Old Jan 02, 2013, 08:08 AM
Schoolya is offline
Find More Posts by Schoolya
Schoolya's Avatar
United States, FL, Mayo
Joined Jul 2012
Spars in a skinned foam core wing
I am about to get into foam core wings, building a vacuum system now (http://www.joewoodworker.com/veneering/EVS/concept.htm), and I am trying to get an idea of how i want to lay up my first wings. I see a lot of build photos and logs, but I am having a hard time deciding on what kind of layup and spars are best for what. My first wing will be for a %125 slipso (http://www.rcgroups.com/forums/showthread.php?t=418625) and my second I want to be a simple high aspect flying wing(a simple multibumm). Is there any information of spars and layup options?
Ryan
Schoolya is offline Find More Posts by Schoolya
Old Jan 03, 2013, 04:43 PM
Schoolya is offline
Schoolya's Avatar
Joined Jul 2012
should I try posting this in a different forum?
Old Jan 03, 2013, 05:19 PM
G Norsworthy is offline
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
I use this with very good results.
http://www.rcgroups.com/forums/showt...hlight=prop+er
G Norsworthy is offline Find More Posts by G Norsworthy
Old Jan 04, 2013, 03:52 PM
killercando is online now
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
Whoops meant to post on another thread.
Plan on bagging multiple parts before you get it worked out but generaly Lay the skin on bias and through some carbon unidirectional top and bottom for spar caps and the foam core will act as the shear web. Uh I think, Lee
killercando is online now Find More Posts by killercando
Old Jan 06, 2013, 12:29 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
http://www.rcgroups.com/forums/showt...1571140&page=3
This may be of interest.I'm about to start my first foam wing and I'll be using Verns method.
Stuart
Stuart A is offline Find More Posts by Stuart A
Discussion Making a foam cored wing using 2-part rigid polyurethane foam in the mould. AvB Composites Fabrication 272 Nov 10, 2014 11:58 PM
For Sale Rohacell structural foam! Wing skins, Tail cores FairlyFaded Aircraft - Sailplanes (FS/W) 7 Jun 25, 2014 10:43 AM
For Sale Rohacell foam 31 and 51! Wing skins! Tail cores! FairlyFaded Aircraft - Sailplanes (FS/W) 4 May 10, 2013 01:33 AM
Discussion Wings skins using foam core beds...? Upvector Composites Fabrication 10 Oct 19, 2009 01:29 AM
Question Adhesive for bonding balsa wing skins to foam cores Rogo Hand Launch 2 May 05, 2008 09:28 PM
