Old Jan 23, 2013, 07:36 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Still working or getting the top of the fuse ready for glass. Had to move to the rear and finish it. Hard to see from the pic but I glassed that "cross" in the rear with 3 oz glass/epoxy. This will stiffen it for the motor mount. I'll sand the fanfold down flush to the balsa circle. I also need to address the openings in each side, pics show them.
Finally, I got a new toy. Have needed it for a long time, way overdo. My buddy Walt in FL turned me on to it. Ordered from Amazon.com Monday morning, 61 lbs, remote controlled, with FREE shipping. It came in at 2:30PM TUESDAY!!!!!!!!!!!! What a great company.
Checked it out, seems to work very well and I'm sure it will help this toxic foam dust factory I call a shop. Just need to decide where to hang it now.
Back to work.
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: F7F Tigercat from Palmer Plans
Old Jan 23, 2013, 09:34 AM
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi John,
I'm very impressed by your new toy.
Never seen so much clear space on one of your workbenches before....
Dan Eaton
eatond is offline Find More Posts by eatond
Old Jan 23, 2013, 01:22 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Originally Posted by eatond View Post
Hi John,
Dan Eaton
Man, you've got that right. Took ten minutes to clear a place.
J
Old Jan 23, 2013, 04:03 PM
DESIGNOSAUR
DesignGeek's Avatar
United States, MI, Wixom
Joined Jun 2002
Looks awesome J... Love watching the Big16 take shape---- Back to the off topic banter: I have the EcoBoosted Flex as well. Even considered entering it into the Hillman MI 1/8th mile street drags last summer....... Pulls like crazy.
DesignGeek is offline Find More Posts by DesignGeek
Old Jan 23, 2013, 04:20 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I'm old school, 5.4L
I will say this 150 Lariat Super Crew Cab is an awesome machine. They have shortened the bed 1 inch and made the back setting area HUGE. The back seats fold up vertical and it looks like a cargo van back there! Lots of little neat gadgets and handy items have been installed. I really like it. But of course my old one was 2007.
Only bad thing is the AC-119K middle section fit in the old truck bed with about 1" clearance. I need to check and see if it will fit this truck. May have to make some ramps to get the middle section inclined to fit.
Enough truck stuff ........
I got the open areas in the rear covered and finally started glassing. Wings, ailerons, fin base, fin, stabs. Hope to get the fuse top glassed tomorrow.
J
Old Jan 23, 2013, 09:16 PM
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Glad you got your new toy John, I'm sure you'll really like it! Planes is comin along, what weight glass are you using on this one? W
Waltjg is offline Find More Posts by Waltjg
Old Jan 23, 2013, 10:01 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
that new toy will be plugged up with foam in short order
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jan 24, 2013, 05:31 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks for the help in selecting it Walt.
You've got that right Roger!
J
Old Jan 24, 2013, 07:24 AM
United States, GA, Cartersville
Joined Jun 2011
Hatches
John,
I seem to have trouble figuring out how to make hatches for access to the electronix and batteries. They never look right. could you do a little toutorial when you get ready to making your hatches for the BIG 16. I am sure it will help me.
hersch54 is offline Find More Posts by hersch54
Old Jan 24, 2013, 04:50 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Sure Hersch. Not sure mine is the best way but it works for me. I'll need a hatch on each side for the wing hold down screws and rec.
And I included a pic of my power supply for the hot wire bows. I built this off plans in the foamie section. Pretty easy build and it has been working great for 10 years or more. The thread it was in should either be in Foamies Scratchbuilt or Foamie Kits and it's an old one. After the big RC Groups meltdown years ago some of the threads got scattered in the wrong forums. I know some of my scratchbuilds were put back in Foamie Kits and I got I don't know how many PMs asking which kit I built them from.
Made a place under the other work bench for the air cleaner. I do a lot of sanding right here so I'll see how it does.
I glassed the other sides of the wings, ailerons, vertical fin, fin base, and the stabs. Trimmed them out and they are ready for sanding and filler coat,
Worked on getting the top fuse ready for glass and finally got it done.
But before that I decided it was time to shape the nose cone plug. I learned a long time ago with these pushers that if you leave the nose as foam, then you'll get real good at repairing them. This one will be glass of course.
Pics pretty well show the progress.
J
J
Old Jan 24, 2013, 09:35 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Hersch,
You have help coming in your PM box and here is another schematic that is close to mine. Simple and cheap to set up.
http://www.charlesriverrc.org/articl...amcutterps.htm
J
Old Jan 24, 2013, 09:41 PM
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Hummmmm get that baby out and hang it from the Celing......
Old Jan 24, 2013, 09:43 PM
“Do it Right The First Time!”
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Originally Posted by J Morgan View Post
Hersch,
J
Same schematic I used. Anyone can build that PS.
CoolerByTheLake is online now Find More Posts by CoolerByTheLake
Old Jan 25, 2013, 04:32 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Walt,
Using 3/4 oz glass on it. Making weight a factor on this one.
I'm going to try the cleaner under the bench first and then may hang it later. Want it close to where I am working , Figure it will do the best job there. Plus easy to change filters. I think that outside filter is going to get a workout.
I know my PS for the hot wire bow doesn't look like much but it's fully adjustable and absolutely trouble free.
J
Old Jan 25, 2013, 07:43 AM
Joined Jun 2011
Thanks for the PS info. I had stopped by RS to pick up some parts and I have it almost ready to work. I got a switch with a red and green light but looking at the schematic I was noit sure how to wire it. but from the diagram you provided I think I can figure it out.
Thanks.
Sold SAVE BIG!!!! SWEET DEAL on NIB SIG 1/4 Scale J-3 CUB!!!! UNTOUCHED!!! Plasmajoe Aircraft - Fuel - Airplanes (FS/W) 2 Jun 22, 2012 08:35 PM
Discussion Tamjets 1/8th scale F-16 cableguy351 Electric Ducted Fan Jet Talk 8 May 20, 2012 09:16 PM
Discussion Replacement Canopy for Tamjets 1/8th Scale F-16 Pepperpete Electric Ducted Fan Jet Talk 6 Apr 24, 2012 07:14 PM
Sold AMT F-16 cockpit kit 1/12 scale nero1156 Aircraft - Fuel - Jets (FS/W) 0 Apr 21, 2012 04:55 PM
Discussion New F-16 build-This should be on H-J's F-16 Thread electriceye Pusher Prop Jet Models 2 Aug 28, 2006 02:45 PM
