Old Jan 02, 2013, 12:42 PM
Nadav Sharabi is offline
Find More Posts by Nadav Sharabi
Joined Aug 2012
building question
recently i am thinking what is the best way to attach the reciver/battary/ESC to the fuselage.
and i will be glad if you guys share your attachment technic...
i use Velcro strap..and probably i can save some grams if you will give me good idea.
Nadav Sharabi is offline Find More Posts by Nadav Sharabi
Old Jan 02, 2013, 01:38 PM
rgj is offline
rgj
Find More Posts by rgj
rgj
Joined Dec 2010
hmm
rx and esc I use "doubelsided" tape same as to gyro's battery I make a smal hole in the fuse just big enought to slide the battery in and glue some extra depron on the side tha battery is resting on the horizontal part off fuse.
rgj is offline Find More Posts by rgj
Old Jan 08, 2013, 11:10 AM
Honza C is offline
Find More Posts by Honza C
Crashing? Hunting the mole!
Honza C's Avatar
Česká republika, Jihomoravský, Brno
Joined Jan 2011
I have recently used a 'sewing' technique: I have a thread (ordinary one, no Kevlar) and needle, run the thread from the opposite side of the fuse, than back (so that it makes a loop around RX, ESC, cables, or whatever you want) and I fix the 2 ends with a small drop of CA in each hole. Then I cut the rests of the thread with scissors or knife. Look at the pics of my new Indexes at http://www.rcgroups.com/forums/showt...623223&page=48. It would not work for battery, maybe if you replace the thread with a thin rubber ?
Honza C is offline Find More Posts by Honza C
Discussion cg help needed on kfm glider build? motor question added rcta15 Foamies (Scratchbuilt) 5 Mar 23, 2012 06:28 AM
Help! QUESTIONS: Extreme Duration/Distance via gas or elec?and building a flight station?? coyoteonethree UAV - Unmanned Aerial Vehicles 9 Mar 13, 2012 03:41 PM
Discussion New Poster with questions about a Fairchild 24 build athos56 Beginner Training Area (Aircraft-Electric) 3 Mar 09, 2012 07:09 AM
Discussion Building GP Reactor 3D, Power question. billmjam Electric Plane Talk 0 Feb 26, 2012 07:59 AM
Discussion Building my first tricopter! Questions faheja Multirotor Talk 1 Feb 23, 2012 09:51 PM
