Joined May 2012
I've looked that motor up, but it is only 140watt that 28-30 750kV motor. Most motors have many more, but if you have experience with it I will try.
If anyone else has a good idea about great motors (maybe a bit more expensive than hobbyking prices?) Just want it to be good. Don't care if it is 50 bucks more or less. & deno, your vids are looking nice! good environment! |
More watts are not always the best choice, it means the motor is thirstier
![]() i have used those motors for a long time, many crashes, i learned flying with them, and now my friend are using my old motors, and they are still strong on power and still in one piece ![]() i really recommend these motors, do not overweight your quad with a heavy frame or big batteries,every gram will affect your sport flying characteristic. Make it simple and light, don't use anything!! that you don't need.Some 20/30A high pwm escs, some plastic(for the learning process) 10x4.5 props, the ntm motors, 3000-3300mah 4s lipos and a fc board and you are good to fly then you can go for better props, fpv and stuff...
Joined May 2012
Do you fly that setup with gopro? In that case I won't have that much weight. Today my father in law and I build a quad with the frame I mentioned which was about 1050gram without gopro and battery, but heavier motors than the one I am looking at from now on.
What is your auw weight with the setup you recommend me? (and btw, I passed the learning process a long time ago on my 3D heli's and wookong octo, without fpv ). Because this is a new type of flying I want to know what combo is best for my needs.Thanks for your help, appreciated!
As I said I was at learning process when I was using these motors, if I am not mistaken I was flying 9 mins of fpv with these motors, on a 2650mah 4s lipo, with auw of 1200grams(plus/minus 50grams). I did not have a a gopro that time, I askedmy friend for his setup with my old motors, when he calls me back, I'm going to write it here.
Germany, BY, Gestratz
Joined Oct 2008
This one has a 3s 5000 battery, auw is about 1400g, motors Sunnysky X2216 880KV with 10" props. Flight time is 19 min. I will now check 12" props, I guess the kv of the motors are lower than rated...
Btw. the motor are affordable, the quality is great, especially bearings (much better than NTM stuff) P.S. Flying aroung obstacles has *ever* a certain risk with 2.4 Ghz. Sometimes it will work, sometimes not. If you fly behind a tree with foliage, you'll have to get a reflected signal from somewhere. Here 35/40 Mhz equipement has big advantages |
| Thread Tools | |
| Discussion Which Quad to get for First Quad / FPV Rig, Gaui 500x or FPV QAV500 or other? | Cloudbase2 | Multirotor Talk | 3 | Dec 01, 2012 11:10 PM |
| Found Looking for a Quad Addict FPV frame or qav500 fpv | thehaw24 | Aircraft - Electric - Multirotor (FS/W) | 1 | Oct 16, 2012 09:46 PM |
| Discussion Lost my FPV plane... Found with my FPV Quad. | Gundy | Video Piloting (FPV/RPV) | 5 | Aug 09, 2012 04:40 PM |
| Build Log Micro FPV Quad "Quadrixette FPV-frame" | daign | Multirotor Talk | 60 | Mar 18, 2012 02:32 PM |
| New Product Quad controller for FPV quads by Cercom | Hauntme13 | Video Piloting (FPV/RPV) | 19 | Nov 19, 2010 08:52 PM |
