Old Dec 18, 2003, 12:53 AM
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
Will KAN 1050's REALLY hold up here?
I'm going to be putting a Mega 3 turn geared 2:1 in a plane of mine, 8x4.5 CAM folder...PCalc says it'll be pulling 20.5A, but I know how inaccurate it is since every time I've run the #'s thru it someone with motocalc says I'm WAY off. My question is will these cells be able to take what the ACTUAL amp draw is...thinkin about using 7 or 8 cells...any more than that wont fit. Or is my only option to try fitting a 3s2p TP2100 setup awkwardly into the plane? I know the KAN 1050's are rated up to 20 amps, but need to know if the #'s I got from pcalc are accuate so I dont fry the packs. Dont have or want to waste money. Thanks
Joe
Joe Ford is offline Find More Posts by Joe Ford
Old Dec 18, 2003, 06:56 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Will you need full power for the entire flight?
If so, KAN's won't do the job (with those numbers)..
..a
Old Dec 18, 2003, 09:46 AM
United Kingdom, England, Surrey
Joined Aug 2002
Kans will be fine, they will get hot but will be fine.
I use a /3 with 8 1050 cells on a 4.75x4.75 prop, must draw about 20-25amps. Most of the flight is spent at full throttle.
devmonkey is offline Find More Posts by devmonkey
Old Dec 18, 2003, 01:27 PM
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
Its actually a sailplane (I know wrong group, but you guys are whizzes when it comes to batts)...I'll only need full throttle for about 15-30 seconds before I'm at operational height. Will have well over 1:1 T2W so I'll DEF be vertical...anyone with motocalc wanna confirm the amp draw I got from pcalc, or does anyone know how accurate pcalc is? Appreciate the help guys
Joe
Old Dec 18, 2003, 01:38 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Vertical is a poor way to climb.
Yes, for LMR, you'll be fine.
..a
Old Dec 18, 2003, 06:11 PM
Malaysia
Joined Jun 2001
WHat about KR1100AAU? These are nicd and rated to handle 20A easily. Hard to get these cell though!
Magna is offline Find More Posts by Magna
Old Dec 18, 2003, 06:17 PM
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
Andy...cant climb any other way where I fly...too many darn trees!!!...have to get up there fast otherwise even if I clear the trees I'd be scared I'd lose the plane...trees are well over 75 yrs old...100+ ft tall and field is small and surrounded by them...all the nitro guys go vertical immediately after takeoff for same reason...all my planes I have the skill to fly em fast in a small area.
Magna...I'll have to look for those...havent seen em anywhere...if anyone knows a supplier of those batts let me know in case I cant find it. Thanks
Joe
Old Dec 18, 2003, 07:09 PM
small electrics r BIG FUN
Iowa
Joined Aug 2000
Joe
If it's that tight, do you come down verticaly too ?
Al P is offline Find More Posts by Al P
Old Dec 18, 2003, 07:44 PM
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
Thats what the spoilerons are for on mine lol...and all the nitro guys come down vertical, level off, and go full flaps. so yeah...lol...have to come down pretty much vertical...makes you concentrate on what youre doing though...if you run out of batt power, youre done for...no going around for 2nd pass...your only option is to do a little damage to the plane and get it down asap b4 you hit the trees...which I've done by the way when I was just learning
Old Dec 19, 2003, 01:01 AM
CheapBatteryPacks.com
Beaverton, OR
Joined Dec 2002
not sure on size and weight requirments but if you need a small compact cell the CP1300SCR and the HR-1700AUP will be much stronger at 20-30amps. but they are around the 1.2 oz range. But you could get away with 7 instead of the 8 KANs you were thinking of.
Or volt up if your speed controller can handle it. Say 10 KAN 650's. Maybe 9 or 10 KAN 1300/1400's. The extra voltage should be a huge help. If its just a matter of getting altitude quick then the voltage sag @ high amp draw on a high cell count pack should not matter. With 11 cells on my 3 turn brushless I pull 30amps on KAN 1400's. Then it settles to 27amps after about a minute. Sure the sag is there but watts are still strong for great climb.
Anyway just some thoughts.
frederm2002 is offline Find More Posts by frederm2002
Old Dec 19, 2003, 01:12 AM
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
Have a Phoenix 45 so the amps would be no problem...I'll look into that frederm...thanks for the recommendation BTW Thinking about going 3:1 instead just so I can swing a bigger prop at same amp draw.
Joe
Old Dec 19, 2003, 05:07 AM
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
Re: Will KAN 1050's REALLY hold up here?
Joe
Yes, would work. I pull 18A from my KAN950 full throttle ALL the time. 16/15/3 4,7x4,7 8cells in a microjet.
I must say the KANs are good, recharging at 3-5A emptying them in 3:30-4min and they still hold up! I´m impressed!
/Henke
henke is offline Find More Posts by henke
Old Dec 19, 2003, 12:00 PM
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
Then the only ? is how many cells do I want...7 or 8? Thinking 8 so I can use them in other applications. Appreciate the help guys.
Joe
Old Dec 19, 2003, 12:30 PM
henke's Avatar
Joined Jan 2001
Never ever leave a 8cell pack <Jester´s voice>
Old Dec 19, 2003, 01:00 PM
sokmeister's Avatar
Tigard, Oregon USA
Joined May 2003
i have 3 differents size battery configuration for my wattage f-22 with a mega 4-turn and apc 6X4.
They all take different spot in the plane for correct CG.
10-cell kan 950's
10-cell CBP 1400's
10-cell CBP 1800's
10-cell CP1300SCR's
the 950's work great cus its lighter.
I don't know what the amp draw is but the 950's can take it. i fluctuate between full/medium throtle when i fly so i guess its ok.
i cut into the air intake to so that air flows right over the batteries so its barely warm when i bring it down.
Thanks Mike at CBP for the batts.
Henke, I thought it was, "you never, ever, leave your wingman!"
"YeHaw! Jester Dead!"
Top Gun is an awsome movie
Sok
sokmeister is offline Find More Posts by sokmeister
False peaking kan 1050's with SuperNova Mikey-flies Batteries and Chargers 8 Aug 25, 2003 04:54 PM
9 Hecell 1100's or 8 KAN 1050's HIGHFLYER99 Batteries and Chargers 2 Aug 21, 2003 03:31 PM
HE 1000`s vs KAN 1050`s? kartman24 Batteries and Chargers 4 Jul 25, 2003 04:01 PM
Kan 1050's arrived sjslhill Batteries and Chargers 0 Jul 25, 2003 02:00 PM
OK Who's sellin the Kan 1050's? FX1SUB Batteries and Chargers 4 Jul 13, 2003 11:00 AM
