Old Jan 03, 2013, 01:21 AM
ChuckTseeker is online now
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
New Product
Parkzone's VisionAire
this looks cool parkzones new VisionAire BNF
cheers chuck
http://www.parkzone.com/Products/Def...ProdID=PKZ6580
The ParkZone® VisionAire™ park flyer is specifically designed for sport pilots by 3D pioneer, Quique Somenzini. Its wings are constructed of hollow Z-foam™ material that has been reinforced with carbon fiber to create structures that are stiffer and lighter than solid foam. This rigid, lightweight airframe is paired with a powerful 10-size, 1250Kv brushless motor that delivers the vertical performance you need for an exhilarating 3D flying experience.
What makes the VisionAire such a great 3D plane for sport pilots is the advanced AS3X® (Artifical Stabilization – 3-aXis) System built into its AR635 receiver. The AS3X System works behind the scenes to counter the effects of wind and turbulence, using 3-axis sensing and flight control software tuned by Quique Somenzini. If you’ve never flown 3D before, this enhanced stability will give you the confidence you need to try high alpha maneuvers like harriers, hovers, torque rolls and more.
You can adjust the amount of stability the AS3X System provides or turn it off completely, but even 3D pros will find flying with it on feels completely natural. There is no delay in control response or limits on the control throws. You’ll simply feel like you’re flying an expertly tuned model that goes right where you point it.
Spektrum™ AR635 DSMX® receiver with AS3X® System, installed
Powerful 10-size BL outrunner, 1250Kv, installed
E-flite® 40A Pro Switch-Mode ESC with 5A BEC, installed
E-flite 13-gram digital micro servos, installed
Clear belly window for monitoring AS3X System status
Carbon-reinforced Z-Foam™ construction
Leading-edge vortex generators
Double-beveled hinges for large control surface throws
Durable wire landing gear and large wheels for flying off grass
Two piece wing for easy transportation and repair
Sharp, Mirco Pecorari signature trim scheme
Includes 3S 2200mAh 25C Li-Po battery
Includes 2- to 3-cell DC variable rate charger
Requires a full-range 4+ channel DSM2®/DSMX aircraft transmitter, sold separately
Wingspan: 45.0 in (1143mm)
Overall Length: 42.5 in (1088mm)
Wing Area: 539 sq. in. (34.8 sq. dm.)
Flying Weight: 43.7 oz (1240 g)
Motor Size: 10-size BL10 brushless outrunner, 1250Kv (installed)
Radio: AR635 6-channel DSMX AS3X sport receiver (installed)
Servos: (4) 13 g digital high-speed servos (installed)
Trim Scheme Colors: Blue, red
CG (center of gravity): 4.5 in (115mm) back from the leading edge of wing at wing root
Wing Loading: 11.7 oz/sq. ft. (35 g/sq. dm.)
Prop Size: 12 x 4
Spinner Size: 1.57 in (40mm)
Speed Control : 40-Amp Lite Pro Switch-Mode BEC Brushless (installed)
Recommended Battery: 11.1V 3S 2200mAh 25C Li-Po (included)
Control Throw (Ailerons): Low: 70% up/down, 15% expo; High: 100% up/down, 25% expo
Control Throw (Elevator): Low: 70% up/down, 15% expo; High: 100% up/down, 20% expo
Control Throw (Rudder): Low: 70% right/left, 10% expo; High: 100% right/left, 15% expo
Approx. Flying Duration: 6 minutes
Charger: 2-3 cell DC Li-Po balancing charger
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: Less than 1 Hour
Is Assembly Required: Yes
ChuckTseeker is online now Find More Posts by ChuckTseeker
Old Jan 03, 2013, 01:27 AM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
That looks cool,i remember discussing as3x with eflite reps at ihobby for larger aircraft a couple years back and it was a no go. Took a while and technically this is a parkzone plane but still cool to see it.
Get Real is offline Find More Posts by Get Real
Latest blog entry: Simplecopter T-Copter
Old Jan 03, 2013, 01:42 AM
Moonbeam is online now
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
My "source" at HH texted me last night to say one of the two new releases is a blast to fly and I'd like it. He said it "is NOT a warbird", so this is it obviously.
Moonbeam is online now Find More Posts by Moonbeam
Old Jan 03, 2013, 01:44 AM
Joined Dec 2007
yep warbird is here
http://www.rcgroups.com/forums/showthread.php?t=1800768
cheers chuck
Old Jan 03, 2013, 02:49 AM
Micro Budget is offline
Find More Posts by Micro Budget
Good Times!
Micro Budget's Avatar
Joined Feb 2011
I want video!
Micro Budget is offline Find More Posts by Micro Budget
Old Jan 03, 2013, 04:55 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
i want to see what this one will be like.
scrub monkey is offline Find More Posts by scrub monkey
Old Jan 03, 2013, 07:50 AM
tele1974 is online now
Find More Posts by tele1974
tele1974's Avatar
USA, OH, Olmsted Falls
Joined Feb 2007
Video! Video!
tele1974 is online now Find More Posts by tele1974
Old Jan 03, 2013, 07:59 AM
Ryan Smith is offline
Find More Posts by Ryan Smith
JR Americas
United States, NC, Greensboro
Joined Oct 2006
The VisionAire is an incredible flying airplane. Even the early samples without the AS3X receiver were stellar flying airplanes. I may be biased, but I think that this airplane (and the receiver that's in it) are game changers.
It's an exciting way to start off the new year!
Ryan Smith is offline Find More Posts by Ryan Smith
Site Sponsor
Old Jan 03, 2013, 08:11 AM
_Colton_ is offline
Find More Posts by _Colton_
Team Horizon Hobby
_Colton_'s Avatar
United States, AZ, Tucson
Joined Feb 2012
+1
This plane is a blast!
_Colton_ is offline Find More Posts by _Colton_
Site Sponsor
Old Jan 03, 2013, 08:29 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Interesting. They seem to have gone back to a thicker wing section more like the older 3Ders by the looks of it. I wonder if those little dimples just aft of the leading edge top and bottom serve a purpose or are just for looks.
Aviefly is offline Find More Posts by Aviefly
Old Jan 03, 2013, 08:43 AM
JR Americas
Joined Oct 2006
I presume you are talking about the vortex generators?
They keep the airflow attached over the top of the wing, stabilizing it in high-alpha flight. They make a huge difference.
Site Sponsor
Old Jan 03, 2013, 09:04 AM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
I thought that might be the case but thought they looked a little small for that.
Old Jan 03, 2013, 09:16 AM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
$300!!
kuczy is offline Find More Posts by kuczy
Old Jan 03, 2013, 09:24 AM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
Only just noticed that part that's £185 over here but you can bet it won't end up being that. I bet it's closer to 200quid, it's on the horizon hobby uk page but I can't find an rrp for it. If it's closer to the 185 mark I suppose it wouldn't be too bad as long as there aren't any problems with the rx/as3x like there was with some of the other offerings.
Old Jan 03, 2013, 09:33 AM
bladeguy5 is offline
Find More Posts by bladeguy5
bladeguy5's Avatar
United States, MD, Waldorf
Joined Jun 2012
HH when are these expected to hit hobby shop shelves?
bladeguy5 is offline Find More Posts by bladeguy5
Discussion Parkzone's New Habu 2 EDF ChuckTseeker Foamy EDFs 4969 Yesterday 12:52 PM
For Sale New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Airplanes (FS/W) 1 Jul 12, 2012 12:26 AM
Sold New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 23, 2012 09:10 AM
