Old Mar 04, 2013, 09:20 PM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Nice looking hull. I know how you feel about finishing up the fiber glassing, not my favorite thing to do.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Mar 05, 2013, 06:49 PM
Bob SF is offline
Find More Posts by Bob SF
Bob SF's Avatar
USA, CA, San Francisco
Joined Aug 2003
Deck Beams Installed
Hi Ed & Louie, thank you for the nice comments.
Today, the deck beams went in, getting ready for the bracing for the bollards and support structure that will be the base for the cabin. The position for the bulkhead at frame 9.5 was moved forward to frame 9 to make room for a servo for the rudder (just too tight a fit). More sanding to do on the interior to clean up the frames before the deck goes on. I'm going to use 1/16" plywood as the sub-deck and plank over the top of that with 3/16" pine (should be tough enough). I positioned a sheet of 1/16" plywood over the deck beams and the plywood took the curve nicely. The deck will be sheathed in two pieces (split down the middle). It will be fun to see the deck go on and fill up that big hole on top. Bob SF
Bob SF is offline Find More Posts by Bob SF
Old Mar 05, 2013, 09:45 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Great progress Bob ~
Summer coming FAST !
Tim B. is offline Find More Posts by Tim B.
Old Mar 06, 2013, 12:17 AM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Hi Tim, with the sound of rain and wind beating against the house....I'll have to take your word for it. Bob SF
Old Mar 06, 2013, 09:18 AM
oldtribefan is offline
Find More Posts by oldtribefan
oldtribefan
oldtribefan's Avatar
United States, GA, Kennesaw
Joined May 2007
Your hull is looking fantastic, Bob!
oldtribefan is offline Find More Posts by oldtribefan
Old Mar 06, 2013, 12:42 PM
Band1 is offline
Find More Posts by Band1
Band1's Avatar
United States, NY, Queens County
Joined Oct 2011
Nice looking hull.
Band1 is offline Find More Posts by Band1
Old Mar 06, 2013, 04:30 PM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Bollard Supports Installed
Hi Everyone,
Thank you for the nice comments. Boat C's hull is ready for the 1/16" plywood sub-deck to come next. All of the bollard supports (3/4" plywood) were cut and glued in today. It is really embarrassing to have your bollards pull out of the deck, so 3/4" ply might be overkill, but at least they won't pull out. The frame for the stern of the boat was also cut and installed. I'm looking forward to planking the deck....another milestone. Tomorrow, Boat B will have a "plank-a-thon" with two of us working to get the second boat covered in balsa planks. Bob SF
Old Mar 06, 2013, 05:42 PM
the goon is online now
Find More Posts by the goon
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Lookin' good .
Mark
the goon is online now Find More Posts by the goon
Old Mar 07, 2013, 08:01 PM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Results of the Plank-A-Thon, Boat B
Hi Everyone,
Here is a shot of Boat B, during the Plank-A-Thon. Two of us sat down and tag teamed the planks and we installed about 14-16 planks in just a couple of hours. It is really cool to see the hull shape forming before your eyes. With each plank, the tugboat is revealed. Bob SF
Old Mar 11, 2013, 11:26 AM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Rudder Goes On
Hi Everyone,
The rudder, skeg, rudder tube, and control arm were installed on Boat C. I'm not used to building big boats and it felt pretty strange to use 3/16" piano wire for the rudder shaft.....but 1/8" didn't look big enough (what I normally use for rudder shafts). The rudder shaft has a key way ground into it so that solder will fill the void and lock it to the brass tube, which in turn is soldered to a brass blade that makes up the core of the rudder. Plywood is laminated to the brass blade to bring the width of the rudder up to the cross section that I'm looking for. The rudder is then skinned with more plywood. The rudder is sanded to shape at this point. The brass bands are glued in place and then drilled and pinned with brass nails, which in turn are soldered into place (at the bands). The rudder is then sanded, and then coated with West System Epoxy. The skeg was made out of two laminations of brass stock (my hardware store has had difficulty getting material from K&S and pickings among the brass bin is pretty scarce). The sub deck is cut today. I think I'm a couple of days away from planking the deck. Bob SF
Old Mar 11, 2013, 11:32 AM
Rmay is offline
Find More Posts by Rmay
Rmay's Avatar
Louisiana
Joined Sep 2006
Bob SF your build is looking great! Just finished the rudder on my little project as well.
Am enjoying the build!
Rmay is offline Find More Posts by Rmay
Old Mar 11, 2013, 12:15 PM
Melih PEKOL is offline
Find More Posts by Melih PEKOL
Istanbul / TURKEY
Joined Feb 2005
amazing
mp
Melih PEKOL is offline Find More Posts by Melih PEKOL
Old Mar 12, 2013, 06:46 PM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Rudder Servo Installed
Hi Everyone,
Skinned the transom today in 1/16" plywood and installed the rudder servo and the linkage. The sub-deck has been rough cut (not glued) and I ran out of 30 minute epoxy, so I'll be waiting for the brown truck to arrive. Bob SF
Old Mar 13, 2013, 07:43 AM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Man your really movin now, in the water in No time ~
This one's big enough to add cladding to the sides in case of go-fasty attack !
Old Mar 13, 2013, 11:18 AM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
No go fasty attacks please......enough fun with planking already! The red buoys at the lake have stopped that completely....much safer now. Bob SF
Discussion 1866 Steam Screw Tug Weymouth Bob SF Scale Boats 46 Feb 13, 2015 06:40 PM
For Sale Rc savannah harbor tug boat tugboat ship kit wjdid Boats (FS/W) 5 Apr 09, 2012 10:18 PM
Discussion US tugboats old english Scale Boats 2 Mar 12, 2012 06:04 PM
For Sale New rc radio control savannah harbor tug boat tugboat ship wjdid Boats (FS/W) 5 Mar 08, 2012 09:16 PM
Discussion Did you get a Flycamone2 from Weymouth today? mr_editor Slope 2 Aug 07, 2008 01:34 AM
