Old Jan 03, 2013, 09:54 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Build Log
Large 90mm Tiger Shark Delta
The idea sprung up over the holiday's.
My brother had gotten one of the 90mm smart fans. He was thinking of selling it, but decided to see what we could get out of it on a light powered setup.
I cant remember exact numbers but i believe he was close to the 5 lb thrust on 6s. Think it was being spun on a 1600kv warhead??
The power system including lipo/esc/unit/etc... all weighs in at 2.5 lb.
So he asked me, think we can build a frame around 1.5 lb
We could try.
Build Progress is blazing fast on this one.
Idea sparked around X-mas 12/26/12
Cad completed just before the new year 12/30/12
Templates/foam cutting started on the New Year 1/1/13
And today we are ready for some glass work.
Air frame weight as of now. 11oz
D_FAST is offline Find More Posts by D_FAST
Old Jan 03, 2013, 10:18 AM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Sweet, looks fast just sitting there. I like the wing cut into sections. I did my Chimera like that. It makes a nice strong wing. I have a extra Change Sun 4 blade sitting here doing nothing, One of these days I will build something around it. Hey what are those black things, look like you are using them for hatch hold downs?
unclecrash is offline Find More Posts by unclecrash
Old Jan 03, 2013, 10:28 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
They came from a crashed dynam turbo jet, you can also find them on dynams a-10.
They used for securing the nacelles, works a champ here too.
Old Jan 03, 2013, 10:33 AM
unclecrash's Avatar
white lake michigan
So D ... Is that a plane you have in a smaller size, that you outlined in sketchup and you enlarged?
Old Jan 03, 2013, 10:41 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
No,
The smaller version in the background. is one that my Bro hand carved. Yes hand carved! no templates used what so ever.
He just looked at my old guai hanging on the wall, and sanded he arse off. that ship is about a yr old.
It had some issues of course, pile drove it into the ground a few times.
So ive started reconditioning it. And transplanting the power system i had in my 100+mph guai over to it.
I used the best picture i could find and re drew everything to get this 90mm version. Unfortunately the way i built the cad model, one can not scale it down or the wall thickness will turn into 1/32in thick.
I did my best to wrap the air frame around the unit as tight as i could to get the lightest possible airframe
Old Jan 03, 2013, 10:47 AM
unclecrash's Avatar
white lake michigan
Man your bro did a great job shaping it by hand. Are you guys planning on hand launch or small retracts? Should be in the air in a couple days at the speed your building
Old Jan 03, 2013, 10:53 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
We havant decided yet. weight will determine if she get retracts. if we do place e-tracts on it. they will be short stubbies like the ones found on viper jets.
Old Jan 03, 2013, 11:38 AM
unclecrash's Avatar
white lake michigan
I think cereal box would work good too. As long as the amps are low and it does not burn your good to go. I think the matting for picture's is even thicker than the poster board I was using.
Old Jan 03, 2013, 12:47 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Sweet, looks great.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 03, 2013, 01:35 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Looks great 'D!!! Hey that reminded me, I still have my old Gaui!!! Just need a HIGH C battery to run it.... Keep up the great work!! W
Waltjg is offline Find More Posts by Waltjg
Old Jan 03, 2013, 06:23 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
looks awesome. I love this method of making planes. so much faster and easier.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 03, 2013, 07:30 PM
Osprey Engineer is offline
Find More Posts by Osprey Engineer
Osprey Engineer's Avatar
Philadelphia, PA
Joined Oct 2005
How do you square up and cut your blank blocks out?
Some people like Claus square up all 6 sides to a block.
Are you using rubber cement to glue the sections?
I used this method with 2 inch thick blue foam and found that it is not the same thickness all the time. Typically thinner at the edges of a 4x8 ft sheet. Caused this problem (see pic) for me when i built the fuse in 2 halves.
I used cereal boxes which is similar to coke case or beer case boxes. Plenty thick for hot wire.
Nice work
Osprey Engineer is offline Find More Posts by Osprey Engineer
Old Jan 03, 2013, 08:27 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
no foam is created equal. unless you are
1: cuting from square blanks that yourself have cut. Hotwire planer and know is true
or
2: cutting both sides in one piece. then the thickness doesnt come into play that much. you just got to keep checking,
Old Jan 05, 2013, 08:32 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
Got a a few more hrs thrown at it last night
* Control surfaces cut
* balsa wood trim around appendages
* Appendages squared and mated to the fuselage
* Carbon Spar installed
* Filled
Now waiting for some glass and resin
Discussion Tiger-shark Delta simonwu Foamy EDFs 449 Aug 09, 2014 02:43 PM
Build Log GAUI tiger Shark Delta w/MMX fan hole digger Foamy EDFs 494 Apr 15, 2012 09:20 AM
Sold Gaui Tiger Shark Delta (again) hole digger Aircraft - Electric - Jets (FS/W) 34 Nov 28, 2009 12:45 AM
Sold GAUI TIGER SHARK DELTA w/MMX fan hole digger Aircraft - Electric - Jets (FS/W) 112 Oct 09, 2009 07:56 PM
Discussion GAUI Tiger Shark Delta druegeme Foamy EDFs 3 Jun 21, 2009 09:36 PM
