Old Jan 20, 2013, 02:22 PM
martin_ is offline
Find More Posts by martin_
Joined Sep 2010
You'r lucky to have the CC ESC with an adjustable head speed change rate, because I don't know of any other ESC with this feature, it's instant change with a good tail kick.
What I use on all my heli with non CC ESC, is to put a delay in my TX throttle between different flight mode, in this way you will be able to make the change very slow between your flight mode, even slower than you need.
martin_ is offline Find More Posts by martin_
Old Jan 20, 2013, 04:42 PM
Scott999 is offline
Find More Posts by Scott999
Joined Jan 2013
ICE 100 head speed change rate malfunction
Yes, thank you Martin, I am aware of this, however what ever has been done since the 11 Jan has apparently sorted that particular problem which in my experience was inherent with firmware 3.27
Now, since the 11 Jan update the "initial spool-up rate" function has been altered and cannot be slowed for "scale use" to any slower than 6 seconds within its total range of 0-20. I have noticed however, although no where near slow enough, the consistency of the spool up is more linear, as graphing shows which is perhaps an improvement.
*The function of the ICE controllers and the inclusion of such features as the separate "head speed change rate" is often why they are purchased over other brands and should work as advertised - luck has nothing to do with it.
I understand the nature of improvements, however if software is going to be mucked about with, affecting these functions negatively then the purpose is lost.
This ESC was available nearly 9 years ago and it has these basic issues at this late stage, which is why under these circumstances it is perfectly reasonable to ask for a reasonable time frame for these things to be corrected. So far I am not amused by the "when it suits us and not you" attitude.
Scott999 is offline Find More Posts by Scott999
Old Jan 27, 2013, 04:38 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
In testing my ICE75 I found that it wasn't that bad, but V4.02 definitely is not as slow as V3.27. With V3.27 I got an initial spool-up time of 19 seconds on rate 1, whereas with V40.2 it took 11 seconds (with either software version, using rate 0 did not slow it down any further).
I suspect that whatever change fixed your 'head speed change rate malfunction' problem has also affected the spool-up rate. Hopefully Castle's software engineers will sort this issue out soon, however in the mean time have you considered using simple governor mode instead, or even just using fixed endpoints with an appropriate throttle curve? Spool-up is much slower in these modes.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Jan 30, 2013, 01:11 PM
Patrick del Castillo is offline
Find More Posts by Patrick del Castillo
Patrick del Castillo's Avatar
Olathe,KS,USA
Joined Oct 2000
Good info Bruce -- I've sent a link to this post to our software guys - -and I'll have them take a look ...
Thank you!
Patrick
Patrick del Castillo is offline Find More Posts by Patrick del Castillo
Old Feb 02, 2013, 01:56 PM
Scott999 is offline
Joined Jan 2013
Altered software
Thanks Bruce, I took your suggestion, and tried simple governor mode, setting up flat lines on idle 1 and idle 2 on my 8FG using a tach to get the target speeds.
This works fine if you have LiPos in identical condition, where differing battery conditions combined with the fixed throttle % from the Tx result in differing governed target rpms between one battery and another.
Using 4.02 in set rpm mode holds the pre-set rpms within reason pretty well whichever battery I use. I just do not have a soft start function any longer.
As previously mentioned, the other change noted in 4.02 was (although way too fast for a low(2) setting) the more "linear" rate of spool up, where 3.27 during the last 1/3 or so of spool up would speed up - as in the graph line would steepen sharply near the end of spool up before reaching target speed. This is an improvement, but as it would appear - at the expense of the overall slower spool up from 3.27
Patrick - I purchased this ESC for a scale model helicopter because I believed it to be able to provide a slow spool up, with a separate adjustable speed change between target governed speeds.
Given that this software is in all ICE controllers (including HV controllers) with some fitted to some large expensive scale helicopter models, can you please ask your software engineers for a reasonable time frame that these issues (including the graph viewing problem) will be corrected for us all please? - Under the circumstances during this thread, I don't believe this to be an unreasonable ask.
Old Feb 26, 2013, 01:52 AM
Scott999 is offline
Joined Jan 2013
response please??
Old Feb 28, 2013, 01:56 AM
Andy01 is offline
Find More Posts by Andy01
Joined Feb 2010
Scott
Is it possible to just load up an earlier firmware version that does not have this bug ?
All of my helis (incl 3 scale helis) run Ice ESCs (1x Ice 50, 2x Ice 75 & 2x Ice 2 80HV) with older versions, and they all spool up nice and slow (around 30-40 seconds), and change speed (done rarely and only in very small 50rpm increments) at a reasonable speed.
Colin
Andy01 is offline Find More Posts by Andy01
Old Feb 28, 2013, 06:56 PM
Scott999 is offline
Joined Jan 2013
Hi Colin, thank you very much for your reply - YES this is a good idea, and thank you for this suggestion - I did think of this, however with the two separate problems with two separate and late issue firmware versions (3.27 and now 4.02) I was reluctant to go back further only to find other problems hence the reason for later versions, with endless re-calibrating throttle end points each time etc.
Also, I felt that the Castle people could have made a suggestion as to just which earlier version or better still at least read the thread properly and reply to us all here on when the issues of late will in fact be resolved.
I seem to be ignored on the faults at this point for well over a month now the faults not being isolated to my set up or my "finite taste" personally (as was suggested)
Thanks again Colin, can you suggest a version you are having success with? 30-40 seconds with the ability to reduce this by higher settings between 0-20 sounds much more like it is supposed to work. Not 6 seconds on setting "Low 2" !
Old Mar 02, 2013, 07:17 PM
Andy01 is offline
Joined Feb 2010
My latest software (on my PC) is 3.41.1, downloaded in December 2011, so it is not a new version. I am a great believer in "if it ain't broke, don't fix it".
This would make it firmware 3.28 I think (I don't have a ESC handy right now to check). I have a suspicion that a couple of ESCs (like the bigger Ice 2 80HVs) may be even older because I got them in December 2011 during the big swap, and I don't think I have ever updated them.
You can try "Custom" and set it to 0 or 1. Set a slow "rate of change of speed" setting as well.
Colin
Old Mar 02, 2013, 07:33 PM
Scott999 is offline
Joined Jan 2013
firmware version
Thanks Colin, I have noticed that there appears to have been a firmware version 3.28, however I also note that later link software does not then give and option between 3.27 and 4.02 and therefore I don't have access to 3.28.
Therefore I am still in the dark about which firmware version does not give PROBLEMS
The assumption is that if I go back too far then there is the chance of earlier problems, however there are some people (Castle) who will know exactly whats going on and they are not forthcoming on the matter.
This forum is rather pointless if the manufacturer cannot even take the time to reply usefully.
Currently the lower custom setting of 1 or 0 makes no difference to "Low 2" in version 4.02 (now non beta)
Thank you Colin for your time, would appreciate a confirmation on which firmware version your one is using sometime ?
Old Mar 08, 2013, 02:56 AM
Andy01 is offline
Joined Feb 2010
Castle does say that if you want a reliable response, it is better to contact their support line rather than use the forum.
I am not sure when I will be dragging a heli out - our club field was submerged under 6 feet of water 6 weeks ago, and still out of commission, so haven't flown for a while.
Colin
Old Mar 08, 2013, 03:04 AM
Scott999 is offline
Joined Jan 2013
no response from Castle on a reasonable request.
Hi Colin, yes I realize this and have emailed directly with NO response other than the auto response which I received back last month on the 27th.
Sorry to hear your field is out of action!
Old Mar 08, 2013, 03:36 PM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Scott I spoke to Steve today and you had been e-mailing back and to with him... he had previously sent your information to engineering for them to review...Steve has been out this week.
I just read through this post and it was very confusing... Please email me an overview of the issue you are having with graphs (.csv ) and the settings file (.dat ) of your setup including all vehicle setup. I will email this directly to engineering to see if they can reproduce the issue... also include all testing info you have... Thanks in advance.
clint@castlecreations.com
Clintstone is offline Find More Posts by Clintstone
Old Mar 10, 2013, 04:26 AM
Scott999 is offline
Joined Jan 2013
ICE100 firmware faults
Hi Clint, Thank you, have emailed you some info.
I cannot speak for all others but I know 2 others who can confirm that the latest 4.02 (non beta) firmware on the lowest spool up setting is a lot faster than it was on 3.27, the times obviously varying between different heli set ups - mine being a very basic fly barred Align 600E set up.
Scott.
For Sale BNF Trex 500 FBL KDE upgrades, I2 Head, Tail, Tail Boom Holder, Hitec Servos, ICE 100 MrGoo Aircraft - Electric - Helis (FS/W) 2 Oct 09, 2014 07:27 AM
Sold Castel Ice 100 speed control New in Bag $100 shipped Sell...er Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2012 02:27 PM
Sold Creations Phoenix Ice 100 Brushless Speed Control RickC2009 Aircraft - Electric - Power Systems (FS/W) 3 Oct 01, 2012 09:03 AM
Discussion ice 100 spools head faster than blades....wobbles hidaven Electric Heli Talk 2 Aug 04, 2012 09:55 PM
Question ICE 100 BEC rating? JustPlaneChris Castle Creations 1 Oct 18, 2010 01:33 PM
