OK, so I didn't go the re-cycled Biro route but I still had to dig deep in my engineering skills to produce this spring strut. Bear in mind that for the last 35 years my mechaniking has been of the agricultural variety involving big lumps of iron and the primary tools a big 'ammer and a long lever.
When my son presented me with a box full of assorted RC car suspension bits, I was delighted to find a pair of mini dampers with alloy bodies. I started by removing the plastic washers that provided the damping effect and the connecting eye on the rod. The hardest bit was filing the end of the rod to fit into a piece of brass fuel tube used to join it to a length of 2mm wire with a generous dollop of solder. I cut off the eye at the top of the damper and drilled and tapped it to take the threaded bit of the 2mm rod with added 'Z' bend. It's locked in with a drop of epoxy. As I don't posses a 2mm tap, I tapered the end of a bit of threaded rod and cut a groove with my dremel cut-off disc, works fine into alloy or plastic. With suitable card fairings, it should look OK. BTW, the springs are from Biros!
Almost there. Undercart and decoration done. I just have to do a bit more glazing, add the fairings to the U/C and struts, add a bit of paint here and there and then do some power tests with different props. There is one main problem!
I need to extend the spring struts to give more ground clearance to the prop. I really like the 8 x 4 three blader but there's only about an inch of clearance. The two blade 9 x 4.5 is, theoretically the most efficient but even less clearance with that. I have run a 7 x 6 on the motor but I'm not sure if it'll have enough thrust which is why I have to do some tests.I think it looks OK for my first attempt at a scale model. |
Your early estimate was spot on, 22oz all up. With those tiny but scale wheels I don't think it will take off from grass but who will I trust for that first hand launch! I'm prepared to fork out for a better motor if needed.
Now that is looking GREAT!!!!
Re the prop clearance, although the current wheels arecorrect scale, you could consider having some 'flying' wheels that are larger diameter to give the clearance needed for the three blader.....would help with takeoffs from less than perfect surfaces too! I don't think that it would detract from the appearance much.... Good work, fella!!!!! Blinkie's still here and he's feeling jealous - but WARM and jealous..... Return on Sunday and have been hankering to continue with the Kitten! |
Thanks all for the kind comments and suggestions.
![]() I'm going to extend the spring strut by about 1/2" and I like Col's suggestion about bigger 'flying' wheels. The antipodean warmth must have stimulated a few brain cells. ![]() Looking forward to seeing you back in harness and getting that Kitten finished.![]() Time to hook up my new wattmeter today and see how much ooomph I can extract from my 2830/14 on 2 fully charged cells. The Doc's peak efficiency chart shows that I should get around 200W in, 120out with the 7 x 6 and the 9 x 4.5.
I'm surprised at how little difference there is between the APC/E 2 blade 9 x 4.5 and the 3 blade, GWS 8 x 4.
Both at 7.6V under load, the APC took 120W in, at 13.5A and my thrust comparator showed 375gm. The GWS took 105W in at13.1A with 370gm of thrust. It's clear that the APC is better but I will have to jack up the U/C or it could be expensive on props! |
Very nice job indeed. One thought - a little more belly clearance if possible would be good. Maybe larger wheels which would also help with prop clearance. Maiden flight over tall, tall grass for insurance and peace of mind if at all possible. Again, beautiful job and looking forward to the flight reportJohn |
| Thread Tools | |
| Discussion Cyril Shaw "Envoy" - Britplan Build Off January 2013 to June 2013 | cpmcgraw | Vintage & Old-Timer Designs | 266 | Today 10:57 AM |
| Contest "Britplan" Build Off - 1st January 2013 to 30th June 2013 Half Time Update Post#156 | Sundancer | Vintage & Old-Timer Designs | 198 | May 20, 2013 11:22 AM |
| Discussion BritPlan buildoff .. an oddity | Applehoney | Vintage & Old-Timer Designs | 40 | Apr 22, 2013 08:51 AM |
| Discussion Auster-Britplan Build-Off Jan 2013- Jun 2013 | mrdj | Vintage & Old-Timer Designs | 6 | Apr 02, 2013 06:02 AM |
| Discussion Proposed "Britplan Build Off" 2013 | Sundancer | Vintage & Old-Timer Designs | 96 | Dec 31, 2012 07:56 PM |
