Old Feb 07, 2013, 12:53 PM
pomroyj is offline
Find More Posts by pomroyj
History Eraser Button?
pomroyj's Avatar
United States, AZ, Phoenix
Joined Aug 2010
Originally Posted by Sundancer View Post
It's looking very smart Mixer. One question though - does it have a bit more dihedral than that once you fit the struts - I hope so.
mixer - To follow on SD's point, will there be ailerons? If not, I doubt there's enough dihedral for adequate rudder only control. I think you said the wingspan was 43"~44". Assuming a 4" wide fuse and 1.5" of dihedral on each tip, this gives 4.3deg on each tip or 8.6deg total. You'll need about 13~16deg total to get a nice handling model without ailerons
John
pomroyj is offline Find More Posts by pomroyj
Old Feb 07, 2013, 01:23 PM
mixer421 is offline
Find More Posts by mixer421
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
John
Thanks for the information John. It's good to have someone who knows this technical stuff! There are no ailerons and your point about dihedral had briefly crossed my mind. With the adjustable struts set at minimum length for 1.5", by my very rough measurements, at maximum length, an increase of 0.5", the dihedral should almost double. If it doesn't, then it's easy enough to make a longer set.
mixer421 is offline Find More Posts by mixer421
Old Feb 07, 2013, 01:53 PM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Based on experience rather than calculation, I would normally expect to be using in the region of 2.5" under each tip for a 44" rudder/elevator model. HOWEVER, as the EP9 has a pod and boom fuselage with a lot of side area concentrated at the front I think you might well get away with a bit less - say 1.75" to 2". Being a scale model of an aircraft which doesn't have much you won't want to spoil the looks by using more than you need, so the adjustable struts will be handy, you could start off with 2.5" which should certainly be safe and reduce it a bit at a time once you get the model otherwise trimmed.
Sundancer is online now Find More Posts by Sundancer
Old Feb 07, 2013, 03:57 PM
NOI53Y is offline
Find More Posts by NOI53Y
Australia, ACT, Canberra
Joined Dec 2011
Originally Posted by RFJ View Post
Here's the deal NO153Y. To get you started you can have mine - if you collect it. I can arrange to be at home tomorrow afternoon. After all It's only 10,648 miles according to the side bar
Ray
Oh bummer Ray,
It appears that Tomorrow has come and gone. I guess i'll have to pass on your lovely gesture
Mixer, she's starting to look good.
Regards,
Glenn.
NOI53Y is offline Find More Posts by NOI53Y
Old Feb 07, 2013, 06:25 PM
Sky Jiver is offline
Find More Posts by Sky Jiver
Sky Jiver's Avatar
United Kingdom, England, Gt Man
Joined Jul 2012
Come fly with us
Originally Posted by Colonel Blink View Post
Very kind of you to say so, George - and I put my success so far down the help I have received here; before now I have only had my own brain to answer the myriad of minor questions that crop up! The whole interaction and proven experience of those in this corner has made these past nine months a real joy. This summer (assuming we get one), I even hope to make it to some Vintage meeting where I can fly with others, possibly even others from here.
Hello Colonel Blink. You would be very welcome to come and fly with "even others from here" this summer, myself hopefully STOMPING and Ian of The Travelling Tadpole. We are not exactly a Vintage group but well electrified.KBO.. Sky Jiver. The naughty message will not transmit,what am I doing rong?
Re the Tiggy, you have actually hit the issue on the head - I actually wouldn't mind building something a little more intricate, but the reality is that with my short 'modelling opportunity windows' it would likely be a project that would be too long for me to sustain the effort. One for retirement or when Young Pippa Blinkette trots off to finishing school, perchance. Until then, there are any number of alternatives to consider!!
As it says on the decent-sized mug that Young Pippa Blinkette bought me for Christmas, along side a pic of Brains from Thunderbirds:
".....Of course! Now why didn't I think of that?"
Hello Colonel, You would be welcome to come and fly with "even others from here" myself hopefully STOMPING and Ian with his Travelling Tadpole. We are not exactly a vintage club but gently electriflying and established since 1978. KBO Sky Jiver.
Sky Jiver is offline Find More Posts by Sky Jiver
Old Feb 08, 2013, 08:45 AM
pomroyj is offline
pomroyj's Avatar
Joined Aug 2010
At 2.5" under each tip, I get 14.25deg total which should be safe for initial flights. Good to hear you can adjust from there. Of course, if you want a more scale look, add some ailerons. I expect the full scale had them and in this size model an HXT900 (9gr from Hobbyking @ $3/ea) in each wing could be easily added I think
You probably know this, but here's the dihedral math in detail
total dihedral = 2 x arctan[(tip height) / halfspan] = 2 x arctan[ 2.5" / 20"] = 2 x arctan(0.125) = 2 x 7.125deg = 14.25deg
The function 'arctan', also referred to as 'inverse tangent', is on most calculators. The button would be labeled as 'tan-1' or 'arctan'.
When working with small angles (<=20degrees), the arctan function can be approximated by the quantity 180/pi (remember the constant 'pi' from grade school math? It represents the ratio of circle circumference to diameter which equals 3.14159....). Like arctan, many calculators have a special button that gives you pi's value.
Here's how the small angle approximation math works for the example above
total dihedral = 2 x (180/pi) x [(tip height) / halfspan] = 2 x (180/3.14159) x [ 2.5" /20"] = 2 x 57.296 x 0.125 = 14.32deg
John
Old Feb 08, 2013, 02:40 PM
mixer421 is offline
Agricultural flyer
mixer421's Avatar
Joined Aug 2007
John
Thanks for the detailed math John. My old maths master, 'Spider' Beck, would be proud to know that I understood all of it. And he wouldn't even let us use a slide rule or 'guess stick' as he called them, calculators would have given him apoplexy!.
I have seriously thought about adding ailerons and I think it would be possible to do it with a single servo in the fuselage but I'd like first to see how it flies with just rudder / elevator in case there is a weight issue. I could build a second pair of wings later with ailerons and the possibility of using them as flaperons to more closely simulate the STOL performance of the full size.
I'm feeling a little sad as I'm in the last stages of serious balsa bashing - just a few more bits of 1/8"square to complete the elevators then it's all down to sanding, doping, ironing and wire bending.
Old Feb 08, 2013, 04:15 PM
pomroyj is offline
pomroyj's Avatar
Joined Aug 2010
Mixer - Your doing a beautiful job on a wonderfully obscure project; it just oozes personality! Like my Fleester and Champion projects, I also really enjoy getting away from the mainstream birds. A 2nd wing with flaperon capability is a great idea.
I'm also always a little sad when I move beyond the framing stage; that part is always fun while presenting unique challenges, all good for the brain cells. What keeps me going is knowing how great it's all going to look during an overhead flyby with the sun shining through that translucent/transparent covering you put on.
Hang in there; covering always goes faster than you think. We're all with you in spirit and looking forward to the video, pics, and flight report
John
Old Feb 09, 2013, 02:35 AM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
She's really coming on well now, Mike! Re the ailerons, that reminds me that I really should take the bull by the horns and try the fourth channel myself one day soon.....
Thanks for the offer SJ! I may well take you up on that come the summer, though your club may have an issue with the fact that though I am insured, I have no A (or is it B?) test......
Colonel Blink is online now Find More Posts by Colonel Blink
Old Feb 09, 2013, 04:40 AM
Joined Nov 2008
I'm feeling a little sad as I'm in the last stages of serious balsa bashing...
I've found I tend to cover some items whilst the glue is drying on others, so I don't have sharply defined 'building' and 'covering' stages. The downside is that I never manage to take those nice pictures of the whole uncovered structure fitted together....
Old Feb 09, 2013, 01:25 PM
mixer421 is offline
Agricultural flyer
mixer421's Avatar
Joined Aug 2007
Most of my previous models have been 4 channel and it tends to make you a lazy flier, usually ignoring rudder input. It was only recently with the Fun Cub (one of those awful foam things for the benefit of real model fliers) that I've started to teach myself to use a bit of rudder for cleaner turns. Of course with these modern computer radios, you can cheat and do it with mixing but much more satisfying to do it properly.
Old Feb 10, 2013, 07:55 AM
mixer421 is offline
Agricultural flyer
mixer421's Avatar
Joined Aug 2007
Well I had to take a photo of her 'naked' didn't I? I stitched the wire strut anchors to the wings and put her together with some temporary struts set at 1.5" dihedral - they're too short to give the full 2.5". 1.5" doesn't look too far out of scale but 2.5" will probably not look good so the aileron wings are definitely worth doing later.
Old Feb 10, 2013, 11:05 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Very, very nice Mixer. Another 1/2" a side wouldn't spoil the scle looks so much and |I reckon it would fly OK with that.
Old Feb 10, 2013, 09:57 PM
pomroyj is offline
pomroyj's Avatar
Joined Aug 2010
Beautiful work mixer. Love the pregnant guppie fuse!
Old Feb 11, 2013, 04:50 AM
mixer421 is offline
Agricultural flyer
mixer421's Avatar
Joined Aug 2007
I just hope I can make a good job of covering, time to practice with the solarfilm polyester methinks!
Perhaps the deep fuselage will help with stability because of some pendulum effect?
Discussion BritPlan buildoff .. an oddity Applehoney Vintage & Old-Timer Designs 44 Jul 28, 2013 01:33 AM
Contest "Britplan" Build Off - 1st January 2013 to 30th June 2013 Now 22 Finished Models! Sundancer Vintage & Old-Timer Designs 257 Jul 16, 2013 12:23 PM
Discussion Cyril Shaw "Envoy" - Britplan Build Off January 2013 to June 2013 cpmcgraw Vintage & Old-Timer Designs 280 Jun 26, 2013 01:35 AM
Contest Auster-Britplan Build-Off Jan 2013- Jun 2013 mrdj Vintage & Old-Timer Designs 6 Apr 02, 2013 06:02 AM
Discussion Proposed "Britplan Build Off" 2013 Sundancer Vintage & Old-Timer Designs 96 Dec 31, 2012 07:56 PM
