Old Feb 15, 2013, 01:11 PM
tghsmith is online now
Find More Posts by tghsmith
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
nice predrilled wire runs!!!
tghsmith is online now Find More Posts by tghsmith
Old Feb 15, 2013, 09:22 PM
Bob SF is offline
Find More Posts by Bob SF
Bob SF's Avatar
USA, CA, San Francisco
Joined Aug 2003
Hi Guys, thanks for the feedback. I'm on the lookout for a cardboard tube to make the stack out of. Once glassed, the cardboard should make a light smoke stack and will help keep the CG of the boat low. But for now, I'll be sanding and filling. Bob SF
Bob SF is offline Find More Posts by Bob SF
Old Feb 16, 2013, 06:57 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Bob, you could always just make up a tube with card stock, glass it and rip out the support structure once the glass kicks off.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Feb 16, 2013, 07:50 PM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Hi Jerome, that's a great idea. I'll do up a sample and see how it goes. Thanks for the tip.
Bob SF
Old Feb 18, 2013, 05:00 PM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Weymouth in Epoxy
Hi Everyone,
Two rounds of filling and sanding were all that it took to get the hundreds of pin holes filled. It was time to put some epoxy on the hull and she took a little less than a pint inside and probably a half pint outside to fill up the balsa. Once this first coat cures, she'll be sanded a little and then given a coat of fiberglass and epoxy. I'm hoping that one layer will suffice. Bob SF
Old Feb 18, 2013, 05:15 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Gonna be BIG !!!
Tim B. is offline Find More Posts by Tim B.
Old Feb 19, 2013, 09:21 AM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Hi Tim,
I agree with you. I think she will carry a lot of lead and electronics to get her down to her waterline. Bob SF
Old Feb 26, 2013, 05:10 PM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Boat C in Fiberglass, Boat B gets Planked
Hi Everyone,
Boat C has been glassed, sanded, and had another coat of resin applied. She will get another sanding and another coat of resin to smooth out her hull. I think one layer of fiberglass will be enough as she is pretty tough now. Her interior has one layer of resin, but will probably get two more to make sure that the balsa is sealed from any water that might get into her hull. My friend came over today and we started planking his boat (Boat B). Our next job on his boat is to build and install the motor mount. Once that is in place, we can finish getting all of the planking done. I'll be glad when all the resin work is done....Bob SF
Old Feb 26, 2013, 06:36 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Very cool to have two of these in the works at the same time !
You guys may be having Too much fun ....
Old Feb 26, 2013, 06:45 PM
woodybob is online now
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Body Tubes - Couplers - Launch Lugs might be just the ticketů
woodybob is online now Find More Posts by woodybob
Old Feb 26, 2013, 08:01 PM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Hi WoodyBob,
The rocket tube that I was originally looking for was "Out of Stock" at the above link.
Found another model rocket supply store that had the part and ordered it T-80H Tube (2.6" x 30"). This should be enough material for two tugs.
http://www.asp-rocketry.com
Using the rocket body tube is a great idea....thank you!!!!!!! Bob SF
Last edited by Bob SF; Mar 17, 2013 at 04:20 PM. Reason: Updating availability of part and diameter of part
Old Feb 27, 2013, 09:06 AM
Rmay is offline
Find More Posts by Rmay
Rmay's Avatar
Louisiana
Joined Sep 2006
I may have to use the rocket tube idea on my TID as well!
Another option, although more complicated - would be something like George did http://www.modelboatmayhem.co.uk/for...5019#msg145019 on his TID.
Much, much easier to go with the cardboard tube I guess, judging from the build and past builds - the above is well within your skills!
Excellent work.
Rmay is offline Find More Posts by Rmay
Old Feb 27, 2013, 10:48 AM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Hi Rmay, those cardboard tubes are looking better all the time! Off to sand the interior and apply another coat of resin. Bob SF
Old Mar 04, 2013, 05:32 PM
Bob SF is offline
Bob SF's Avatar
Joined Aug 2003
Weymouth Resin and Glass Done
Hi Everyone,
I can't tell you how happy I am now that the resin and glass work is done on Boat C. She had an additional two coats of resin applied after the glass coat. Each coat was sanded to a point where I didn't dare sand anymore for fear of sanding through the glass....which I actually did on one side near the keel (easy fix). Inside the hull, she also received two coats of resin, with special attention being taken to seal up the bow at the gap between the stem and the planking. She also needed to have a real boat stand built, as she fell off the temporary boat stand, but luckily landed on the work bench with no damage. Boat B had her motor bearers installed and an aluminum motor mount was made to hold her big Pittman motor. Once her thrust bearing base is installed, she will be back to the building board to have the rest of her planking completed. Both boats are looking really good. Bob SF
Old Mar 04, 2013, 05:52 PM
louie R/C NUT is offline
Find More Posts by louie R/C NUT
no such thing as to many boats
louie R/C NUT's Avatar
United States, NY, New York
Joined May 2010
Coming out nice those hull look good
louie R/C NUT is offline Find More Posts by louie R/C NUT
Discussion 1866 Steam Screw Tug Weymouth Bob SF Scale Boats 46 Feb 13, 2015 06:40 PM
For Sale Rc savannah harbor tug boat tugboat ship kit wjdid Boats (FS/W) 5 Apr 09, 2012 10:18 PM
Discussion US tugboats old english Scale Boats 2 Mar 12, 2012 06:04 PM
For Sale New rc radio control savannah harbor tug boat tugboat ship wjdid Boats (FS/W) 5 Mar 08, 2012 09:16 PM
Discussion Did you get a Flycamone2 from Weymouth today? mr_editor Slope 2 Aug 07, 2008 01:34 AM
