This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Jan 03, 2013, 12:03 AM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Build Log
FMS V7.5 P-51 BBD: Dyno Tuning the Prop!
I'm going to show how I Dyno Tuned the FMS 14" 4-blade prop!
I must admit, out of the box, this prop needed very little attention.
Dyno Tuning the FMS V7'5 4 blade prop (8 min 23 sec)
My vid is pretty much self-explanatory, but I will go into detail on a couple of things:
In the process of doing the 1mm prop shim mod to increase the blade pitch, I noticed the supplied 3mm x 17mm screws were not fully penetrating the embedded nylon material of the lock nut.
To better explain (and a lot less typing on my part) I found a really good explanation of how a nylon lock nut is supposed to work: "Nylon locking nuts, also known as ny-locks, have a small ring of nylon on one end that forms slightly smaller hole than the threaded hole going through the nut. When the nut is screwed onto a bolt, the bolt has to force its way through the smaller opening, causing the nylon to stretch. This stretching creates a huge amount of friction between the nut and the bolt, allowing the nut to stay tight for long periods of time without coming loose. Nylon lock nuts are especially useful for applications that involve a lot of vibration that would cause regular nuts to come loose."
That said, I decided I was going to use (8) 3mm x 20mm hex screws to secure the blades to the backing plate. As you can see in the thumbnails below, the 20mm screws penetrate the nylon with room to spare.
Note* When doing the 1mm shim mod it will throw the alignment of the screws off center slightly, but as you tighten the screws they will line back up. It also takes those four tiny index dimples out of the equation, so care must be taken to insure the forward edge of the blade feet are flush and parallel with the stops.
Once I'm happy with the balance of the prop/spinner combo, I mount it on the G&C 4250 540kv motor and do a run-up test. "FMS V7.5 P-51 BBD: The 540 Power Plant!" before installing it in the BBD.
~~~~Thumbnails~~~~
Sandancer is offline Find More Posts by Sandancer
Old Jan 03, 2013, 04:48 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Very Nice Teaching Demo!! Thank You SandDancer
Weed89 is offline Find More Posts by Weed89
Old Jan 05, 2013, 08:47 PM
Jose5x5 is online now
Find More Posts by Jose5x5
The ground is my Enemy!!!
Jose5x5's Avatar
United States, CA, Crestline
Joined Aug 2008
Nice Demo
Jose5x5 is online now Find More Posts by Jose5x5
Old Jan 07, 2013, 04:50 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
You're welcome!
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Originally Posted by Jose5x5 View Post
Nice Demo
Again, you're welcome too!
Old Dec 13, 2014, 12:43 AM
xsample is offline
Find More Posts by xsample
Joined Mar 2012
Thx for the awesome demo, thinking about modding my prop in a similar fashion. Do you happen to know the final pitch of the prop after a 1mm shim?
xsample is offline Find More Posts by xsample
Old Feb 12, 2015, 06:35 AM
jermo is offline
Find More Posts by jermo
Pantera .61 - Yeah Baby!
jermo's Avatar
United States, SC, Fort Mill
Joined Nov 2006
ty sir
jermo is offline Find More Posts by jermo
New Product FMS 1400mm V7 P-51D Mustang & P-51B "Razor Back" Mustang brandonmoon Electric Warbirds 254 Mar 15, 2016 12:25 PM
Discussion Companies that sell FMS P-51 v7 in the U.S.? Gobstopper Electric Warbirds 17 Apr 24, 2013 05:06 PM
Discussion FMS p-51 1450mm V7 racersrx700 Electric Warbirds 1 Oct 03, 2012 06:31 PM
