Old Jan 02, 2013, 06:07 PM
patmcc is offline
Find More Posts by patmcc
Northumberland, England
Joined Jan 2007
Raf_Bob, there's nothing driving the rotors that's fixed to the airframe, therefore there's no force for the rotors to react against.
Gordon, bearing drag would act in the same direction as rotation, therefore not a reaction.
I think the need for any corrective trim can only be due to rotating wash from the rotor.
patmcc is offline Find More Posts by patmcc
Old Jan 03, 2013, 02:11 AM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Excellent that an autogyro is being entered for the Build Off!! I have looked at the Ro-Dart several times, but I've never had the bottle to even decide to attempt it - and still haven't.
Re the torque reaction - what GeeW said re bearing drag makes a lot of sense. Now I may be exhibiting an astounding lack of knowledge here, but isn't the greater problem the asymmetric lift - ie the forward travelling half of the rotor disc is travelling through the air faster and at a greater AoA than the rearward moving half? Am I right in thinking that the swash plate mechanism on jellychoppers counteracts this by increasing the pitch on the rearward moving half of the rotor disc? But with contra rotors, that issue should be negated.
Another thing (admittedly based upon a single full size experience of flying a Rotax powered 3 axis microlight alongside a similarly Rotax powered gyrocopter) is that you may find that you will need more power to fly an autogyro than a similar size and weight aeroplane. I remember that at similar cruise speeds, climb rates etc the guy in the gyro was caning his engine whilst we were happy below the redline at all times (and using a lot less fuel)...!
Colonel Blink is online now Find More Posts by Colonel Blink
Old Jan 03, 2013, 03:13 AM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
Morning, Colonel. You're absolutely correct - this applies to all rotating wing aircraft, whether the rotor is powered or unpowered. As soon as the whole craft starts to move bodily through the air, i.e. when it has net airspeed rather than simply being in a hover, vertical climb or vertical descent, then it has an asymmetric effect because the forward-moving blade has higher airspeed, and generates more lift, than the rearward-moving blade.
Whereas the reactive torque of a helicopter, or the bearing drag of an autogyro, act in the yaw axis, the advancing / retreating blade effect acts in roll. Without some compensating mechanism the single-rotor autogyro will roll towards the retreating more and more strongly as the forward airspeed increases.
Yes, up to a point. This factor is usually what determines the never-exceed speed for a rotary wing craft - as the forward speed increases you eventually run out of ability to keep it flying straight.
Again, yes, up to a point. Obviously you solve the problem of asymmetry, and thereby you solve the roll control problem. But the retreating blade still remains a speed limiting problem. As the aircraft increases forward speed, more and more of the retreating blade starts to experience backwards airflow and it all becomes rather messy, aerodynamically.
Very true. Autogyros are not particularly efficient - even the best, which are the Wallis designs. They do, however, excel in terms of the useful load that they can lift (fuel, plot, payload) in comparison to the empty weight of the airframe.
Work in Progress is offline Find More Posts by Work in Progress
Old Jan 03, 2013, 03:57 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
This thread is such an education, you guys are great.
sparks
sparks59 is offline Find More Posts by sparks59
Old Jan 03, 2013, 05:46 AM
mixer421 is offline
Find More Posts by mixer421
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
This is going to be a fascinating build. Good luck Bob.
mixer421 is offline Find More Posts by mixer421
Old Jan 03, 2013, 11:25 AM
GeeW is offline
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
Power wise, for a model A/G, work on about twice that you would expect for a fixed wing.
Orientation is one of the biggest issues whilst flying R/C A/Gs so make sure it has a high contrast colour scheme. It also helps enormously to have the top of the rotor blades a different colour from the bottom.
The C of G shown on the plan does not look ideal to my eyes having had a few A/Gs. DO NOT let me put you off, A/Gs are great fun and can be flown (once you've had a few flights) in quite small spaces.
GeeW is offline Find More Posts by GeeW
Old Jan 03, 2013, 11:53 AM
Raf_Bob is offline
Find More Posts by Raf_Bob
United Kingdom, England, Lancs
Joined Sep 2006
I seem to have stimulated a bit of response by taking on this model. As I stated in an earlier post, my knowledge of these machines is almost nil so your various post are very welcome and enlightening. I suppose this model is not a true a/g as the head is not articulated! That would be a step too far at this stage and, of course, the whole idea is to build something that fits the "Britplan" formula. Is it torque or gyroscopic precession + bearing drag or all three or any other combination (sounds like echos of Twenty Questions) that affects these flying machines?? Whatever it is I think the challenge is intriguing. I've machined the spindles for the head and will show the photos when I can get time (being called for dinner). I'm aware of the need for extra power so I expect only short flights but time will tell.
Raf_Bob is offline Find More Posts by Raf_Bob
Old Jan 03, 2013, 01:04 PM
Joined Sep 2004
Oh, it's an autogyro, all right. It's just a fairly simple one.
Personally I like the two-rotor solution as used on the DB Autogyro: there's a good example built by a German modeller here:
http://www.helioldie.de/tragschrauber2.htm
These fly very similarly to a rudder/elevator/throttle trainer, but with the low-speed benefits of the rotary wing added on.
Old Jan 03, 2013, 06:15 PM
RyanNX211 is offline
Find More Posts by RyanNX211
Thermals, Tom
RyanNX211's Avatar
United States, OH, Upper Arlington
Joined Dec 2007
Is that a PT Gyro?
RyanNX211 is offline Find More Posts by RyanNX211
Old Jan 04, 2013, 02:37 AM
Raf_Bob is offline
Joined Sep 2006
Thanks GeeW for your posts. Could you let me know what you consider the correct balance point. Flying is a long way off, of course, but I'll probably start with the suggested position and see how it goes. Nevertheless, it would be interesting to experiment, so any observations from experienced A/G fliers would help.
Old Jan 04, 2013, 08:43 AM
Raf_Bob is offline
Joined Sep 2006
Contra-Gyro under way with the rotor head bearings. Mast is 14swg wire as original but the bearings are turned from delrin rather than fabricated from tinplate and brass tube. Next job is to bend the blade attatchment arms, again from 14swg wire. I always struggle with wire bending! getting clean, sharp bends eludes me somehow. I know one can get bending jigs but I'm relying on a home made one and a medium sized hammer
Old Jan 04, 2013, 09:13 AM
Joined Nov 2008
Originally Posted by Raf_Bob View Post
...the bearings are turned from delrin...
POM tiddly POM POM......!!
Nice work!!
Old Jan 09, 2013, 03:02 AM
McGiver is offline
Find More Posts by McGiver
NSWFFS
Richmond NSW Oz
Joined Apr 2005
I'm a bit late on this thread but thought I'd jump in as one of our older (88) flyers builds anything oddball, this being one of them.
I would offer two pieces of advice.
1) When building your rotor blades, build at least two sets. Sooner or later you WILL break one or two.
2) To launch, give both rotors a touch to set them on their way, run like blazes into the wind and give the model a healthy heave, preferably with the model at the correct attitude at release. When running, angling the model upward will result in (desirable) increased rotor speed at launch.
Landings were quiet reasonable affairs when preceded by flight, those immediately after launch rarely resulted in a quick flick and a second attempt. This is illustrated in one of the lower rotor blades in the larger, lower quality pic but he's still smiling!
Given Brian's age, getting the required launch speed was a problem for him with this model but the flights were always predictable and as long as you cared to put fuel into the tank for.
Cheers,
Rob
McGiver is offline Find More Posts by McGiver
Old Jan 09, 2013, 03:19 AM
Raf_Bob is offline
Joined Sep 2006
Originally Posted by McGiver View Post
2) ..................... run like blazes into the wind ..........................
Rob
Wow, Rob!! I can't run the length of my shoes, never mind blazing into the wind!!!
I'm having second thoughts about it now. Perhaps I'll finish it as a "hangar queen" and hope flying is not required for the build-off. I live in a windy area so it may be possible to let the wind run to me. We'll see.
Thanks for you post and the pics. I've done a bit more work on the rotor head and will get some photos up soon.
Old Jan 09, 2013, 11:54 AM
GeeW is offline
GeeW's Avatar
ENGLAND
Joined Jul 2001
Are you converting the head to Direct Control or is it staying fixed and using rudder and elevator?
In answer to a previous question 1/2A PT Gyro.
The trick in hand launching A/Gs is not to run....you do not need to. The rotor heads are slow to accelerate into full autorotation and it takes several seconds to get there. Most days if there is say 5 mph of wind I will just hold model at 45 deg nose up and wait. You will clearly hear when the heads pass from wind-milling and into autorotation and really start to accelerate. Once head speed stabilises start to walk forwards listen for heads further accelerating ...walk a bit faster for a couple of seconds then rotate model to nose only 10 degrees nose up and push the model forwards.
For ROG you spin up head (s) using fingers to make sure they are going the right way round (don't ask) and then taxi slowly forwards...give it a few seconds then a fast taxi then give it a couple of seconds the add a bit more power. Normally it will come airborne just as you add the final bit of power. The PT comes off the ground using about 1/2 power and is travelling at a medium walking pace. I then add more power to climb away.
http://www.photoavia.org.uk/AutoGyro%20Video.wmv
Gordon
Contest "Britplan" Build Off - 1st January 2013 to 30th June 2013 Now 22 Finished Models! Sundancer Vintage & Old-Timer Designs 257 Jul 16, 2013 12:23 PM
Build Log Rubberdub - Britplan Build Off 2013 - FLYING PHOTOS ADDED Sundancer Vintage & Old-Timer Designs 68 Jun 26, 2013 02:17 AM
Discussion Cyril Shaw "Envoy" - Britplan Build Off January 2013 to June 2013 cpmcgraw Vintage & Old-Timer Designs 280 Jun 26, 2013 01:35 AM
Contest Auster-Britplan Build-Off Jan 2013- Jun 2013 mrdj Vintage & Old-Timer Designs 6 Apr 02, 2013 06:02 AM
Discussion Proposed "Britplan Build Off" 2013 Sundancer Vintage & Old-Timer Designs 96 Dec 31, 2012 07:56 PM
