Old Dec 31, 2012, 06:02 PM
Sessholvlaru is online now
Find More Posts by Sessholvlaru
United States, NJ, Caldwell
Joined Apr 2007
Can you alter E-flite electric retract travel/stopping point?
Basically I have a situation where 90 degree retracts are needed but to clear my inlet ducting I'd need them to not retract all the way. Imagine a reverse 85 degree unit. Is that possible?
Sessholvlaru is online now Find More Posts by Sessholvlaru
Old Jan 01, 2013, 06:58 AM
Cougar429 is online now
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
Other makes offer both 90 degree or less sweep retracts. Not sure if Eflite does as well.
From all of mine, including Eflites up to the 60-120 units, I can state that it is possible to alter their sweep angle. There are microswitches built onto the control board that signal each end of the cycle. By adding a blob of glue you can tell the trunnion to stop earlier than normal. In my case, with a couple of sets of the larger Eflites I had to shave a touch off the switch buttons to allow them to go into full lock.
And that's where the problem can crop up since if the cycle stops early the trunnion will not be in full lock, either up, or in the worst case in the down position. This can allow them to come unlocked and move under loads, as well as increase wear and tear.
Cougar429 is online now Find More Posts by Cougar429
Old Feb 04, 2013, 01:35 AM
chuck75 is offline
Find More Posts by chuck75
Georgia
Joined Jun 2007
You might also consider bending the gear legs, or altering the gear mounts.
chuck75 is offline Find More Posts by chuck75
Wanted E-Flite EFLG110 10 to 15 - Size Tricycle Electric Retracts Timewarp Aircraft - General - Miscellaneous (FS/W) 0 Mar 30, 2012 03:46 AM
Sold New In Box Tri Set Of E-Flite 25 - 46 Tricycle Electric Retracts $155 Shipped FlyBoyTha1 Aircraft - General - Miscellaneous (FS/W) 1 Mar 20, 2012 12:03 PM
Sold New In Box Tri Set Of E-Flite 25 - 46 Tricycle Electric Retracts $155 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 4 Mar 20, 2012 12:01 PM
Sold E-Flite Electric Retracts SOLD themadhatter196 Aircraft - Electric - Airplanes (FS/W) 4 Mar 02, 2012 10:15 PM
Discussion Can you belly land E-Flite's Sea Fury with retracts installed? crash331 Electric Warbirds 16 Mar 31, 2009 03:43 PM
