Old Jan 09, 2013, 10:49 AM
egras14 is offline
Find More Posts by egras14
Pompano Hill Flyer
egras14's Avatar
United States, FL, Fort Lauderdale
Joined Apr 2003
What is the difference between that and Min-Wax WPU?
egras14 is offline Find More Posts by egras14
Old Jan 09, 2013, 02:00 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
It is water based like poly. Having watched the video, only diff I see is they says the first coats dry in about 30 min. From my experience, first coat of poly takes longer than that. However, successive coats of poly dry faster. Don't see a whole lot of diff. I'm like Ace, probably just stick to messy epoxy and glass although I will throw in the occasional poly/glass bird.
I do most of my building/engineering/designing on the fly by the seat of my pants. Hence the mistakes. Been working on getting that area on the aft end of the wing close to the plastic model. Has taken me forever it seems but is getting close. I sometimes have a real problem "seeing" what I want. Anyway, here's what I'm doing now so I can skin this section.
Oooops... forgot the pics.
J
J Morgan is offline Find More Posts by J Morgan
Old Jan 09, 2013, 02:41 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Ace, what is the source? I used this in the past and liked the results but found it quite expensive.
Highfly! is offline Find More Posts by Highfly!
Old Jan 09, 2013, 03:51 PM
Hans-Joachim is offline
Find More Posts by Hans-Joachim
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
BG J,
it looks like you start to do fantastic scale details!!
HJ
Hans-Joachim is offline Find More Posts by Hans-Joachim
Old Jan 09, 2013, 04:07 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks Hans
I'm trying. Finding mistakes in my formers as I go( I had some in the wrong spots... duh) and fixing them slows me down some. Here's the skinning from this afternoon.
And you know there will be a whole lot of sanding after the skins are on.
J
Old Jan 09, 2013, 07:06 PM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Here is the direct link. I made a mistake on quantity. It was two quarts which is part A +B so even a better deal. One thing to note. It is happier in a more humid environment as it is moisture/air dried. I'm in the desert so it took longer to harden. When I use it again I will use humidifier in my shop.
http://www.industrialpolymers.com/pr...st/styrospray/
acesimmer is offline Find More Posts by acesimmer
Old Jan 09, 2013, 07:33 PM
Highfly! is offline
Highfly!'s Avatar
Joined May 2007
Ace, thanks! I used it also successfully on balsa after spackling the surface. Works great!
Old Jan 09, 2013, 09:51 PM
W. X. Davis is offline
Find More Posts by W. X. Davis
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
J , have you decided if your gonna separate the fuselage ?
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Old Jan 10, 2013, 05:08 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Woody,
I had planned on using the same system of tubes on the fuse but after checking the trailer I decided to NOT separate it. Makes things easier and lighter. I've already glued the two sections together. Forgot to mention that.
J
Old Jan 10, 2013, 01:22 PM
Living a Dream
Joined Oct 2003
.. we'll get her and the other planes inside your trailer and truck. Suitcases and luggage can stay out. HJ
Old Jan 10, 2013, 01:43 PM
Pinky_d_brain is offline
Find More Posts by Pinky_d_brain
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
she's looking good J
I would be moding that trailer a bit by adding a small deck to the front of it. Some 2x6, ply & U-bolts would probably do it.
Pinky_d_brain is offline Find More Posts by Pinky_d_brain
Old Jan 10, 2013, 02:05 PM
Living a Dream
Joined Oct 2003
Everything has it's place for a long road trip.
Old Jan 10, 2013, 04:04 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Hans,
All that foam is almost gone! Used up. Need to get some more.
Pinky,
I'm planning on taking the trailer over to the local welding shop and having them build a cage on the front.
Not much going on here except for more skinning. Finding I screwed up on the front formers and am changing them out as I get to them.
I would like to get this top skinned so I can make the canopy plug. The plug will be sent to Sparky, no way I'm going to fight forming it. It is over 16" long and that's just too much for my equipment.
A few pics of progress.
J
Old Jan 10, 2013, 05:02 PM
Living a Dream
Joined Oct 2003
BG J, she's a big baby! OK, suitcases and luggage have to stay inside to get the foam.
HJ
Old Jan 10, 2013, 08:44 PM
Joined May 2004
Hey John, is this thing gonna have a full cockpit ?
Woody
Sold SAVE BIG!!!! SWEET DEAL on NIB SIG 1/4 Scale J-3 CUB!!!! UNTOUCHED!!! Plasmajoe Aircraft - Fuel - Airplanes (FS/W) 2 Jun 22, 2012 08:35 PM
Discussion Tamjets 1/8th scale F-16 cableguy351 Electric Ducted Fan Jet Talk 8 May 20, 2012 09:16 PM
Discussion Replacement Canopy for Tamjets 1/8th Scale F-16 Pepperpete Electric Ducted Fan Jet Talk 6 Apr 24, 2012 07:14 PM
Sold AMT F-16 cockpit kit 1/12 scale nero1156 Aircraft - Fuel - Jets (FS/W) 0 Apr 21, 2012 04:55 PM
Discussion New F-16 build-This should be on H-J's F-16 Thread electriceye Pusher Prop Jet Models 2 Aug 28, 2006 02:45 PM
