Old Jan 01, 2013, 03:40 PM
Bargle is offline
Find More Posts by Bargle
Bargle's Avatar
Joined Jan 2007
A power jig saw is handy if you've got access to one, but a coping saw will do OK. Just try to stay a hair outside the lines so you can sand to final fit.
Bargle is offline Find More Posts by Bargle
Old Jan 01, 2013, 05:19 PM
PyroMan is offline
Find More Posts by PyroMan
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
I'll probably stick with the coping saw because its only three little pieces. I do have a jig saw but to me it's more of a fiasco than just using a hand saw. I guess if I had a lot of pieces to cut out I'd set up my scroll saw. I don't have a workshop so setting up power tools is not always the easiest thing to do.
PyroMan is offline Find More Posts by PyroMan
Old Jan 01, 2013, 07:15 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
I only use a coping saw for plywood pieces. Put the wood in a vise and cut (as Bargle said) to the outside of the line and sand to the line. Easy and quick.
aeronca52 is offline Find More Posts by aeronca52
Old Jan 02, 2013, 03:42 AM
Vince77 is offline
Find More Posts by Vince77
Registered Misuser
Vince77's Avatar
United States, CA, Tehachapi
Joined Jan 2004
Originally Posted by PyroMan View Post
I didn't know the ink would come off with an iron. I will have to try that sometime. . . Even of just for fun
Just be sure to use a laser printer, and keep the ink towards the wood...
On the dihedral braces, you might want to see what other plywood pieces you'll need. I usually just pull out a coping saw, but once you get used to scratch building, sometimes it's quicker to set up the jigsaw and get all the plywood parts done at once.
Vince77 is offline Find More Posts by Vince77
Old Jan 03, 2013, 12:44 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
I got some work done past night on the first half of the wing.
This morning I was taking the wing off of the building board and realized the wood glue had glued to the wax paper. I am using Elmer's Carpenter's Wood Glue. I didn't think that it would stick to the wax paper, but I have spent about 20 minutes this morning picking off wax paper and doing a little sanding. Is this normal? If not, what I am I doing wrong? On the next wing I'm going to try to keep the glue off of the wax paper as best as possible.
In the pictures I have sanded a little, but I still have more to do. . .
Description: Name: ImageUploadedByTapatalk1357234997.301670.jpg
Description: Name: ImageUploadedByTapatalk1357235046.204460.jpg
Description: Name: ImageUploadedByTapatalk1357235059.822406.jpg
Description:
Old Jan 03, 2013, 02:01 PM
Vince77 is offline
Registered Misuser
Vince77's Avatar
Joined Jan 2004
That's pretty normal. Maybe try using the other side of the wax paper next time. The brand I buy works best with the shinny side up. Also, the pin holes tend to stick. You'll figure out how much glue to use as you go along.
Old Jan 03, 2013, 02:11 PM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
Attachment 5418066Attachment 5418067Attachment 5418071Attachment 5418072
glue on your work is usual and happens to everyone. And btw your wing looks very nice and tidy, keep it up and that thing will fly like a bird!
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old Jan 03, 2013, 03:53 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Okay, I'll try the other side of the paper. I'm using a syringe to apply the glue because it has a smaller tip than the bottle, but sometimes it shoots out real fast. I may try a different applicator bottle to keep the glue on the wax paper down to a minimum.
RC trainer Plane, thanks. I sure hope it flys well. I found your build log of your trainer plane and have been reading it. I still got a few more pages to read, but I'm looking forward to seeing the finished product.
Old Jan 03, 2013, 06:17 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Do y'all shape the leading edge before or after glueing up the wing?
I did not shape my leading edge first so I just got done rounding it with sandpaper. It wasn't too hard, but I'm debating whether to round the leading edge for the other half of the wing before I begin the glue-up.
Old Jan 04, 2013, 01:15 AM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Waiting for the glue to dry on the other half of the main wing. . .
Description:
Old Jan 04, 2013, 05:20 AM
Joined Apr 2012
i shape the leading edge when i've put on the sheeting for the plane. If you don't have sheeting make sure you put it on when you've finished all the ribs.
hope it helps
Old Jan 04, 2013, 06:29 AM
Vince77 is offline
Registered Misuser
Vince77's Avatar
Joined Jan 2004
I'd recommend shaping after sheeting for now. The structure is stronger and will hold up better. Also it's easier to match the curve of the sheeting than to guess the curve of the ribs.
Really depends on the design though. On most, the sheeting stops and is glued to the back of the leading edge. Then like RC Trainer plane mentioned, you sand the leading edge so it matches the sheeting.
Sometimes, I cut the leading edge beforehand so it matches the ribs, then glue the sheeting on top of both. This makes the glue joint bigger and stronger, but also puts it right on the leading edge. Glue joints are harder to sand and blend with the surrounding balsa.
Old Jan 04, 2013, 11:03 AM
Captain Dunsel is online now
Find More Posts by Captain Dunsel
United States, NJ, Southampton Township
Joined May 2005
I used plastic sandwich wrap, instead of waxed paper. It won't stick, even with CA (but my primary glue is Titebond aliphatic).
Here's my "Mambo 252". I used Glen Rock's plans for the Minnie Mambo, but enlarged it to 252 sq. inches, revised the innards (i.e., 1/32" sides, different spar construction, and so on), and installed a Skatty brushless motor and a 3S 1250 Lipo. Flying weight is 16 ounces. It is a blast to fly, especially doing flat spins (but start them up HIGH and end them high, 'cause it takes a while to stabilize from those flat spins!).
Covering is Fibafilm (from Balsa Products -- same stuff as Micafilm), trimmed with more Fibafilm and white CheapieKote.
Glow or Electric,it doesn't matter. The Mambo series is a blast to fly!
CD
Captain Dunsel is online now Find More Posts by Captain Dunsel
Old Jan 04, 2013, 07:22 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Well I've already shaped the leading edge a little, but I'll finish rounding it up after I get all the sheeting on like y'all suggested.
Captain Dunsel, that's really cool! I don't think I've seen a bigger version before. Thanks for posting.
Feel free everyone to post pictures of your Minnie mambo's. I enjoy seeing them
I've got the wing framed up and glued together.
Right now I have cut the sheeting for half of the wing and it's clamped on with the glue drying.
Old Jan 04, 2013, 07:24 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Forgot to attach pictures. . .
Description: Name: ImageUploadedByTapatalk1357345473.080754.jpg
Description:
Discussion Sterling 1/2-A Minnie Mambo R/C nearing completion OkiThumper 1/2A Planes 25 Dec 12, 2012 08:50 PM
Discussion Minnie Mambo Video Tee Bee 1/2A Planes 6 Jun 08, 2012 11:07 AM
Discussion Minnie Mambo 252 Captain Dunsel Vintage & Old-Timer Designs 25 Jul 07, 2010 10:11 AM
Question Beginner questions from a first time scratchbuilder :) neu Foamies (Kits) 13 Aug 09, 2006 08:05 AM
