Australia, NSW, Leeton
Joined Jul 2011
Hi Stuntflyr, I agree with your comments, although in my case I longed to make these sorts of kits in the 70’s. I gather that these kits build into great flying aircraft with a little care, and with a bit more effort will look reasonably scale (if viewed from a distance)
![]() The tail will be airfoiled, I am thinking maybe a 1/8th core, ribs and 1/32 sheeting, should be OK strengthwise as I intend to glass the whole bird. Regarding the nose shape, if it saves someone making a mistake, it was worth commenting on, I was all ready to shave the battery box corners to make a snipey nose, but then looked at the photos and 4 views (thanks again Chad and TLH) and realised it would a: be wrong and b: make a mess of the structure. (Phew) ![]() ![]() It was a little milder today and I made some progress.
Joined Jul 2011
Fuselage tail closed
Got the ends of the fuselage together, checking with Mk I eyeball indicates she’s straight and true. Those blessed with Mk II and later may scoff, but the old Mk I is able to detect errors of a couple of thous when used carefully
G , great job the cowl looks great !!
I am not 100% sure but for some reason I thought Dave Platt was responsible for the Red Box designs .. For some reason on my first kit I remember his name being on the plans (again guessing but for some reason I remember that ) . I have to open the new one and see whose name is on the plans |
Latest blog entry: The Ultimate Hobby shop "Orange...
Joined Jul 2011
Hi Gree, enjoy the ride.
Thanks for the kind words LDM, I am pretty pleased with the result so far. Also you are spot on, design Dave Platt, kit engineered by Sid Axelrod. Tomorrow we are scheduled for a little relief from the heat wave, should be a mere 85 or so, (27 C), then 95 ish on Thursday, before getting back to some serious heat. I hope to get the main hatch and cockpit dashboard area made up while the respite lasts . Upper nose is rough carved, but needs to be blended into the hatch etc., will post pics tomorrow. |
Joined Jul 2011
Got quite a bit done today, sadly most of it was on other projects.
Formers for the upper cowling etc. have been cut, I am not satisfied with the shape of the middle one and will re do it this evening. The pilot is on a charge for being out of uniform... |
Joined Jul 2011
Retracts and fibreglassing materials have been ordered, work continues.
The main hatch looks kind of ugly at the moment, but is coming along nicely .I found a 1/72 kit of an “A”, although the manufacturer has used the wing sprue from a “D”. It will give some more information about fuselage shape etc., together with a couple of (I hope) genuine colour schemes. Looking at the plans , it seems as though the wing for my bird is closer to the “D” planform too, and the wing chord as a percentage of total length seems too small. I am intending to build as is for the moment, and make a more correct wing later, if the urge strikes me. Another detail problem is that both the belly and hatch area are currently too straight, easily fixed by adding 1/8” of light balsa, and feathering in all round. The miscreant in the cockpit turned out not to be the pilot, but a member of the ground crew, sitting there making engine and machine gun noises...
Joined Jul 2011
A little more progress...
The cowling and hatch are basically complete, with the extra layer for the belly is being moulded ready to be glued on. Total weight of the fuselage, hatch and cowling as it stands is 13 ounces. There is a lot of excess in the cowling. I am guessing to some extent, but hope to have the complete, fitted out fuselage come in at about 1.5 pounds, and a total flying weight of about 5.5-6 pounds.
![]() I have ordered a nice Tru-Turn spinner, opting for the basic international postage (us$12) rather than the international expedited (us$185). I would prefer to buy from a LHS, but the nearest supplier of any kind is 60km away, and the nearest suppliers with a good range are more than 400km away, so I order most stuff online. ![]() I have included a picture indicating the concept of how the main hatch will work. The CF rods will go through the rear 2 hatch formers and into the front cockpit former to locate the hatch. The catch will be mounted on the front 2 formers, and engage with the firewall. It will be operated by inserting a suitable probe through the carburettor air scoop, giving a clean surface. The second catch is simply to show the mechanism. I have also found a partial solution for the weather conditions, a misting fan. It sprays a mist of water into the draft from the fan, cooling it by about 5 degrees (or almost 10 degrees F).
great job, the lines look excellent !
Joined Jul 2011
A couple of hours with sanding block and paper
Thanks for the kind words, they really help to keep me going.
Also Hi to all those people who look at this log without commenting, feel free to join in. Any suggestions etc are always welcome. I tend to follow the techniques I learned scratch building model boats almost 40 years ago, all I claim is that my methods generally work. Made an early start this morning, the pictures mostly tell the story. General sequence – Preparation: ink in the exhaust stack locations (won’t sand off as easily as pencil) and apply masking tape to the limits of where sanding is to occur (the tape is quite resistant to sanding). Blend the sides of the cowling to the main fuselage, then blend the various thickness of the belly together. Shape the front, blending it to the nose block Shape the rear Refit cowl to fuselage, sit back and admire improved profile... note to self, chin is still too prominent. Next step is to do the same to the main hatch.
Joined Jul 2011
Enter the mummy...
The bird looks pretty ugly at the moment, all wrapped up like a mummy, but once the glue is dry and a bit of sanding done, the whole nose area will be pretty much done, or at least the correct shape.
I have also made a start on the cockpit area. I am likely to be away from home for a few days in the near future, so there may not be much action for a while...
Joined Jul 2011
Back on deck... for a day or so.
Okay, back at home, don’t talk to me about exes in general, driving 1708.6 km in under 24 hours
to pick up a friend whose flight times and destination had to be radically changed at short notice or the sorts of mongrels who think it is okay to hack credit cards to steal money , and will probably blame their victims for causing hardship to their family when they get caught and duly punished.Got some stuff ready to continue the project, retracts, filler, fibreglass resin and cloth. I will be spending some hours shaping the upper deck and hopefully will post an update this afternoon
| Thread Tools | |
| For Sale Top Flite Red Box P-51 kit | jjscott | Aircraft - Fuel - Airplanes (FS/W) | 3 | Oct 12, 2012 08:50 AM |
| Sold TF P-51B Yellow box kit | mewert | Aircraft - Fuel - Airplanes (FS/W) | 5 | Jun 04, 2012 09:25 PM |
| Wanted TF Red Box P-39 NIB | barkleyb | Aircraft - Fuel - Airplanes (FS/W) | 2 | Apr 07, 2011 05:09 PM |
| Wanted Need const. manual for TF Red Box P-51 | Johnny Angel | Aircraft - Fuel - Airplanes (FS/W) | 7 | Dec 12, 2010 05:08 PM |
| WTB/Trade TF,(Red Top), P-40 Kit | papaoften | Aircraft - Fuel - Airplanes (FS/W) | 0 | Mar 19, 2005 10:47 AM |
