Old Mar 26, 2013, 02:23 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Originally Posted by dave1993 View Post
pcb is for girly boys. REAL men use deadbug!
really
SadSack is offline Find More Posts by SadSack
Old Mar 26, 2013, 06:19 PM
blackmoon is online now
Find More Posts by blackmoon
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
SadSack you inbox is full
blackmoon is online now Find More Posts by blackmoon
Old Mar 26, 2013, 06:40 PM
SadSack is offline
Joined Aug 2008
Whoops
Old Mar 26, 2013, 06:45 PM
gilcd85 is offline
Find More Posts by gilcd85
Israel
Joined Mar 2012
I just put in an order in OSHPark for 3 PCBs for 2.1$ free shipping in the US (or 8 bucks shipping outside the US).
70 cents PCB sounds very reasonable to me
Originally Posted by midelic View Post
....and why I should pay 9.90+2.90 shipping for whatever number of pcb if I need only one or two.)
gilcd85 is offline Find More Posts by gilcd85
Old Mar 27, 2013, 04:32 AM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
Now you contaminated me also with this multiwii.Just crossed my mind, I have this boards for tqfp32,I bought an Atmega 328-3.7dolars ea.and an 6050 for 5.3 dollars...A7105 i already have, fets the same.I want to build a brushed tricopter.
I see I can program the 328 using usb asp programmer...no need of stinky ....arduino bootloader.
I'm thinking of..a modular design a main328 board with female pin headers, connect each section(mpu6050 board ,fet board ) with male pins to the main 328.The A7105 installed bug style on the main board back(all together humping style).
I told you I'm lazy.
midelic is online now Find More Posts by midelic
Old Mar 27, 2013, 04:35 AM
SadSack is offline
Joined Aug 2008
sorted it again, sorry
Old Mar 27, 2013, 05:42 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
For small PCB's that's tremendous value.
Cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Mar 27, 2013, 06:08 AM
midelic's Avatar
Joined Apr 2012
Quote from OSHPARK
"The medium run order
$1 per square inch, 150 square inch minimum. You can have as many different designs as you want, as long as each is ordered in a multiple of 10 boards."
So there is minimum order..maybe you are old customer.Anyway I'm not in US.
Old Mar 27, 2013, 06:31 AM
gilcd85 is offline
Israel
Joined Mar 2012
I am new to OSH Park (registered yesterday).
From my receipt:
Description Unit price Qty Amount
1 batch of diy flysky rx - 3 x rev3
boards Item# 9BD0D6cc $2.10 USD 1 $2.10 USD
I am not in the US as well so it will end up as 3$ per board (less if I order more than 3).
Old Mar 27, 2013, 06:41 AM
midelic's Avatar
Joined Apr 2012
3 dollar per custom board is good value as long as no pay for minimum order.It is good to now for the future boards.
Old Mar 27, 2013, 04:06 PM
gilcd85 is offline
Israel
Joined Mar 2012
One thing that has been bugging me is the amount of wires I have going between the Rx and FC (Signal, GND, VCC * 4/5 channels=12-15 wires). Granted if we have a single MCU doing both Rx and MultiWii FC functionality this will be resolved but until then I would like to try and remove as many wires as possible.
I don't have any experience with PPM SUM, is it doable in the current configuration? What would be required for it to work?
One thing I think we can do straight away and cut # wires by ~1/2 is to remove GND and VCC from all RX-FC connections besides one. This is already done by several FCs (nanowii). Any thoughts as to why this wouldn't work here?
Old Mar 27, 2013, 04:11 PM
Banjo5 is offline
Joined Jun 2012
AFAIK it would work fine. You'd need a single ground, +5, plus the 4/5 signal wires. That's the way I have it wired between my FrSKY RX and KK2 board on my brushless quad.
The PPM sum (CPPM?) would get it down to 3 wires. Integrating RX with the FC to zero .
cheers,
Andrew
Old Mar 27, 2013, 04:23 PM
midelic's Avatar
Joined Apr 2012
Why they say PPM sum all the time ? Is simple PPM signal there is no such thing as PPM sum(CPPM). what is the difference?
Old Mar 27, 2013, 05:07 PM
gilcd85 is offline
Israel
Joined Mar 2012
Ah that's great! This allows for a new and improved Rx PCB design of 15.23x12.37mm with only the ATmega8 on the back for mounting (humping? lol) the 7105.
I have no idea how I'm going to solder anything on this though
Old Mar 27, 2013, 05:17 PM
SadSack is offline
Joined Aug 2008
gilcd85 :
What you using in eagle for 3D output ?
Which module are you using or have ?
Mini-HowTo TH9X Turnigy FlySky IMax modify module to SMA and 1W booster DIY FPV rotaryboots Radios 5 Feb 03, 2015 05:46 AM
Sold iMAX/Turnigy/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 12, 2011 01:33 PM
For Sale iMAX/Turnigy/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 2 Dec 09, 2010 12:15 PM
For Sale Turnigy/iMAX/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 0 Oct 27, 2010 12:03 PM
