Old Feb 09, 2013, 01:56 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
9" prop !! Wow ....
I used to fly the QB10 on a 7" when IC .... and the QB10H I built little while ago used a 7x5 on about 1400kv ... was more than enough ...
I reckon a 9" prop may give you torque problems .... I reckon max you should go is 8" and keep pitch down to ~4.5 to 5
My thoughts anyway ...
Nigel
solentlife is online now Find More Posts by solentlife
Old Feb 10, 2013, 08:28 AM
Harry Rule is offline
Find More Posts by Harry Rule
Joined Oct 2012
I agree with Nigel; smaller prop and lower pitch - will make the battery last longer too. Even if you do go bigger, it's a good idea to start smaller and build up after each test flight.
I used to always put the biggest prop I could on my electrics when I first started but after buying a 'Watts Up' meter and doing a few tests I found I was over-propping them needlessly. They all fly just as well with an inch less in diameter and less pitch, plus the aforementioned increase in duration.
If in doubt, buy a few props and experiment, all part of the fun isn't it!
Regards
Harry
Harry Rule is offline Find More Posts by Harry Rule
Old Feb 10, 2013, 09:26 PM
ripplewave is offline
Find More Posts by ripplewave
United States, TX, Kerrville
Joined Dec 2007
Even the 11" prop is not overpropping. In fact it is giving me just about my target power of 150 watts. The 9" props don't get over 100 watts.
ripplewave is offline Find More Posts by ripplewave
Old Feb 11, 2013, 03:22 AM
solentlife's Avatar
Joined Jan 2010
For me - I go for THRUST ... watts are fine IF you are getting pitch speed / thrust as well.
Put a flat plate wood on a motor and have it put out a million watts - you aint going anywhere with it !
Only value I see in figures above is the run-time with the 9" will be better than the 11"...
But on a QB10 - originally designed in LitePly and balsa flew on an IC 10 engine.... that's small and could never swing a 9" prop well and certainly not an 11". Even when I converted my QB10 to a 'ballistic display' machine without wheels, swept back wings and an IC 20 motor - she still ran only a 8x6 .. and then it was very torquey !
A large diameter prop will have a serious flywheel effect and create a torque moment ... My foam QB10H now as i say is on a 7x5 ... and that climbs like a bat outta hell !
Only trying to help ....
Nigel
Old Feb 13, 2013, 03:56 PM
Joined Dec 2007
Alrighty! She is all dressed up and ready for the prom!
AUW is 20.5 oz or 690 grams. She came in under the specified weight range on the plan. The CG is just at the spar.
As far as props go. I am going to build a thrust meter and do some more testing. I do know for certain that it will not fly with a 7" prop or I should say, not fly well.
The motor is as stated in the test results post an 880 KV motor. If the battery is fully charged and for simplicity sake I have 12 V this means without a prop the motor RPM will be 10,560. My TT .10 can do closer to 12,000. One of the advantages of outrunner electric motors is their ability to swing a larger prop because of their torque. I am thinking that I would not go any smaller than a 9" prop. Even with the 9" props, some of them will give me a decent flight time of close to 10 minutes (not full throttle.)
Anyway I will update when I get a chance to further test props and fly her.
Joe
Old Feb 15, 2013, 06:57 AM
solentlife's Avatar
Joined Jan 2010
Very nice too !
[As far as props go. I am going to build a thrust meter and do some more testing.
Far more use than watts per lb in my view ... Watts / lb as guideline ... thrust meter for actual. Then Pitch speed from RPM ...
No wonder you want 9" prop !! 880kv motor ? I'm running an 1800kv ... much more suited to such a model IMHO.
I know I differ from some - but my idea is that low KV motors are more for slow-flyer jobs and not aerobatic / sport machines. With the QB10 series I would consider motors in the 1400kv and up range to keep more in line with original 10 FSR IC specs ...
Nigel
Old Feb 15, 2013, 03:58 PM
Joined Oct 2012
Looks great, like the finish - simple but very attractive.
White planes always seem to look bigger in the air somehow - or at least I think so.
Look forward to the flight report!
Regards
Harry
Old Dec 06, 2013, 11:42 PM
orck is offline
Find More Posts by orck
Joined Aug 2004
I don't know if this is possible but I will ask anyway.
Is it possible to give in public the files that the laser cut machine used to create this?
I would like to try this on a shop near by.
orck is offline Find More Posts by orck
Wanted Pilot QB series Kits checkprop Aircraft - Fuel - Airplanes (FS/W) 1 Sep 10, 2012 10:00 AM
Sold Pilot QB 20HII $35.00 shipped Dizzante Aircraft - Fuel - Airplanes (FS/W) 11 Jul 15, 2012 11:08 AM
Sold Pilot QB 15H II vpresley Aircraft - Fuel - Airplanes (FS/W) 0 Mar 04, 2012 12:30 PM
For Sale Pilot QB 15H II vpresley Aircraft - Fuel - Airplanes (FS/W) 0 Mar 04, 2012 12:27 PM
Pilot QB slope 16 Karellen Slope 8 May 10, 2002 01:33 PM
