Latest blog entry: Zach & Dan 3DHS 71" Slicks Duo...
When I was flying in my backyard yesterday, I only had about a 4 ft. x 8 ft. spot to land, so I kind of just hovered/harriered it in, then plopped it down. No damage any time, I just had to bend the gear back a little sometimes. Also, when hit LVC the one time, it kind of fell out of the sky and the wing it first and then the landing gear. Again, no damage! Just a little dirt on the SFG and I had to bend the landing gear back. There were a couple other times where it kinda plopped down, too.
Back from the field, and my Visionaire maiden.
Complete success! Recharging 6 used 2200mah batteries right now. Each one was flown on a mix of general and 3D, for 6 minutes each, and that left from 38% to 54% left in the pack. Did not do a lot of crazy stuff given conditions (time was smack in the middle of this chart ![]() ![]() I did do the first take off on grass, and it went like a piece of cake, flew out very stable and predictably, and just worked with no worries. I flipped it inverted, felt good, ran it across the field and realized that it was very slightly diving when upright, and very slightly climbing inverted. Rest of trim and the overall CG and balance felt great right out of the box. Landing was easy, except it took me a little jockeying the throttle for altitude control, and some time to learn how to set up a sink rate and not give so much elevator that I transition to high alpha in that stiff wind. Obviously lots of lift in that huge and lightly loaded main wing! Even at low speeds the plane has lots of control authority, and I never felt nervous or out of control. Once I adjusted the elevator with one and a half turns for the next flight (I used zero electronic trim tonight), it turned out to be the right direction and almost right amount -- now it was *very* slightly climbing in upright, and very slightly falling in inverted. One half turn back the other direction for batt #3, and that made flights #4, #5, #6 perfect -- no more trim or fiddling required at all. I was amazed not only at how easily I could detect that fine a change in trim, but also at how close the factory had gotten all the out-of-box adjustments! In those later batts, I spent a little time in 3D, at higher altitude, did some snap rolls, spins, pure aileron rolls, hovered as much as wind would allow (very little), hung upside down into the wind in one spot with engine just keeping up with wind....shot a lot of touch and goes, every one of them smoother than the one before... Eventually the light faded out and kept me from using my last 2200 batt. While I could not really practice 3D moves tonight given my skills and the howling wind, I could tell how stable it is, and how much throw those controls surfaces have in high rates and 3D -- snaps are deliciously violent, it can flip over it about it's own length into the wind, and in general, it's all just pretty cool! The build only took me a few minutes, and every thing fit perfectly, and the quality of parts and instructions was awesome. I did decide to use my own 'system' for Velcro -- I always place the rough part on the inside stuff like battery hold down tray or ESC mount area, radio mount, and then I put the fuzzy half on the battery or any other 'movable' pieces like ESC or receiver. So other than using my own 'system' instead of the provided stuff (which as I say, IMHO they have backwards) I just can't think of a single thing to gripe about or that I wish they'd improve. Even when I grabbed the charger expecting it to be yet another cheesy wall wart throw away with no use to me, I was surprised to see it is actually a decent balancing field charger, with cigar lighter-connector, and will do 2 or 3 cell batts, so actually, this went right into the truck and will probably get some use. Quality of foam, graphics, and mechanical pieces is excellent. I expected to need to balance the prop, but it seemed smooth enough to just let it go -- might do some dynamic balancing later to see if it can be even better, but not really needed. This one is a real winner. |
You guys should try a Thunder Power 2250 65c pack in this plane. They blow all of my other packs away in my PA Extra 260 - even my Hyp 2200 VX 35c packs. They're good for 600 cycles when properly cared for & they're designed for 12 charging. I've got almost 300 cycles on mine at 8.8c charge (highest my charger will go) & they still pull nearly the same RPM as they did just after break-in.
![]() Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
I have become a firm believer in the church of high C rating!
As I said, I did not wring it out tonight, but I can almost bet that there will be a big difference between the provided 25C batt and my GenSAce 60C-120C burst, taken from the EDFs. I'm sure the TP 65C would be a real kick in the butt! |
| Thread Tools | |
| Discussion Parkzone's New Habu 2 EDF | ChuckTseeker | Foamy EDFs | 1960 | May 19, 2013 10:19 PM |
| For Sale New Parkzone S.E.5a w/ AR600 Rx - LPU | Kevinfred | Aircraft - Electric - Airplanes (FS/W) | 1 | Jul 12, 2012 12:26 AM |
| Sold New Parkzone S.E.5a w/ AR600 Rx - LPU | Kevinfred | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Jun 23, 2012 09:10 AM |
