Old Jan 02, 2013, 06:55 AM
rkenosha is offline
Find More Posts by rkenosha
Joined Jan 2012
Help with led set up.
Hi everyone. I building a new quad. I have two 1 meter strips, each minus 3 leds that I cut off. I always use 4s batteries. Would like to know what type of resistor I need to wire in to drop the 4s to acceptable voltage for leds? Also, important part, how do I wire them in? Thanks rkenosha
rkenosha is offline Find More Posts by rkenosha
Old Jan 07, 2013, 09:05 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Hmmm A cheap LM7812 (<$1.00US) Voltage Regulator might work better. Drop the voltage down to the 12v the strips are already expecting. Slap a small heat sink on it and make sure it's near the prop wash.
-K
kad is offline Find More Posts by kad
Old Jan 08, 2013, 03:38 AM
electrotor is offline
Find More Posts by electrotor
Bonnie Scotland
Joined Jun 2004
Each 1 metre strip will draw less than 400mA so I suggest the easiest thing to do is buy a small 3 cell LiPo (500-1000mAH) and wire the LED strips directly to it. It's a ready made solution.
Wire both strips in parallel.
electrotor is offline Find More Posts by electrotor
Old Jan 10, 2013, 06:03 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Or buy a small switching buck regulator on ebay. These are adjustable in voltage and very cheap as well.
Connect this to the outer contacts of the balance plug for simplicity.
Julez is offline Find More Posts by Julez
Discussion Need help setting up ER9-X with Naza tgreening Multirotor Talk 34 May 15, 2012 10:58 AM
Discussion Need help setting up Tricopter with Spektrum DX7s with gyros Easyrider717 Multirotor Talk 35 Apr 19, 2012 11:50 AM
Discussion Need help setting up stryker with dx6i. John S. Beginner Training Area (Aircraft-Electric) 6 Mar 27, 2012 07:12 PM
Discussion Help with my first e power set up. Panther Power Systems 1 Mar 12, 2012 03:06 PM
Discussion Help with setting up D/R Expo in Acro Helijib Multirotor Talk 1 Feb 27, 2012 09:07 AM
