Old Jan 15, 2013, 02:53 PM
shufflez is offline
Find More Posts by shufflez
The Netherlands, NH, Amsterdam
Joined Mar 2008
+1!
shufflez is offline Find More Posts by shufflez
Old Jan 15, 2013, 03:12 PM
kristjane is offline
Find More Posts by kristjane
Have a nice day! Kristjan
kristjane's Avatar
Slovenia, Novo mesto, Šentjernej
Joined Jan 2006
Originally Posted by juuuut View Post
Hi,
i would like to present my latest work
its a new ESC based on a MCU which has a HW PWM unit especially for driving three phasis BL motors.
because of that it can do high frequencys (6-128kHz), a clean active freewheeling(HW deadtime generator and complementary PWM) and the mcu dosent need to hadle the PWM .. so there is more time for other tasks
i got to say that the main idea to use this HW was from ampere dieter. he faund the MCU and also the gate driver and fets. and without his knowladge of ESC's and his work this thing wont exist!
the HW is based on small but powerful parts. on the 20A version 2.125mOhm N fets with fast gate drivers will be used. there will be also a 35A version with two of these fets parallel. the fets are rated with 100A and 140W peak each
the software will be closed source for now .. it is planed to make it open later.
(just to prevent misunderstandings.. yes the gui is based on the MWC GUI so it will and must be open source)
its features for now are:
- normal input PWM (50-500Hz)
- 1kHz fast input PWM
- MK I2C (also with I2C telemetrie)
- full 11bit (~2000 steps) resolution (input and output)
- jitter free PWM reading and generating (both done with HW timer)
- active freewheeling with a very short and stable deadtime
- Lipo protection
- stall detection
- closed loop
- GUI Configurable (also with live datas)
- USB port onboard (for a GUI and software updates)
the 35A version will also have CAN HW onboard (there is no SW for CAN atm.)
we have well working prototypes of the 20A version (these protos have 4mOhm fets on it so thay are rated with 15A but otherwise it will be the same thing )
here are also some videos of the GUI:
some active freewheeling tests:
http://www.youtube.com/watch?v=aH1MxxyNQ7Y
a resolution test:
http://www.youtube.com/watch?v=vxXoDRPHk-0
closed loop test:
http://www.youtube.com/watch?v=2A-RdbW7yLM
some HW tests (remember the protos are 15A .. and i dont want to kill it because i dont have enough )
http://www.youtube.com/watch?v=pQeG6FzwD5E
http://www.youtube.com/watch?v=27vduHSRp10
today warthox did the first acro flight tests
http://vimeo.com/56548217
http://vimeo.com/56557351
edit:
here is a video that shows its motor comatibility..
http://www.youtube.com/watch?v=UEZNpfO5oc4
the 20A version will be available at Fylduino soon .. it will cost 29,90€ incl. german tax (19%)
i will update this post when i have news.
a good new year at all
regards felix
Really nice work!
Is there any chance to make 4x20A or 4x12A ECS-s on one board? Something similar to new hobbywing 4x20A ESC.
kristjane is offline Find More Posts by kristjane
Old Jan 15, 2013, 04:09 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Sure, that could be done. But if you burn 1 you can throw away all 4.
And ESCs and their wires cause heat and EMI which you concentrate in the center underneath the FC. Not a good idea...
ESCs are best mounted away from the FC/sensors. Since propwash cools them down, the arms are still a good compromise...
btw: Flyduino fixed the prices for the HEXFET series:
- 10A / 2-3s ~ 16 Euros
- 20A / 2-4s ~ 17 Euros
- 40A / 2-6s ~ 28 Euros
http://flyduino.net/ESC-brushless-motor-controller
Atm only the 10A version is available.
kinderkram is offline Find More Posts by kinderkram
Old Jan 15, 2013, 06:57 PM
saskya is offline
Find More Posts by saskya
DR , EVIL
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
Subscribed
saskya is offline Find More Posts by saskya
Old Jan 15, 2013, 10:43 PM
saskya is offline
DR , EVIL
saskya's Avatar
Joined Apr 2012
With the x2208 motors what esc should I use
10amp are available not 20amp is this ok 10 amp
Old Jan 16, 2013, 06:05 AM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
Flyduino do say the 10A Hexfet ESC will handle more than the P/N 12A ESC.
http://flyduino.net/Flyduino-NFET-HE...onK-Firmware_1
Seeing 12A ESC seems the standard for 2208 (1100KV) one would think it should be OK????
Soma is offline Find More Posts by Soma
Old Jan 16, 2013, 07:23 AM
saskya is offline
DR , EVIL
saskya's Avatar
Joined Apr 2012
and do I need to do something with software or they are ready to install an fly
Old Jan 17, 2013, 12:02 AM
Soma is offline
Joined Sep 2012
The Flyduino ESC's I have are factory calibrated to a throttle range from 1000 - 2000 and I don't think it can be re calibrated. If you're using multiwii you set the right values in config.h. I know nothing about other boards though KK etc.
Maybe these since they're SimonK can be calibrated in the normal way if you need to. Might be something to check?
Old Jan 17, 2013, 12:10 AM
Soma is offline
Joined Sep 2012
I'd really like to see a 4x 6A 2-3S ESC in a 35mm square footprint for mini quads
Or at least 2x ESC per board so two could be stacked vertically.
Would a 6050 gyro/acc chip or the CPU be affected by being close to an ESC? I have a Skywalker Quattro coming and I'd like to set them up close if possible. No other sensors and FETs facing away from FC. They won't be driven hard so they shouldn't get too hot.
ESCs have CPUs right on the same board and run fine????
Old Jan 17, 2013, 12:23 AM
kristjane's Avatar
Joined Jan 2006
I had made few... multicopters and never burned ESC.
About price, 29€ is not so cheap. If there were 4 for let say 100€, that would be more reasonable ( talking about 20A ESC-s).
Old Jan 17, 2013, 02:46 AM
juuuut is offline
Find More Posts by juuuut
Joined Dec 2010
Hi,
MCU's or gyro's and ACC's have no problem with the ESC's... but a MAG and GPS does!
the high switching frequencies with also high current does a lot of EM noise..
i know there are many different opinions how a ESC schould be mounted on a multicopter. i think i know that the best place for it is near the motors. the reasons are:
- better cooling
- the lipo +- wires does a lot less EM noise then the 3 motor wires .. and you can add C's to it to smooth it.
- all the noise is as far as possible away from the RX and the FC
we also thought abaut a 4, 6 or 8 in one and maybe we do one later .. just because its mor easy to install.
regards
Felix
juuuut is offline Find More Posts by juuuut
Old Jan 17, 2013, 03:14 AM
Soma is offline
Joined Sep 2012
Hi,
i know there are many different opinions how a ESC schould be mounted on a multicopter. i think i know that the best playce for it is near the motors. the reasons are:
- better cooling
regards
Felix
Thanks for the reply Felix
Always good to get info from one who knows.
Interesting about comparing EM noise from motor wires and power wires.
Cheers mate
Old Jan 19, 2013, 12:23 PM
saskya is offline
DR , EVIL
saskya's Avatar
Joined Apr 2012
I am puzzle about best props to use with this setup
Old Jan 28, 2013, 04:33 PM
isvedic is offline
Find More Posts by isvedic
Joined Jun 2012
juuut your work is very impressive! Looking forward seeing UltraESC on market soon...
btw. rarely I see things in theory work as planned and in your case it works in practice even better (thanks to warthox)
isvedic is offline Find More Posts by isvedic
Old Jan 31, 2013, 06:05 AM
juuuut is offline
Joined Dec 2010
hi,
yes warthox is a grate tester if there are any problems .. he will find them!
while waiting for the 35A protos and the 20A to be in the shop, i tryed some other code
here are the first results of a sinusoidal driving code.. well just for slow movements like needed on BL gimbals
i started some prototypes of a 3S BLDC stepper controller, using almost the same HW.
the HW PWM also gives some adventages in this mode. i can use higher PWM frequencys (24kHz for now) so there is no audible sound, and because of its resoluntion i can use 1024 steps sinus tables without having too large dead periodes.
here are two videos of my first tests
UltraESC sinus betrieb für BLDC gimbals (0 min 50 sec)
and here a resolution test .. it does 10 steps per second in this video
UltraESC schrittmotor .. 1024 schritte pro 2 pole 10 schritte pro sekunde (3 min 56 sec)
regards
Felix
