BIG 1/7h scale F-16 H-J Style
My buddy Hans has been flying a small profile F-16 (I built from his plans) everytime he visits the states and travels to fly-ins with me. And he flies the snot out of it, it is showing signs of aging.
On the long road trip back from Vegas we talked about a big F-16 profile pusher to replace or accompany it. He agreed to print the plans out and send them to me. I got them just a couple of weeks after we got back to TN. The plan was to build a 1/7th scale, 56" wingspan, ~84" long profile pusher that still could be hand launched. I think falcon5 had one about this size several years ago with a large Scorpion motor and it flew great( as all of Andy's planes do ).Anyway, I got to thinking about it( read that as OC started taking over again) and thought I could build a full fuse that would be much more scale and still be able to HL it. With enough power, anything is possible, right? ![]() So I've decided to go ahead with it and scrap plans for the A-7 build for now. Plus while I am working on it( for SEFF) I want to be gathering parts for my new Vegas build which will be a 83" ws F7F Tigercat built from Palmer Plans. Don't want to go through the hectic pace that I had during the AC-119K build. Time really got away from me there. This will be in the classic Hans-Joachim style of building. We will use the side and top profiles to establish a base and then fill in with formers and sheet the whole fuse. I think I can remove most of the internal structure to keep weight at a minimum and use the fuse skin to take the flight loads. It will be mostly fanfold with some balsa and depron. One other thing, it has to be able to be transported so I will be breaking it up in parts for easier loading. I've ordered tubes & sockets but they have not arrived yet so I will start with some sub assemblies until they do. Pics show the plans that Hans enlarged and I think the sheets were about 12' long! J |
Latest blog entry: F7F Tigercat from Palmer Plans
First thing I did was strip the plastic from 8 sheets of fanfold. Hoping that will be enough.
![]() Got a start by cutting out the necessary views and then cut parts for the side & top out of fanfold. I'll probably work on the stabs and wings until the tubes & sockets get here. I need them for removable wings and to split the fuse in two pieces. J |
Yep, another pusher.
![]() Worked on the stabs. I'm going to use a 0.30 FG arrow shaft for the stabs. I routed a channel for them in the stabs. I will try to get as much anhedral in them as I can by just tilting the stabs when they are glued on. No way I want to fight the complexity of mounting them separately at the proper angle. Let's keep this build as simple as we can. She should have an anhedral look to it though. These stabs are huge. They need to be mounted at 25% MAC or you have some real problems with stability under loads. I will also balance them which will require weight in the nose. After those two things are done they should perform well and keep the heavy loads off the servo. I used a simple method to figure MAC (Mean Aerodynamic Chord) that I learned years ago from my friend and modeler guru Fuzz. We all know Fuzz don't we? ![]() Anyway, simply measure the tip and root chord length, add the tip length to the root chord, top and bottom. Add the root chord length to the tip chord ends, top and bottom. Using those points draw a line from the top left to bottom right and right top to the bottom left. Where they intersect is the MAC. Draw a line through this point parallel to the root chord. Then measure that chord(MAC) and use 25% of that from the LE along that chord and it gives you where the you need to position the stab pivot point. Probably clear as mud huh? Anyway, it works, is fast and simple. I like that. ![]() Maybe the pics will show better. So I used two pieces of 6mm depron, routed a channel and glued them together. I'll sand a symmetrical airfoil into them tomorrow. J |
Hey Hans! I'l try to do it justice.
![]() Don't have a lot to show for today. I do have the stabs airfoiled and spackled. After sanding they will be ready for glass. The pic shows the weight required to balance the stab. Quite a bit but these stabs are huge and they will work a whole lot better balanced. Started on the front fuse top section. Really wanted to have my tubes & sockets before I go too far. Hope they show up tomorrow. Hans' plans show formers but it was designed much smaller and I will need to add a bunch more before I can skin it. I'll just wing it and interpolate the extras needed using the plastic model as a guide. But that's half the fun of scratchbuilding. ![]() J |
| Thread Tools | |
| Sold SAVE BIG!!!! SWEET DEAL on NIB SIG 1/4 Scale J-3 CUB!!!! UNTOUCHED!!! | Plasmajoe | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jun 22, 2012 08:35 PM |
| Discussion Tamjets 1/8th scale F-16 | cableguy351 | Electric Ducted Fan Jet Talk | 8 | May 20, 2012 09:16 PM |
| Discussion Replacement Canopy for Tamjets 1/8th Scale F-16 | Pepperpete | Electric Ducted Fan Jet Talk | 6 | Apr 24, 2012 07:14 PM |
| Sold AMT F-16 cockpit kit 1/12 scale | nero1156 | Aircraft - Fuel - Jets (FS/W) | 0 | Apr 21, 2012 04:55 PM |
| Discussion New F-16 build-This should be on H-J's F-16 Thread | electriceye | Pusher Prop Jet Models | 2 | Aug 28, 2006 02:45 PM |
