flaps and ailerons 1.5 to 2mm.
Old Jan 05, 2013, 02:32 PM
Indgroove's Avatar
Joined Feb 2007
Thanks again!!! I launched the Satori today at the recommended setting of cruise. Great launches!!! Much better!!!
An experence glider pilot showed up and showed me a few things and the launches improved. When he flew it, WOW. The Satori is a nice plane. It was trimmed properly, just need better launch techique and the right launch mode.
I am using a hosemaster 3 meter hi start. (50 feet of rubber and 250 ft. of string)
I walked 50 steps to launch. How many steps should I take with this hi start?
Ind
Old Jan 05, 2013, 03:44 PM
rcglider is offline
Joined Sep 2004
Glad to hear your launches went well. And good that someone came along to help get the launch tuned in. As far as hi-start stretch, most often the amount to stretch is 3 to 4 times the unstretched length of the rubber, so roughly 150-200 feet. If your step is 3 feet long, that would be 50 to 70 steps. Most people have a somewhat shorter stride so if your's is shorter also then just add a few more steps.
A lot of guys go with the pull of the rubber instead of how far to stretch. Usually use 4 to 5 times the weight of your airplane. The Satori is about 4 1/2 pounds so say 16 to 20 pounds of pull. If you have a digital fish scale, that is all you need. Measuring the pull helps to eliminate the variation caused by temperature changes.
One last thing, be careful with a hi-start in cold weather. If you stretch it when it is too cold out you can ruin the hi-start. And, as you know, a good Hosemaster setup is not cheap.
Old Jan 05, 2013, 08:55 PM
Indgroove's Avatar
Joined Feb 2007
Thank you to everyone that answered my questions. This forum is very valuable.
I apreciate all the help I received. Thanks again.
I will try to get comfortable with the hi start then go to the winch. Hopefully, by spring I will start hi start launches.
In the mean time, I'll keep practicing and hit the gym. After 7 or 8 launches my arm gets tired.
Ind
Old Jan 26, 2013, 07:12 PM
Indgroove's Avatar
Joined Feb 2007
I am comfortable with the high start. Getting good launches, finding good thermals.
Today I started to launch when a thermal pass through and the wind direction changed 90 degrees. I know that means a thermal has influenced the prevailing wind direction. My question is, if I were using a winch what is the proper launch technique when the head wind changes (say 90 degrees or more) from the prevailing wind? ( in other words, I cannot launch into the wind)
Off Site 70oz Satori SL *$1895.00* Alex1157 Aircraft - Sailplanes (FS/W) 0 Nov 28, 2012 03:46 PM
Sold Satori 68 Guy Flys Aircraft - Sailplanes (FS/W) 0 Oct 17, 2012 05:46 PM
For Sale Satori C68 much lowered price! ak79 Aircraft - Sailplanes (FS/W) 6 Aug 07, 2012 03:56 PM
For Sale Satori's F3J C68 and SL ak79 Aircraft - Sailplanes (FS/W) 1 Jul 23, 2012 03:44 PM
Sold " NEW SATORI super lite" repost with pics! Rich Burnoski Aircraft - Sailplanes (FS/W) 10 Mar 10, 2012 06:09 AM
