Old Jan 18, 2013, 02:30 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
TN we really miss not seeing you ...hope you can get to vegas again some day .bring that bald eagel you can serch the swamp for planes that have gone in there.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jan 18, 2013, 08:47 AM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
That's right Thomas, you need to make Vegas again!
Pulled the vertical out this morning and trimmed it. Came out beautiful and it is much more scale. It gave me a weight penalty of 1 oz over the Depron one but I can live with that. Have the LE glued on and will shape it later.
Canopy sanded and still some work to finish it.
J
J Morgan is offline Find More Posts by J Morgan
Old Jan 18, 2013, 04:11 PM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
J I'm trying to pull a few light lens using soda bottles and when I heat up the plastic it just shrinks and pulls up tight in my frame but never sags I'm using a heat lamp and have tried a heat gun do I need more heat to get it to relax?
any help would be appreciated,
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Jan 18, 2013, 04:41 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Bruce,
If you use the plunge method it should work. I use a piece of lite ply and make a cut out just a bit larger than the plug. Fasten a piece of plastic over the ply hole. Put the plug on a stick, heat the plastic and then shove the plug up through the hole in the ply. Let it cool before you release the pressure on the plug. If that doesn't work then I would say try diff plastic.
Mostly grunt work today. I contacted Sparky and discussed the plug. He suggested I make a base for it( the plug is not flat) and sand it flat. That will allow the plastic to make a uniform pull. Sparky is The Man! So I did. Hope to have it ready to ship out on Monday.
Then I started some cosmetic work on the fuse. Digging out glue and spackling.
J
Old Jan 18, 2013, 05:53 PM
Baltimore MD USA
Joined Jan 2011
Alright J thanks I think I'm not getting it hot enough I 'll break out my toaster oven
and crank it to 250 degrees and see what happens.
Your project looks great by the way,
Bruce
Old Jan 18, 2013, 08:21 PM
W. X. Davis is offline
Find More Posts by W. X. Davis
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
J, will the vertical fin be removable ??
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Old Jan 18, 2013, 08:25 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Woody
Yes it will Woody
J
Old Jan 19, 2013, 06:07 AM
Hans-Joachim is offline
Find More Posts by Hans-Joachim
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
BG J, I 'll need to train on a similar size F-16. .. ..wonderful
Thomas, we want to have you with us in Vegas after all these years.
HJ
Hans-Joachim is offline Find More Posts by Hans-Joachim
Old Jan 19, 2013, 06:52 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Looking good John. Is there nothing YOU can't build out of foam?
Gives me hope on my next build!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 19, 2013, 07:09 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I have no doubt you will fly this thing with no problems Hans, You are just too good of a pilot to have problems.
Thanks Cooler! Hope you are feeling better and progressing well.
J
Old Jan 19, 2013, 04:29 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Well, Spring Hill TN had a swap meet this morning so I stopped by. Pretty typical, but I did find a plane I've wanted for awhile to play around in my grass field with.
Would have preferred a little larger one but..... this one will do. A 72" ws Telemaster 40. It's a slimer build but not for long. May change it to a tail dragger, haven't decided yet. It is well built, stout, and has the aileron servos installed. Had a $60 price tag, he said make me an offer and I threw out $40. SOLD!
Got back and into the grunt work. Working on the fuse top, all cosmetic stuff. Digging out GG and replacing with spackle. I used 1/32" ply strips embedded in the LE strake section and the vertical fin base. This gives me a nice hard edge to sand to. Tomorrow, more of the same.
And still working on the canopy plug.
J
Old Jan 19, 2013, 05:01 PM
Willsonman is online now
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
What a steal J! Have fun with that!
Willsonman is online now Find More Posts by Willsonman
Old Jan 19, 2013, 05:27 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
Looking great!
ATIS is offline Find More Posts by ATIS
Old Jan 19, 2013, 07:00 PM
TPfingston is online now
Find More Posts by TPfingston
Retired and Lovin' it!
TPfingston's Avatar
United States, KY, Sturgis
Joined Jul 2007
You should be ashamed of yourself, J. You stole that Telemaster!
Tony
TPfingston is online now Find More Posts by TPfingston
Old Jan 19, 2013, 09:00 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Yeah, I do sort of feel bad. The guy probably paid around $90 for the kit, had to build it, and then cover with Monocote. But then he said yes, could have said no. I'm sure he has the same problem I have, running out of room.
J
Sold SAVE BIG!!!! SWEET DEAL on NIB SIG 1/4 Scale J-3 CUB!!!! UNTOUCHED!!! Plasmajoe Aircraft - Fuel - Airplanes (FS/W) 2 Jun 22, 2012 08:35 PM
Discussion Tamjets 1/8th scale F-16 cableguy351 Electric Ducted Fan Jet Talk 8 May 20, 2012 09:16 PM
Discussion Replacement Canopy for Tamjets 1/8th Scale F-16 Pepperpete Electric Ducted Fan Jet Talk 6 Apr 24, 2012 07:14 PM
Sold AMT F-16 cockpit kit 1/12 scale nero1156 Aircraft - Fuel - Jets (FS/W) 0 Apr 21, 2012 04:55 PM
Discussion New F-16 build-This should be on H-J's F-16 Thread electriceye Pusher Prop Jet Models 2 Aug 28, 2006 02:45 PM
