Old Jan 04, 2013, 07:51 PM
PyroMan is offline
Find More Posts by PyroMan
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
Elevator??
Okay I need some help. . .
I'm starting to work on the horizontal stab when I realized that the plans do not have an elevator in the plans. I know this is because the original plans were just for rudder. . . . sooo, any tips on how to do this? How big should it be? How do I frame it up?
Nicholas
PyroMan is offline Find More Posts by PyroMan
Old Jan 04, 2013, 09:00 PM
Captain Dunsel is offline
Find More Posts by Captain Dunsel
United States, NJ, Southampton Township
Joined May 2005
Nicholas:
Based on an approximately 77 sq. inch horizontal stab and elevator (combined), my Mambo has two elevators for a total elevator area of 13 sq. inches (i.e., 64 sq. inches that isn't elevator and 13 that is). So, the elevators are just under 17% of the stab's total area.
Assuming your Mambo has the same relation of stab size to wing area (252 sq. versus 77 sq.), I'd shoot for the same 17%. Construction-wise, mine are sheet balsa, the same thickness as the rest of the stab, and joined with a square "U" of music wire.
CD
Captain Dunsel is offline Find More Posts by Captain Dunsel
Old Jan 04, 2013, 11:35 PM
Brner is offline
Find More Posts by Brner
AMA16634...Just Me
United States, OR, Salem
Joined Apr 2006
Elevator Detail
Maybe this can be of help to you....
Brner is offline Find More Posts by Brner
Old Jan 05, 2013, 11:05 AM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
That helps a whole lot Brner! Thanks!
Old Jan 05, 2013, 05:30 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
I'm about to cut out the fuse formers when I realized it calls for 3/32" "lite ply". I only have 3/32" birch ply on hand. Will this work okay?
Old Jan 05, 2013, 05:56 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
It will just be a bit heavier and harder to cut out, but also stronger.
Most of the weight goes when you cut the big hole out in the middle, so probably not a big deal.
(I think they show two F4 formers on the plans, one of them is actually F2 )
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 05, 2013, 09:41 PM
Brner is offline
AMA16634...Just Me
Joined Apr 2006
Good catch.....the one with the flat top is F2...
And PM is right about the ply. What you have will work fine, just a little heavier. What I use for lite ply is an old mahogany door skin....cheap old fart here.....lol
Old Jan 06, 2013, 01:42 AM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Thanks for the heads up, Pat. I caught another mix up while building the wing. They have the names of the wing ribs mixed up. W1 is really W2 and vice-versa.
I got quite a bit of work done today. I worked a lot on the plane because I think it will be my last day of vacation. Anyway, this morning I finished up the balsa construction of the wing by sheeting it, tapering the traileing edge, and sanding. It weighs in at 42.56 grams. . . Is this a good weight? I'm not worried about it, I'm just curious on how I did with trying to be careful about not getting too heavy.
Description: Name: ImageUploadedByTapatalk1357457424.445830.jpg
Description:
I also built the horizontal stab today. I made the center piece of the elevator solid like the plans suggested. I also cut out a 1" strip of 3/32" balsa for the elevator, but I don't have any hinges on hand so I was unable to completely finish it.
Description: Name: ImageUploadedByTapatalk1357457565.994441.jpg
Description:
This evening I cut out the fuse sides and glued on the nose doublers. I also began cutting out some of the formers. I'm pretty sure cutting the formers out of ply is the most laborious task yet. I have two down, and 4 or 5 left to do.
Description: Name: ImageUploadedByTapatalk1357457904.047216.jpg
Description:
Do I need to start planning out the placement of my servos and gather all my radio gear before I glue the plane together, or will I be able to put in the electronics after its all built? I know gluing up the model won't be for a while, but I'm just trying to get my thoughts together.
Old Jan 06, 2013, 11:43 AM
Vince77 is offline
Find More Posts by Vince77
Registered Misuser
Vince77's Avatar
United States, CA, Tehachapi
Joined Jan 2004
You'll be fine just leaving the top (or bottom) sheeting off until you have servos and pushrods in place. This design used a single solid control rod way back when... I used to use 1/16 music wire ends on 1/4 inch square balsa sticks for my pushrods, and 1/4 by 1/8 spruce rails to hold the servos...
Now, I'd recommend double sided foam tape to hold servos against the sides and carbon rods.
I prefer to frame up as much as possible so I can play with servo and battery location to avoid nose weight. Not as big a deal now with 9 gram servos and all... We used to be stuck using 30 gram standard servos and AA receiver packs...
Vince77 is offline Find More Posts by Vince77
Old Jan 07, 2013, 12:22 AM
kpriddle is offline
Find More Posts by kpriddle
Slow 'n Steady...Grease 'r In
kpriddle's Avatar
Maine
Joined Oct 2008
Nicholas,
I've been watching your build and have enjoyed the progress. I am building a Lanier Indicator right now that is very similar in many ways to the Minnie Mambo.
Anyway, here is some inspiration:
Little Traveler I Flight for St. Jude Children's Research Hospital, October 10th, 2009 (5 min 59 sec)
kpriddle is offline Find More Posts by kpriddle
Old Jan 07, 2013, 10:47 AM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
I think I started watching that a long time ago and never finished. That's a great video and a daring accomplishment.
All this time and I never knew You were kpriddle.
RknRusty is offline Find More Posts by RknRusty
Old Jan 08, 2013, 12:45 AM
kpriddle is offline
kpriddle's Avatar
Maine
Joined Oct 2008
Rusty,
I'm sorry. Actually, that's not me, but now that I look at that guy's channel, he seems like a pretty cool guy! Last night, I just saw his incredible flight and had to show Nicholas.
KP
Old Jan 08, 2013, 12:54 AM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
That's an awesome video and it's a great cause he's flying for! Thanks for posting!
If he could fly for 30 minutes on a 4oz tank, wouldn't it be cool to put like, I don't know, an 8oz tank in it and fly for an hour! :P it would be a pretty long time to fly, but it'd be kind of cool. Which gets me thinking . . . What size of fuel tank do y'all recommend? And where should I put it inside the plane? I don't have one of those fancy tanks that mount directly to the engine's back so I'll have to put something inside the plane.
Old Jan 08, 2013, 01:07 AM
kpriddle is offline
kpriddle's Avatar
Maine
Joined Oct 2008
I'm using a large 2oz. tank in my Indicator right now, and that will probably allow the SureStart to run for about 15 minutes. As you guessed, a one ounce tank should provide about half that time.
Make sure your tank is right up from behind your firewall. You will not want your fuel lines to be too long, or fuel pickup will be difficult for the engine (you want good suction).
KP
Old Jan 08, 2013, 01:12 AM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
KP
How should the tank be vertically in relation to the engine? Does it need to be higher than the fuel inlet on the engine so the fuel is gravity fed?
Discussion Sterling 1/2-A Minnie Mambo R/C nearing completion OkiThumper 1/2A Planes 25 Dec 12, 2012 07:50 PM
Discussion Minnie Mambo Video Tee Bee 1/2A Planes 6 Jun 08, 2012 10:07 AM
Discussion Minnie Mambo 252 Captain Dunsel Vintage & Old-Timer Designs 25 Jul 07, 2010 09:11 AM
Question Beginner questions from a first time scratchbuilder :) neu Foamies (Kits) 13 Aug 09, 2006 07:05 AM
