Old Jan 28, 2013, 01:24 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
oh nice! looking great! take good care of er hans!
corsair nut is online now Find More Posts by corsair nut
Old Jan 28, 2013, 02:54 AM
Hans-Joachim is offline
Find More Posts by Hans-Joachim
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
Originally Posted by corsair nut View Post
oh nice! looking great! take good care of her hans!
Brent, .. she is too good to be true ..
John, you are the master!!
HJ
Hans-Joachim is offline Find More Posts by Hans-Joachim
Old Jan 28, 2013, 04:40 AM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Looking good, John what are the top hatches for? to pin the wings on or possibly access the taileron servo's.
unclecrash is offline Find More Posts by unclecrash
Old Jan 28, 2013, 05:52 AM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks guys
I'm really liking the look so far.
The hatches on each side are for the wing hold on screws and to access the rec. Those aren't tailerons, they are flying stabs controlled by a single servo which is already set up. If I need to access it I will simply cut a hatch at that time.
Have to get the suburban serviced today and get license for the new pickup. That means some shopping for my better half will be involved so I don't expect to get much done today.
When I get back on it I will need to address the bottom. Still a bunch of cosmetic work down there before glassing.
I think it's about time to weigh it all too.
J
J Morgan is offline Find More Posts by J Morgan
Old Jan 28, 2013, 06:28 AM
unclecrash's Avatar
white lake michigan
My bad I was looking at your elevator setup the other day I don't know why I called them Taileron's. I like you setup seems quick and easy and Im all for the pin through the whole assembly to keep it solid and from twisting. I saw a write up in a magazine a couple years back, where the guy was using nylon toilet bolts to attach the wings. I believe he cut the heads off the bolts and glued the stud into the wing then he slide them through and tightened up the nut,drilled a hole through the nut and stud and put a pin through to keep them from backing out. I might do something like that on my YF 23 if I can find room to put them if not I will use tabs and a couple small screws.
Old Jan 28, 2013, 06:53 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
John, Hope you hit the magic 4lb. " I think it's about time to weigh it all, too."
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 28, 2013, 07:04 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks Mark
Not sure I will hit that magic 4 lbs but it should be close. I'm thinking more like 5 lbs just airframe weight. The fuse is 2 lbs now with more work to do. The wings are around 5 oz each sans ailerons. Stabs are about 3 oz each. Vertical and base I haven't weighed. I think I'll go out in the shop and weigh it all right now, stay tuned.
J
Old Jan 28, 2013, 08:00 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Here is where we are on weight so far.
Fuse 33.5 oz
Wing(L) 5.6
Wing (R) 5.8
Ailerons(2) 2.3
Stabs(2) 5.2
Fin/Base 6.5
Nose cone 2.7
Total 61.6 oz= 3.8 lb
To finish airframe:
Glass bottom
Fill weave on fuse
Motor mount
Exhaust housing
Lower rear fins
Full cockpit
Pilot
Canopy 0.040 plastic
So you can see I really won't make 4 lbs, will be difficult to make 5 lbs but should be close.
Then to make it flyable:
3026-890KV Scorpion motor/prop/wire/esc
Battery 4s-5000 (18oz)
Two 9 g servos for ailerons
Rec
And finally paint. I had hoped to make to make AUW when done at 8 lbs and I really think that is doable. Actually should be closer to 7 lbs if I'm successful.
As far as hand launch, it should not be a problem with the help of another individual other than the pilot. Once comfortable with it, I'm sure Hans will be able to launch himself. Hans is a very good pilot. This plane will exactly fit the flight envelope that he enjoys, low level and slow passes. He never worries about being 3 mistakes high like I do.( I still tend to make 4 mistakes!).
For maiden I may throw a tow hook on it just to be safe. It all depends on how it feels to me when I get it ready and power up in my hands. My 141% F-16 hand launches easily with 500 watts and a strong throw and I just can't see this one being any harder.
Also, on the color scheme. I discussed it with Hans. I'm just not feeling the brown desert camo scheme. I feel better going with the standard two tone gray. Hans said that was fine so that is what I'm going with. It just looks more like a F-16 to me.
J
Old Jan 28, 2013, 08:04 AM
Willsonman is offline
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
I agree on the CS. The gray seems more fitting.
Willsonman is offline Find More Posts by Willsonman
Old Jan 28, 2013, 08:38 AM
tehachapi, CA
Joined Jan 2006
a f-16 at this size, even at 8 lbs will be a floater!
Old Jan 28, 2013, 11:21 AM
ZRX212 is offline
Find More Posts by ZRX212
ZRX212's Avatar
United States, FL, Christmas
Joined May 2010
I like this....
ZRX212 is offline Find More Posts by ZRX212
Old Jan 28, 2013, 12:12 PM
thedeuce is offline
Find More Posts by thedeuce
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Looking great john
I was curious on the prop you are going to use with this setup?
Cheers
thedeuce is offline Find More Posts by thedeuce
Old Jan 28, 2013, 05:37 PM
Pinky_d_brain is offline
Find More Posts by Pinky_d_brain
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
Blue Gray would be good to but if not some nice pics for some added detail and for your line work. As always fine work J
Pinky_d_brain is offline Find More Posts by Pinky_d_brain
Old Jan 28, 2013, 09:05 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I'm with you on the CS Willsonman
Right Nut, it will be a big floater.
deuce,
As I remember a 11x8 APC gives about 900 watts on 4s.
Pinky,
Never been a big fan of the aggressor scheme. Don't know why, just doesn't trip my trigger.
J
Old Jan 29, 2013, 02:04 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Navy, Navy, Navy....
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Sold SAVE BIG!!!! SWEET DEAL on NIB SIG 1/4 Scale J-3 CUB!!!! UNTOUCHED!!! Plasmajoe Aircraft - Fuel - Airplanes (FS/W) 2 Jun 22, 2012 08:35 PM
Discussion Tamjets 1/8th scale F-16 cableguy351 Electric Ducted Fan Jet Talk 8 May 20, 2012 09:16 PM
Discussion Replacement Canopy for Tamjets 1/8th Scale F-16 Pepperpete Electric Ducted Fan Jet Talk 6 Apr 24, 2012 07:14 PM
Sold AMT F-16 cockpit kit 1/12 scale nero1156 Aircraft - Fuel - Jets (FS/W) 0 Apr 21, 2012 04:55 PM
Discussion New F-16 build-This should be on H-J's F-16 Thread electriceye Pusher Prop Jet Models 2 Aug 28, 2006 02:45 PM
