Old Feb 11, 2013, 03:29 PM
Airdog67's Avatar
Joined Mar 2011
Is the recommended 2200 mah batteries working good for you guys
Airdog67 is offline Find More Posts by Airdog67
Old Feb 11, 2013, 03:31 PM
Flyin' low
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
I get 4 minutes on mine but it's cold here right now and I don't know how good my batteries are.
zmonster97 is offline Find More Posts by zmonster97
Old Feb 11, 2013, 03:41 PM
United States, NC, Garner
Joined Nov 2012
[quote=rlongenecker;24104676]general mode, sport mode, 3d mode? My dx8 is set up with two positions on the gear switch and seems to fly great in either mode. What am i missing?[/quot NOTHING
dalecheek1 is online now Find More Posts by dalecheek1
Old Feb 11, 2013, 03:43 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by rlongenecker View Post
General Mode, Sport Mode, 3D Mode? My DX8 is set up with two positions on the gear switch and seems to fly great in either mode. What am I missing?
Nothing. Just fly it and be happy!
I will fly mine in 3D mode 100% of the time anyway.
turnerm is offline Find More Posts by turnerm
Old Feb 11, 2013, 03:54 PM
Joined Nov 2012
U beat me posting ( nothing) LOL i also fly only 3d,,MODE,,too much YAKITY YACK about non issues,,,,,lets go fly,,got 30min untill sunset WOOT WOOT D ale
Old Feb 11, 2013, 04:06 PM
United Kingdom, Taunton
Joined Dec 2012
I am a relative beginner and even I found general mode with 100% rates absolutely fine. My advice (not worth much, I admit) is to do what most posters above have said and just leave everything at 100% and use the mode switch as advised.
GoAround is online now Find More Posts by GoAround
Old Feb 11, 2013, 04:08 PM
USA, TX, Houston
Joined Jan 2010
Thanks, guys.
rlongenecker is offline Find More Posts by rlongenecker
Old Feb 11, 2013, 04:17 PM
Joined Dec 2012
I did 5 minutes till the timer plus about half a minute to get it landed and used only half a battery. This was on first two flights. I hope to get to the stage when 5 minutes uses 80%
Old Feb 11, 2013, 04:26 PM
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
For all the new chums to this great plane, if you can fly your PZ warbirds well i do not think you will have any problem with this plane on it's stated setup
Hey guys even "I" could fly it and yes i was as nervous as before it took off, but once those wheels left the ground i just new this plane was a beauty and nothing to worry about flying it in "Normal" mode. Second trip out and i was using full throws 3D and now turn to 3D 100% as soon as i'm in the air
I own a DX8 and set up the rudder for my 3 position switch DR/Expo here is my set up for anyone interested!
position 0) normal flight 70% 25% position 1) 85% 30% position 2) 100% 40% Ail and elev. On the Rudder i use same for position 0 but straight to 100% for the other 2 slots and half the Expo
Position 0) 3D flight 70% 30% position 1) 85% 35% position 2) 100% 40% again on Rudder i do as above
so that gives me 6 flight modes to choose from, i also assign all my DR/Expo controls to the Rudder Switch as i cannot flick all the switches individually yet and have the flight mode switch as the suggested Gear switch
also on "ALL!" my models i set the Throttle Curve too my Hold! switch and put all values to "0" on one side of the switch thus giving me a Throttle Cut so no accidents can happen when the system is armed, the motor won't work till i hit the switch as said i do this on all my planes as accidents do happen
hope this helps some of the newer people to this sort of plane out
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Feb 11, 2013, 04:34 PM
Mugen4Lfe's Avatar
Joined Sep 2011
There are two flight modes: 3D and Sport. These are chosen when selecting TX type (page 7 of the ar635 manual). However since the default (and the mode that most use) is "3D", that's the mode that's assumed most are using. Now the confusion is that WITHIN the 3D flight mode, there are also two "sub" flight modes: 3D and General Flight (pos 1 and pos 0). Sport mode has "sub" modes Gear up and Gear down (pos 0 and pos 1).
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Feb 11, 2013, 04:41 PM
Did you commit aviation today?
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
Originally Posted by bobly View Post
But sport mode and general mode are two different choices. As I read it, you can't have sport mode with 3d on the gear switch. Only general and 3d. Sport mode is only enabled through programming and has different gain rates. But they do not say anything about travel in sport mode. They say travel is fixed in general and 3d as far as receiver is concerned, but you can underide them with dual rates. According to the chart, the gain is quite a bit higher in sport mode compared to general and on some axis's even 3d.
That's correct. Sport mode is selected via stick programming. Putting the system in 'sport' eliminates the general/3D flight-mode switching that you get in '3D computer' or '3D non-computer' mode, and 'sport' also lets you use all 6 rx channels. You simply set up the gains that you want & that's it. With oversize control surfaces & wild throws, a given set of gains will only be sufficient across a narrow speed envelope. Hence, why you get general & 3D settings on the gear switch when in 3D mode. With normal control-surface sizes & more scale-like throws, one set of gains is usually sufficient across a much broader speed envelope. So, if you were flying a sport-plane, scale ship, warbird, or anything with flaps & retracts, you'd use the 'sport' mode. Regardless of what the actual throw is in 'sport' mode, you'd still establish control-throws by moving the pushrods to different holes on the control horns & servo arms to get the correct control-throws.
Joel
turboparker is online now Find More Posts by turboparker
Old Feb 11, 2013, 04:51 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Works great. Per my last video I can confidently say that you get a solid 7 minutes before hitting LVC.
So I'd set the timer for 5:30 minutes.
Old Feb 11, 2013, 04:59 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
How? I'm only getting like 4 minutes. Although, my batteries are kind of old and I'm hard on the throttle and it is cold out right now.
Old Feb 11, 2013, 05:11 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I was using a brand new stock battery.
Old Feb 11, 2013, 05:21 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
I'm using about 2 1/2 yr old turnigy nanotech batteries!
Discussion Parkzone's New Habu 2 EDF ChuckTseeker Foamy EDFs 1960 May 19, 2013 10:19 PM
For Sale New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Airplanes (FS/W) 1 Jul 12, 2012 12:26 AM
Sold New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Micro & Indoor Airplanes 1 Jun 23, 2012 09:10 AM
