Old Jan 01, 2013, 12:12 PM
Recce is offline
Find More Posts by Recce
Recce's Avatar
Estonia, Harju, Tallinn
Joined Aug 2012
Question
Stone wool insulation as wadding?
I started taking interest in model rocketry, because it seems like a good pastime during cold winter season. I guess new Year`s Eve gave the final push.
After looking for a cheap and easily available wadding, I got the idea of using stone wool. What are your thoughts about it? The material itself seems pretty dense at first, but it can be pulled apart to gain more volume. Or should it be used in disks instead?
Recce is offline Find More Posts by Recce
Old Jan 01, 2013, 01:53 PM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
An excellent cheap wadding is cellulose insulation, available at most hardware stores. It's biodegradable, and treated to prevent fire. And a lifetime supply costs about $10.
Remember not to pack it in too tight, or the chute won't deploy properly.
ttabbal is offline Find More Posts by ttabbal
Old Jan 02, 2013, 02:31 AM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
I haven't used stone wool but have use stainless pot scrubber, it works well but you need to design the rocket to be able to replace it as it will get clogged eventually. Other people use baffles to block hot particles and allow gasses to cool.
Are you planning on ejecting it out, or seeing if it can sort of act as a tied in piston, or securing it and seeing if it passes enough gas to work as a baffle? I don't think it is biodegradable so you might not want to eject it.
Frank
burkefj is offline Find More Posts by burkefj
Old Jan 03, 2013, 11:53 AM
wrightme is offline
Find More Posts by wrightme
Trons and Fumes
wrightme's Avatar
Fallon, NV
Joined Mar 2007
Check the baffle design of the Aerotech line for a possibility; it is similar to the potscrubber.
Their catalog at this link explains it. (catalog p13, pdf p14)
http://www.aerotech-rocketry.com/products.aspx
wrightme is offline Find More Posts by wrightme
Old Jan 04, 2013, 10:32 AM
Recce is offline
Recce's Avatar
Joined Aug 2012
Thank you for your opinions. Stone wool is out and cellulose is in.
Discussion Will this work as an insulator? Hajile Micro Helis 6 Oct 12, 2012 11:35 AM
Help! How Are Those Red Insulating Protectors (NitroPlanes) Installed Over 4mm Gold Conn? KenS999 Batteries and Chargers 8 May 30, 2012 02:19 PM
Is Fan-Fold the same material as the pink 2" insulation foam ? NetForce2K Foamies (Kits) 5 Jul 02, 2002 11:15 PM
