This thread is privately moderated by Peejster, who may elect to delete unwanted replies.
Old Jan 01, 2013, 06:20 PM
Peejster is offline
Find More Posts by Peejster
Trader Rating: 83
United States, WA, Seattle
Joined Oct 2012
Trader Rating: 83
Sold
Flyzone Cessna 182 Select Scale EP Tx-R
Plane in great shape - no damage. It has been flown a handful of times with no crashes or roll overs - still on original prop. There are a couple of spots where a foam cell or two has been pushed in a bit (can be seen in the photos); it's very minor but wanted to point it out.
This is transmitter ready so all electronics and power system components are included - motor, esc, servos, receiver, light kit. Two batteries are included as are an extra prop and spinner. Lipo balance charger with AC and DC plugs are also included.
This plane is completely stock except that one of the factory servos was replaced by a Hitec HS-55 servo (you can see it installed in the battery tray in the photos).
The plane flies well - very scale. It's just not the plane for me.
$110 Shipped CONUS
Here is the link to the product page:
http://www.flyzoneplanes.com/airplan...html#txranchor
FEATURES:
Construction: AeroCell foam with pre-applied decals
Wing: One-piece design with functional flaps and ailerons, wing attaches with two bolts
Electronic Speed Control: 18 amp Tactic BL-18, TACM6610
Servos: Four FLZA2012, 1 rudder, 1 elevator, 1 aileron and 1 flap
Motor: Brushless outrunner, FLZA6082
Receiver: Tactic 2.4GHz SLT receiver
Battery: 11.1V 1800mAh LiPo
Battery Charger: Balancing capable with AC/DC adapters
Lights: Red and green blinking navigation lights on wing and tail
Landing Gear: Prebent aluminum 0.08" (2mm) thick, tricycle style with spring loaded steerable nose gear
Wheels: Foam, two main 1.75" (38mm) diameter, 1.75" (38mm) nose wheel
Canopy: Plastic tinted windows, instrument panel in cockpit
Spinner: 1.4" (35.8mm) diameter chrome finish plastic
INCLUDES: FlyZone TxR Cessna 182 Skylane Select, brushless motor, ESC, servos navigation lights, photo illustrated instruction manual, RX, spinner and propeller
REQUIRES: Tactic AnyLink SLT 2.4GHz Radio Adapter (TACJ2000) to adapt aircraft transmitter (the Futaba Square, TACM0001 and JR, Spektrum, TACM0002 are included with the AnyLink adapter)
*Tactic 2.4GHz 6 channel transmitters do not require the AnyLink adapter
SPECS:
Wingspan: 47.5" (1207mm)
Wing Area: 339 sq in (21.87) sq dm
Weight: 37oz (1049g)
Wing Loading: 15.72 oz/sq ft (48 g/sq dm)
Length: 39" (991mm)
Center of Gravity (CG): 1-7/8" (48mm) from the leading edge of the wing at the fuselage
Control Throws-
Elevator: 11/16" (17.5mm) up and down
Ailerons: 5/16" (7.9mm) up and down
Rudder: 13/16" (20.6mm) right and left
Flap Throw: 3/8" (10mm) down
Peejster is offline Find More Posts by Peejster
Old Jan 02, 2013, 02:15 PM
TheBeastTamer is offline
Find More Posts by TheBeastTamer
Trader Rating: 37
Closed Account
Joined Jan 2012
Trader Rating: 37
Pm'd you.
TheBeastTamer is offline Find More Posts by TheBeastTamer
Sold Assembled Brand New Flyzone Cessna 182 Skylane Select Scale chucksolo69 Aircraft - Electric - Airplanes (FS/W) 3 Jan 08, 2013 10:14 AM
Sold Flyzone Cessna 182 Skylane Select Scale (and/or AnyLink Adapter, Power adapter) davidjrojas Aircraft - Electric - Airplanes (FS/W) 1 Jul 23, 2012 01:27 PM
flyzone cessna 182 scale select wing strut hobbiconexstar Non R/C Items (FS/W) 5 Jun 30, 2012 02:15 AM
Sold Reduced price! Nice used Flyzone Cessna 182 skylane select scale RTF setup... MiG-3 Reno Rocket Aircraft - Electric - Airplanes (FS/W) 1 Mar 18, 2012 03:59 PM
