Old Jan 02, 2013, 09:25 PM
Aircraft Designer Guy
MIT KID's Avatar
Melrose, MA
Joined Jul 2005
Sweet! Love your big jets. Should be no problem to hand launch. I did some tests with my Eurofighter before starting to paint it, and we got it up to around 17 pounds (from 13) with no change in the ease of launch.
-Adam
MIT KID is offline Find More Posts by MIT KID
Old Jan 02, 2013, 09:55 PM
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
Hans, I must be too buried into the build cuz I didn't even notice the sign. Pretty kewl.
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Old Jan 02, 2013, 11:21 PM
John 3:16 Still Applies
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Looking forward to watching this one progress...
What paint scheme(s) are you looking at Hans?
Sammy70 is offline Find More Posts by Sammy70
Old Jan 02, 2013, 11:23 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
andy are you coming to seff this year again?
what are the dates again? i need to set this in stone...
maybe we can fly out together andy, from vegas
corsair nut is offline Find More Posts by corsair nut
Old Jan 02, 2013, 11:26 PM
Joined May 2004
Nut - SEFF dates April 22 - 28
Wanna see you there. Gonna have a F4U to fly.
Woody
Old Jan 03, 2013, 09:25 AM
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
I will love this baby in every paint scheme.
But blond upps I mean desert camo would be sweet.
HJ
Hans-Joachim is offline Find More Posts by Hans-Joachim
Old Jan 03, 2013, 11:28 AM
unclecrash's Avatar
white lake michigan
Gotta love a desert camo or my next choice would be a winter camo they do up in Alaska. I will be doing my CBM in one or the other. Build is looking good John as always.
unclecrash is offline Find More Posts by unclecrash
Old Jan 03, 2013, 01:05 PM
Capt. Z
falcon5's Avatar
Tonopah, Nevada
Joined Dec 2004
The F-16 is looking great John.
I prabbaly won't make it to SEFF this year wingman...
falcon5 is offline Find More Posts by falcon5
Old Jan 03, 2013, 03:38 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
MIT KID,
Yeah, weight won't be a problem. I just want it light so I don't have to go massive with the power and run a big a$$ prop on the back. I have enough scars on my right hand some small ones.
Thanks Andy,
But there sure isn't much to look at yet.
STILL waiting for my tubes.I called and they think they have been delayed because of Xmas traffic. Don't want to go to far on the rear section until they get here and I can set them.
Meanwhile, I've started skinning some. I put more formers in some spots later. Pics show the glue strips to make skinning easier. Once the skins are on I cut the bulkheads out, more interior of the "crutch" will be removed later.
It's going to take awhile to skin this monster.
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: F7F Tigercat from Palmer Plans
Old Jan 03, 2013, 03:48 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
As far as color schemes Hans, is this what you mean?
And a couple of pics of my 1/10th scale pusher at SEFF 2008. Can't remember who photoshopped the pic. Pretty cool trick though.
J
Old Jan 03, 2013, 04:54 PM
acesimmer's Avatar
Joined Oct 2011
What glue do you use for the foam?
acesimmer is offline Find More Posts by acesimmer
Old Jan 03, 2013, 05:15 PM
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
looks like weight Gorilla Glue, J uses it a lot depending on the application. For something like this it works well for filling the gaps up. This is handy because your cuts don't have to be so perfect to get a good hold and it still sands well if needed.
J do you do anything to bend the foam like that I have never tried it as the stuff I get is to thick to bend, most common is 2'x8' 1.5" thick sheets, I have seen up to 6" thick.
Pinky_d_brain is offline Find More Posts by Pinky_d_brain
Old Jan 03, 2013, 06:02 PM
Living a Dream
Joined Oct 2003
Yes J, that would be great!! Here is a closer look to ne.
HJ
Old Jan 03, 2013, 08:31 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Yep, Pinky has it right Ace. I use a lot of white Gorilla glue. I can glue a panel, tape it down and it has set up enough in less than an hour to remove the masking. It's great for this application. Also easy to slice off or dig out any excess prior to sanding. CA glue isn't so easy IMHO. I only use CA when I have to.
Pinky,
I use a piece of plastic pipe to roll the foam against my belly to get the curl needed. GGRN taught me that trick quite a few years ago. But fanfold is 1/4" thick and just works splendidly in these type builds. Again, I think it is much easier to bend than depron, no heat or fancy things needed for it. Just a nice big belly.
J
Old Jan 04, 2013, 01:57 AM
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
Hi John !
nice that you started a new thread, each time is a source of wonderful tips&tricks from you , thanks !
Don't know if you've already explained, but how do you cut the panels in the correct shape ? It looks like when you glue the panels, they are already nice fitted on the former shape, you develop the shape or you put a large panel and then cut away the excess ?
I ask this because one time i've tried to cut a flat developed shape for a panel that has compound curves and it was a failure, never fitted right
thanks
Dave
FlyDave is offline Find More Posts by FlyDave
Sold SAVE BIG!!!! SWEET DEAL on NIB SIG 1/4 Scale J-3 CUB!!!! UNTOUCHED!!! Plasmajoe Aircraft - Fuel - Airplanes (FS/W) 2 Jun 22, 2012 08:35 PM
Discussion Tamjets 1/8th scale F-16 cableguy351 Electric Ducted Fan Jet Talk 8 May 20, 2012 09:16 PM
Discussion Replacement Canopy for Tamjets 1/8th Scale F-16 Pepperpete Electric Ducted Fan Jet Talk 6 Apr 24, 2012 07:14 PM
Sold AMT F-16 cockpit kit 1/12 scale nero1156 Aircraft - Fuel - Jets (FS/W) 0 Apr 21, 2012 04:55 PM
Discussion New F-16 build-This should be on H-J's F-16 Thread electriceye Pusher Prop Jet Models 2 Aug 28, 2006 02:45 PM
