Old Jan 05, 2013, 09:29 AM
Canada, ON, Ottawa
Joined Dec 2011
That looks sweet.
preelude is offline Find More Posts by preelude
Old Jan 05, 2013, 11:11 AM
Allways the hard way!
georgy's Avatar
South Africa, GP, Johannesburg
Joined Jan 2012
Helluva nice sport jet... & a delta to boot!
It looks really "PLAN"-able... hint hint!
George
georgy is offline Find More Posts by georgy
Old Jan 05, 2013, 02:29 PM
United States, NJ, Frenchtown
Joined Mar 2003
I worried about the sanding ridges at each glue line. So I bought a blue foam Flotation Billet from a lumber yard. It was 12" X 24" X 96" to start with. I cheated as it was my first foam scratch build. Used the plans frames as the body stations.
The solid body was about 6 hours with 33 grit paper & then 100 grit for final.
I accidentally built 2 left wing panels first.
Hand forming of foam is easy if you have a good set of plans.
cyclops2 is offline Find More Posts by cyclops2
Old Jan 05, 2013, 09:43 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Really nice. I dont think i could carve or build that way, heck im trying my best Not to sand
Trick is using the right glue and sanding it at the right time,so it rolls off sorta. But the plugs have been coming off the bow really nice that helps a lot too.
This build has maybe 2 hr of sanding, tops, to get to glass work, and the way it laid up it wont be much other then another coat with micro balloons to hit mirror finish
of course another 2 hrs of sanding in between
Guess i cant get away from it.
D_FAST is offline Find More Posts by D_FAST
Old Jan 05, 2013, 09:48 PM
unclecrash's Avatar
white lake michigan
until you get out the magic wand and become a wizard sanding will allways be in a scratch builder's future
unclecrash is online now Find More Posts by unclecrash
Old Jan 06, 2013, 07:21 AM
Joined Mar 2003
D
You nailed the gluing problem !!
I used epoxy on the China Clipper below. Hull is a bunch of H D 2" thick pieces lengthwise.
What a 6 hour cutting BELOW the surface of every seam line !!!! Then fill it in & final sand. I used my electronic 3" wire side cutter to do the job. I took Ibuprofin after finishing.
After that mistake. I went back to the big blue Styrofoam billets.
Thinking of doing a foam hydroplane.
Old Jan 08, 2013, 09:02 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
some of the boring stuff
should have all the filler primer on this evening.
then there is more sanding in the scehdule
Built lite. Only 1 layer 3/4oz cloth used
Good news is we are gonna meet the goal of 1.5lb empty air frame
Calulating around 3.75lb - AUW
@ 2200w for a screaming 600w per lb!
Old Jan 08, 2013, 09:16 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
cg look ok?
Old Jan 08, 2013, 06:05 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
should be a good starting point. might be a tad nose heavy, but that's ok too.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 08, 2013, 06:30 PM
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
The Tiger shark looks awesome.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Jan 10, 2013, 10:52 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Almost there
Finished up the layup and epoxy.
A rudder was added as an after thought,
pocket was made so the servo is not in the exist tunnel
while slits for the control horn protrude the fiberglass
Everything sprayed with a fill primer.
still need to clean up the hatch areas from the build up of epoxy, couldnt resist placing the unit in there for a few shots
Old Jan 10, 2013, 11:49 PM
RC ADDICT
gonracn's Avatar
Minneapolis, MN
Joined Sep 2005
Wow...
gonracn is offline Find More Posts by gonracn
Old Jan 11, 2013, 12:03 AM
Joined Jan 2009
that looks awesome.
Old Jan 24, 2013, 10:43 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Some more finished.
We Can throw the 3.75lb AUW out the door
Added weight of
new esc, from *90amp to 120 amp
Larger wiring
Modification and installation of an old fly-fly twin seat F-100 sabre canopy
bigger,metal gear servos
larger connection rods,easy connectors, etc
larger Lipo
some paint
We now sit at just under 4lbs
Man does the weight creep up on you!
Did a poor mans thrust test, seeing 4lb 9oz with no thrust tube *See video I think its funny
Does that sound like a bearing?
Rating M for mature.
I didnt edit anything so there is a bit of cursing
90mm Smartfan thrust test (0 min 52 sec)
Old Jan 24, 2013, 06:57 PM
unclecrash's Avatar
white lake michigan
Sweet, I like the blue something different for a change
Build Log GAUI tiger Shark Delta w/MMX fan hole digger Foamy EDFs 494 Apr 15, 2012 09:20 AM
Sold Gaui Tiger Shark Delta (again) hole digger Aircraft - Electric - Jets (FS/W) 34 Nov 28, 2009 12:45 AM
Discussion Tiger-shark Delta simonwu Foamy EDFs 448 Nov 20, 2009 09:15 AM
Sold GAUI TIGER SHARK DELTA w/MMX fan hole digger Aircraft - Electric - Jets (FS/W) 112 Oct 09, 2009 07:56 PM
Discussion GAUI Tiger Shark Delta druegeme Foamy EDFs 3 Jun 21, 2009 09:36 PM
