Old Dec 31, 2012, 04:32 PM
PyroMan is offline
Find More Posts by PyroMan
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
Build Log
Minnie Mambo - First Scratchbuild, Many Questions
I got some balsa for Christmas and I bought a Cox .049 SureStart. I am now ready to begin my first balsa scratchbuild. I have printed off and taped together the plans for a Minnie Mambo. I plan to build it two channels - Rudder and Elevator. I may make it three channels if I get a throttle for my engine, but if that doesn't happen it will just be the two channels.
Being that I am new to building with balsa, I know I will have tons of questions.
My first question of many is: How do I cut out the pieces? For the wing's ribs, for example, do I print and cut out the rib template and glue it to the balsa or. . . .?
All help is appreciated.
Nicholas
Link to the plans: http://my.pclink.com/~dfritzke/Minni...o-GeneRock.pdf
PyroMan is offline Find More Posts by PyroMan
Old Dec 31, 2012, 04:50 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Another questions. . .
I weighed some of my 3/32" thick balsa and sorted them by weight. My lightest sheet is about 10 grams and my heavies sheet is about 21 grams. Should I use the heaviest sheet for the fuselage sides or for making the wing ribs or does it not really matter?
Old Dec 31, 2012, 05:28 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
The ribs are usually very light. In some of the kits with 1/16" ribs that I've built, you can barely touch them without damage.
RknRusty is offline Find More Posts by RknRusty
Old Dec 31, 2012, 05:44 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Okay, then I'll use the lightest balsa sheet I have for the wing ribs.
Old Dec 31, 2012, 06:35 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
For a constant chord wing I usually cut a template out of thin ply, then simply trace around that with the x-acto to cut out all the ribs.
To make the template glue the pattern onto the ply and cut it close.
Then sand it till it matches the pattern.
For the root ribs I would just cut them out the same, then shift the template down 1/16 to cut the back part where the sheeting goes.
If you don't have thin ply then you could use the hardest balsa you have and harden the edges with CA. You will have to be more careful when you use it to guide the knife.
And for the x-acto use the #11 blades. A cutting mat on the bench will keep the tip from going dull.
Try to match the weight of the ribs on both sides of the wing, and also the two fuselage sides should be of similar weight and stiffness.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 31, 2012, 06:44 PM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
good luck pyro man keep us posted
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old Dec 31, 2012, 06:55 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Pat, I like your idea much better than the way I did it. I created a page with twelve of the rib templates. I cut 'em out and glued them to the balsa. I then used a straight edge, a French curve, and an Xacto blade to cut them out. They are all very close to being the exact same. I will hold them together and sand them at the same time to get them all to the exact same size and shape.
I will cut the hole where the spar will be after I sand them because I don't want them to be weak when I sand.
Description: Name: ImageUploadedByTapatalk1357001698.557175.jpg
Description:
Old Dec 31, 2012, 07:56 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Here are a few things to get you going...
http://www.rcgroups.com/forums/showt...ht=minni+mambo
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Dec 31, 2012, 10:19 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Thanks for the links Rusty-Gunn. I'll look at those threads later tonight.
So far I've got all the wing ribs cut and ready to go. I also cut the wing spar. I was reading the plans and at the very beginning it says for maximum strength, coat each part with a light coat of cement. and let it dry before assembly. Is this necessary? I want the plane to be as strong as possible for my less than great 'landings'. I am using Elmer's wood glue so should I dilute the glue with water and brush it onto each part?
Old Dec 31, 2012, 10:43 PM
pmackenzie's Avatar
Joined Dec 2002
I would not do it. Just extra weight.
Build to fly, not to crash.
They are talking about solvent based glue like Ambroid, not wood glue like you are using.
Old Dec 31, 2012, 11:55 PM
BillM is offline
Find More Posts by BillM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
What you are describing is double gluing. We did that when model airplane glue smelled strange--30 plus years ago. Not really necessary with modern adhesives.
Wing ribs are easy to do. Make a template out of thin plywood--1/16 is good--1/8 better. put a couple of thumb tacks through the template at the front and rear. Push tthe tacks exposed points into your rib material and trace around the template as many times as you need to make a set of ribs.
Tapered wings--another story.
BM
BillM is offline Find More Posts by BillM
Old Jan 01, 2013, 02:13 AM
Vince77 is offline
Find More Posts by Vince77
Registered Misuser
Vince77's Avatar
United States, CA, Tehachapi
Joined Jan 2004
Congrat's Nicholas, you picked a pretty rewarding and forgiving hobby. There are plenty of ways to do most things, as you just found out. I too make a sheet of rib copies, but then I print them on a laser jet and iron the ink onto the balsa to transfer the pattern. Not necessarily a better way, but worked better for me.
Measure twice, cut once and when in doubt, ask. One of us will be lurking and ready to give you a tip.
Cheers,
Vince L.
Vince77 is offline Find More Posts by Vince77
Old Jan 01, 2013, 02:36 AM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
Cheers,
Vince L.
I didn't know the ink would come off with an iron. I will have to try that sometime. . . Even of just for fun
Thanks, will do.
Old Jan 01, 2013, 01:47 PM
PyroMan is offline
PyroMan's Avatar
Joined Mar 2011
So I need to cut out the pieces of wood that hold the two halves of the wing together and they also set the dihedral of the wing. They are numbers W4, W5, and W6 and they are made out of 1/8" plywood.
How do ya'll cut out plywood pieces? I feel like it would take forever to cut through 1/8" plywood with an Xacto blade. I can use a coping saw, but I didn't know if you guys had some better methods.
Old Jan 01, 2013, 01:51 PM
Joined Apr 2012
i think coping saw is you only bet unless you take it to a kind wood cutting store that will cut it for you.
Discussion Sterling 1/2-A Minnie Mambo R/C nearing completion OkiThumper 1/2A Planes 25 Dec 12, 2012 07:50 PM
Discussion Minnie Mambo Video Tee Bee 1/2A Planes 6 Jun 08, 2012 10:07 AM
Discussion Minnie Mambo 252 Captain Dunsel Vintage & Old-Timer Designs 25 Jul 07, 2010 09:11 AM
Question Beginner questions from a first time scratchbuilder :) neu Foamies (Kits) 13 Aug 09, 2006 07:05 AM
