Joined Jan 2013
ICE100 auto rot feature stuck on
Hi Alan, thank you for your help, here is some info. I've played with it with the blades off before and the same thing happens - it all works as it should except for the noticeable sharp drop off in head speed, but that's a simple matter of not swinging blades.
Now under proper load at the field, I can get it to work on the ground sometimes and not others, so it is unreliable and quite vicious - 10T pinion! probably won't strip the main gear, but it is NOT nice. Will set up to go past the 30 flat line and only use the 70 and 100 flat lines (Idle 1 and 2) on 8FGH to switch between speeds to see if there is any difference. As mentioned earlier there was no difference on firmware version 4.02 that I thought I was supposed to be using.......... |
Chicago 'burbs
Joined May 2006
In the plot things look like they are working just fine on the ramp ups---it is taking something like 3s (0.05min, one of the x axis ticks) to ramp from the low level to the top, and a little less to ramp down.
Remember ramping down is a bit different because most heli's have one way bearings and the motor/pinion decouples from the main gear when you command a ramp down. Also this value of head rpm isn't really the head rpm when the one-way bearing releases, it is the actual motor rpm divided by the gearing. Anyway this plot looks "ok". Apparently this isn't what you are seeing in the air. |
Joined Jan 2013
Hi Alan, yes this is correct, the constant is when first plugged in - it will work every time on the way up. It is after this that it fails to ramp back up at the change rate setting of "2" as it does on the first spool up between 1450- 1650.
WITHOUT the blades however it will work correctly ?? I am not interested in experimental trying this and trying that firmware wise on a scale heli with a whole lot of guessing and risk - I want to know which version is a proven version - which is why I have it on 3.27? or this version faulty I wonder? |
Joined Jan 2013
Firmware
An up date on this head speed change rate problem. Have downloaded "Link" software version 3.53.11, and found that the ESC "firmware" version 4.02 is no longer a "beta" version.
So updated that, cleared the logger and without doing anything else and went out and tried it - it is FIXED, I could not get it to doing anything other than what it was set to. GREAT! Now, a couple of other things have become apparent. Firstly, the slow start appeared to be somewhat faster still on the low (2) setting. Then when I came home and loaded the data, I only got 1 "session" out of two separate flights (two separate batts) I cannot see all the info on along the bottom of the graph viewer window, it cuts off the Max line........... |
Joined Jan 2013
ICE 100 4.02 slow start now NOT slow
Ok, it appears that when the data logging is set to 10hz a second, as opposed to 1, it will only store one session
I have set it back to 1hz, and got it to record two sessions at home without blades on. As for the slow start - nope, it is no longer a "slow" spool up when set on low (2) even with blades on. setting to either 1 or 0 makes no difference?? |
United States
Joined Feb 2001
Does your FBL controller have a governor? You might want to consider using an external governor and the new CC external governor mode.
Both my Skookum SK540 and SK720 (temporarily out of production) have the capability to set the spoolup rate. You could email Skookum and ask about the slowest spoolup speed available. . |
Joined Jan 2013
Fautly ICE 100 ESC
Thanks RC Man, however I do not have any of these items. This is a basic older Align 600E fly bar mechanics in a scale fuselage.
There was nothing wrong with the soft start function before this recent change in software/firmware. Remember the "initial spool-up rate" setting has a range of 0-20 with the lower end the slowest ..........which is now NOT slow. I most certainly will not be buying some "add on" to solve a problem "given" to me by Castle, where obviously the unreliable head speed change rate problem has been replaced with a problem with the slow start/spool up function. |
Joined Jan 2013
Castle creations software malfunction
What do you mean "Beta" firmware? when we updated the link software from the 11 Jan, the 4.02 no longer had "Beta" beside it in the software tab?
I have also recently been accused of having "such finite taste" by a Castle rep over something that has nothing to do with me or anybody's "taste" for that matter. If you check the beginning of the post where I have made an effort to be thorough in information in order to make it easy to be assisted you will see that 3.27 is where a different problem existed to begin with. The fact is there is now a different fault with 4.02 and it does not function as it is did in 3.27 with regard to the "initial spool-up rate" setting. This function was fine in 3.27. If there is any more nonsense on here or directly to me via email on the matter other than to assist in resolving the issue, the item will be returned for refund immediately. I have given Castle the benefit of doubt in my decision to support them even after the ICEHV problems, but I will not tolerate unfair personal accusations regarding a product fault.....or in this case faults. |
| Thread Tools | |
| Sold Castel Ice 100 speed control New in Bag $100 shipped | Sell...er | Aircraft - Electric - Power Systems (FS/W) | 0 | Oct 28, 2012 02:27 PM |
| Sold Creations Phoenix Ice 100 Brushless Speed Control | RickC2009 | Aircraft - Electric - Power Systems (FS/W) | 3 | Oct 01, 2012 09:03 AM |
| Discussion ice 100 spools head faster than blades....wobbles | hidaven | Electric Heli Talk | 2 | Aug 04, 2012 09:55 PM |
| For Sale BNF Trex 500 FBL KDE upgrades, I2 Head, Tail, Tail Boom Holder, Hitec Servos, ICE 100 | MrGoo | Aircraft - Electric - Helis (FS/W) | 0 | Jun 05, 2012 01:22 PM |
| Question ICE 100 BEC rating? | JustPlaneChris | Castle Creations | 1 | Oct 18, 2010 01:33 PM |
