This thread is privately moderated by KamikazePilot, who may elect to delete unwanted replies.
Old Dec 31, 2012, 09:55 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
FrankenYak
What do you get when you have parts laying around and time? You get FrankenYak.
Specs are:
25" version of leadfeather's yak 55 1.9 epp
19 gram suppo motor and 10 amp esc. 8x4.3 tuff prop
OrangeRx R610 receiver.
5 gram servo for ailerons two 2.5 gram servos for elevator and rudder.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Jan 01, 2013, 06:45 PM
Twisted Do Nut!
Joined Dec 2010
Did a quick test flight on the FrankenYak. Wind was blowing about 14mph so I didn't do much other than see if it'd fly, which it did. Even with the 1.9 epp the wings did bow some, need to add some carbon. And color will be a must as well. Figured the 2.5 servos would be weak with this airframe but they work out pretty good.
Old Jan 04, 2013, 06:07 PM
Twisted Do Nut!
Joined Dec 2010
FrackenYak is once again on the bench going through a reduex. I didn't like the bowing of the wing so I added another spar a bit longer than the original. It helped quite a bit from first impressions. Now I just have to put it all back together. Thank god for welders and acetone.
Old Jan 19, 2013, 05:31 PM
Twisted Do Nut!
Joined Dec 2010
Finally got around to test flying the plane. Flys good though I lost the prop band, hence the clip is small.
FrankenYak test (0 min 54 sec)
