Old Jan 01, 2013, 10:57 PM
storkus is offline
Find More Posts by storkus
storkus's Avatar
Joined Dec 2012
Sig Kadet II. Removing dihedral, and motor options.
So, I've got this partially framed up sig kadet II. The wings are built with the stock dihedral, which is a lot. I'm thinking about getting rid of the dihedral, cuting off maybe one rib bay on the inside of each wing, and one on the outside of each wing, cutting off the wing tips, which would remove about 6 inches of span in total. I also want to put a really fast motor on it, make it a really hot plane. What do you guys think? I can't really think of anything else to do with this half-built kit that I started while I was learning to fly. Would these mods work out? Let me know what you think.
Also, do you have any suggestions in terms of power set up? I've never put together my own system before. I'm hoping to to have this plane come out at about 5 pounds.
storkus is offline Find More Posts by storkus
Old Jan 02, 2013, 12:55 AM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Build it standard, sell it, and buy/build something fit for purpose.
Or, build it standard, enjoy it for what it is, improve your landings and rudder coordination. I can't bring myself to get rid of my stock Kadet LT-25 simply because it is such a nice flyer, and each time I get a nice axial slow roll is that bit more skill that goes into my pattern and 3D models. And I've powered it with near 800W and it sure climbed ballistic, but top speed remained modest.
You just can't make that into a hot ship - the wing section is too thick and thus has a lot of drag, it has has a lot of camber and thus has a strong pitching moment as airspeed increases, the longitudinal dihedral opposes going fast, and so on.
IMO butchering it without real prospect of achieving your goal is rather pointless.
If you want something genuinely hot, start with a Hobby King Rare Bear funfighter for around $80 plus a couple $10 3S-1000 packs, then when you're keeping up with that grab a couple of 4S-850s and hang on.
scirocco is online now Find More Posts by scirocco
Old Jan 02, 2013, 12:59 AM
storkus is offline
storkus's Avatar
Joined Dec 2012
How much could I get for it if I were to build it? Not saying I wouldn't end up enjoying it, just want to make an informed decision. I don't really have the funds to have all kinds of planes lying around.
Old Jan 02, 2013, 01:19 AM
storkus is offline
storkus's Avatar
Joined Dec 2012
Here are some pictures of one of the wings. I also have another wing, and two fuselage sides all done. Haven't touched this for a few years, and I've been thinking it's time to finish it or give/sell it to someone who would.
Old Jan 02, 2013, 09:11 PM
baldguy is online now
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Build it standard, keep it and enjoy the crap out of it!
baldguy is online now Find More Posts by baldguy
Old Jan 04, 2013, 11:17 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
It's a kadet, huge amount of wing area, high wing, flat bottom wing. It's not meant to be fast or hot. You can remove the dihedral by adding a few shims of lite ply or balsa to the wing joint decreasing the dihedral angle. This would allow you to maintain the amount of wing area the bird is meant to have while giving you a significant amount of pizazz I think you are looking to put into the plane.
The Sig design of that bird is tried and true with more than 20 years of field service on that frame, why change a good thing?
That's difficult to say. Are we talking fully equipped RX/battery ready or just the covered bird no electrics? Either way it's only worth what someone is willing to pay. The problem you may run into is that people would rather put $100 or $150 towards the model of their choice. They may not like the color scheme you chose for it. Personally I'd build it and hold onto it.
I converted a prebuild Great Planes Trainer .40 from glow to electric. This bird is not lightened. I powered it with this motor from HK http://www.hobbyking.com/hobbyking/s...dProduct=14404, on a 4S 5000 mAh pack I get 500 watts WOT, and it only draws around 32 amps. AUW is 6.5 lbs.
dedStik is offline Find More Posts by dedStik
Old Jan 05, 2013, 04:17 PM
catspaw is offline
Find More Posts by catspaw
catspaw's Avatar
United States, WI, Stoughton
Joined May 2003
Kadet II was my first plane. Well after I was a proficent flyer on other birds, I used this for my knock around and fun fly plane. Replaced a lot of pieces in the process.
If you are set on reducing the diherdal, then do only a little, leave some in. One of our club trainers was a MkII, but had zero diherdal, and was a taildragger. NOT ideal for a new pilot, I'll tell you that! It was kind of squirrelly on takeoff, that being it's main problem.
catspaw is offline Find More Posts by catspaw
Old Jan 05, 2013, 07:05 PM
I eat glue
Joined Jul 2006
I have a Seniorita that I cut the dihedral in half, put in ailerons and flaps, and made it a taildragger. Love flying that thing, flies faster than I thought it should be able to. I use an Eflite Power 25 and a 3s battery in it. 4s is gobs of power, can go vertical. Mine weighs about 4.5 pounds ready to fly.
Old Jan 07, 2013, 11:51 AM
DustBen is offline
Find More Posts by DustBen
DustBen's Avatar
United States, AL, Birmingham
Joined Dec 2011
Finish building it close to stock.
A flat bottom airfoil plane doesn't invite "going fast" well.
The wing creates more lift at higher speeds, requiring more down trim, but once you cut throttle to cruise around, it dives, adding down thrust only goes so far, you can try mounting the wing with less angle of incidence but that too is a speed/lift compromise.
Finish the model, keep it, teach someone else to fly, and then someone else after that.
DustBen is offline Find More Posts by DustBen
For Sale Sig Kadet M. II SnoJetter Aircraft - Fuel - Airplanes (FS/W) 0 Sep 15, 2012 10:31 PM
For Sale Sig Kadet Mk. II - electric conversion? SnoJetter Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2012 10:29 PM
Question Sig Kadet Senior Dihedral? Harry60 Beginner Training Area (Fuel) 8 Jul 09, 2012 10:26 AM
Help! Sig Kadet Sr Arf Fuel Tank Removal fenderjw Fuel Plane Talk 4 Jul 13, 2007 08:51 AM
Removing dihedral on Kadet LT-40? mhgoldwing Fuel Plane Talk 6 Feb 23, 2005 04:54 PM
