United States, NC, Garner
Joined Nov 2012
winds 10plus so i flew kind easy,,lots of down drafts near ground,,plane can HANDLE wind,,,i can t
Props: Stock vs. APC 12x6
First, the wattmeter (static test): Stock 12x4 @ 1/2 throttle=10.98a @ 3/4 throttle=34.13a @ Full throttle=44.10a APC 12x6E @ 1/2 throttle=13.45a @ 3/4 throttle=42.15a @ Full throttle=50.16a Actual flying: The plane seemed a bit faster with similar performance in other respects. Will need more time to see the flight differences, but the run time is maybe a minute less to similar discharge and mixed flying. Not sure how much headroom the stock ESC has, but should be ok in the air. The APC prop requires reaming to fit the motor shaft. The stock spinner fits, but does contact the blades somewhat. |
Joined Nov 2012
Joined Nov 2012
,,winds UNPERDICTALE today,,bouncing around near the ground ,,was trying to land EASY but wind tried to stop that with gusty updafts,,,think i will put about 800 flights on vizionair brick,,then callHH to get refund,,tell them NOT HAPPY with groovless brick evil![]() ![]() ![]() Dale HA HA HA HHAA HA
You can buy an inexpensive 5mm shaft prop adapter which will accept the APC electric props "as is" - HH has em as do others your spinner will not fit this but they have a little bullet end -with a hole in them.
another propwhich you may like is the APC 13x4 electric - - if amps are too high for you, trim and balance the prop 1 little bit-I use this prop on my Fun Cub for VTO full flap takeoffs. ( EFlite 10 motor) |
Around here, a turkey roll is like a lobster roll only made with turkey- Not to be confused with a roll in the hay |
Joined Nov 2012
East Texas
Joined Nov 2008
I have my DX8 set up so that the Sport and 3D are on the gear switch and the High and low rates are on the Elevator switch. I have the DR/Expo that is on the Elev. switch exactly as the manual describes. I mainly fly 3D and just use Sport mode for take off when I feel like I need it. By doing this am I missing out on any of the capabilities that the Visionaire is capable of?
Joined Jan 2013
Guys be carefull with the APC 12x6......high chances you would damage the motor.....Specially when weather gets warmer. Not easy for ESC either. Check current before you make final choice and compare to stock prop to make a smart decision.. During all my developing test the provided prop design/size and motor Kv showed best match to the airplane performance/design.
The VA needs that up motor angle, please do not change that angle. The motor angle is very relative to CG. Check CG and do the inflight test we recommend in the manual and also I post here. The motor, wing and stab angles are all relative to CG. The plane it is set with those angles and CG to delivery most performance in the entire flight envelope/maneuvers. Thanks. Quique Somenzini Horizon Hobby |
| Thread Tools | |
| Discussion Parkzone's New Habu 2 EDF | ChuckTseeker | Foamy EDFs | 1949 | Yesterday 11:56 PM |
| For Sale New Parkzone S.E.5a w/ AR600 Rx - LPU | Kevinfred | Aircraft - Electric - Airplanes (FS/W) | 1 | Jul 12, 2012 12:26 AM |
| Sold New Parkzone S.E.5a w/ AR600 Rx - LPU | Kevinfred | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Jun 23, 2012 09:10 AM |
