United Kingdom
Joined Aug 2008
http://www.rcgroups.com/forums/showp...4&postcount=25 and one time i was in a jam but don't ask me to revisit it I got a least 4 ways i can re-flash without lpt1. Favorite Attiny one i made back then and at90usb162 which does everything. And two Fuse repairers and a AVRDragon <<< if you ever buy one only run it off USB hub that can supply 1amp else it breaks its self.
New York
Joined Oct 2008
hey thats rich, the guy i worked for for many years and taught me virtually everything i know. he also set me up here at rcg and on ebay. i wish he was still around.
be aware there are three popular pinouts: bascom, ponyprog, and stk500. only the last has survived the test of time so id advise avoiding the pinout in "jam" link. 100ohm series resistors are not really required but might be a good idea to protect your motherboard in case you accidently apply 12v or something. i love this method and recommend it to anybody whos lucky enough to have printer ports on their pc. and if you dont as dj said it solves the chicken/egg situation building a usbasp or tinyisp even if you only have temporary access to an old motherboard. |
New York
Joined Oct 2008
well.. yeah. but im not sure why if you already have a v911 tx. you probably meant to say "rx" and if so the answer is no. at least not a very good one. the v911 tx module is not configured for rf out so receive range will be very short. enough for development like in my case but not very practical for flying a plane. the best combo is mega8 and one of those cheap xl7105 modules.
United Kingdom
Joined Aug 2008
I recognized elements of his style in someone here abouts
United Kingdom
Joined Aug 2008
vusbtiny programmer atiny85 based avr programmer http://www.simpleavr.com/avr/vusbtiny
If you really get stuck could build and post one. Think i've got enough parts here to do it. |
New York
Joined Oct 2008
http://www.rcgroups.com/forums/showthread.php?t=1636399 search function of the forum can be very helpful. |
New York
Joined Oct 2008
an offline comment has reminded me i failed to mention recent updates to post #1. sunday i took some photos of the prototype thats being used last few weeks and posted them. wiring is still the same as original prototype but a couple changes: xl7105 instead of v911 module and diode added. a diode on the module allows running the mega8 from 4.2v lipo or 3.3v dc supply yet keeps the module happy with <3.6v. this setup not only used for software development but, even though not in the milligram range, is small enough to be tested and flown in my micro planes.
this power supply issue is particularly important because i did burn out 3 of the xl7105 and one of the v911 modules. almost certainly due to overvoltage but might have been related to cmos latchup because both specs were violated. although it dont die right away that chip does like to go out with a bang. in any case now i avoid running the chip directly off 5v and allowing input signals to go too far above vcc or below ground. i can still operate from a 5v supply (usb) by using another diode to drop everything down to 4.2v to imitate a battery. so 2 diodes total, one for the mega8 and module (4.2v) and another in series with just the module (3.5v). or only one diode for the module when using a 1 cell lipo or 3.3v supply like from usbasp or serial dongle. that .7v drop really works out well for these applications. |
| Thread Tools | |
| Mini-HowTo TH9X Turnigy FlySky IMax modify module to SMA and 1W booster DIY FPV | rotaryboots | Radios | 1 | Apr 04, 2013 05:47 AM |
| Sold iMAX/Turnigy/FlySky TX module & RX | John Kim | Aircraft - General - Radio Equipment (FS/W) | 0 | Jan 12, 2011 12:33 PM |
| For Sale iMAX/Turnigy/FlySky TX module & RX | John Kim | Aircraft - General - Radio Equipment (FS/W) | 2 | Dec 09, 2010 11:15 AM |
| For Sale Turnigy/iMAX/FlySky TX module & RX | John Kim | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 27, 2010 11:03 AM |
