Old Jan 22, 2013, 11:40 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
ive uploaded to post #1 a hex file for the 8chan mega8 version of diy flysky rx. fuses are c0a4. wiring is same as in the prototype photo:
pd7-0=chan1-8
pb5=cs
pb4=sck
pb3=dio
pb2=io1
to bind:
1. turn on tx
2. short ch8 to gnd and apply power
3. wait 5 sec then disconnect ch8, led on pc5 goes on to indicate link
ill add a diagram and more photos when i get a chance. i think this should be enough to get one running now assuming i havent made a mistake somewhere or left anything out.
dave1993 is offline Find More Posts by dave1993
Old Jan 22, 2013, 04:33 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Originally Posted by dave1993 View Post
i also improved the half gram 8ch modified pcb version. now has failsafe and simpler link procedure. playing around with antenna configurations i was able to almost double the range. it was already adequate for any model that size to be seen but now your buddy in the next county can watch the plane and give you control instructions over cell phone. lol!
You added failsafe? Sweeeeeet
msev is offline Find More Posts by msev
Old Jan 23, 2013, 11:23 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
Originally Posted by msev View Post
Awesome we like your projects ...When will rssi for 9x receivers come onto your to-do list :P
Originally Posted by blackmoon View Post
Does the pcb version already outputs PPM-sum signal ? (I know I'm impatient...)
Well done Dave.
thanks for the compliments guys. hopefully others find these things as interesting as i do. so looks like a to-do list is in order:
1. rssi
2. ppm
3. ?????
ill start tracking suggestions in post #1.
Old Jan 23, 2013, 01:29 PM
Ivan2280 is offline
Find More Posts by Ivan2280
ITALY
Joined Sep 2004
actuator
Actuator output for micro airplane.
Ivan2280 is offline Find More Posts by Ivan2280
Old Jan 23, 2013, 06:36 PM
djdavies83 is online now
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
This is cool, what are the odds of a version that uses a gyro from S107 or V911 and has 4 motor outputs to be used in a tandem coaxial?
djdavies83 is online now Find More Posts by djdavies83
Old Jan 24, 2013, 02:45 AM
msev is offline
Joined Sep 2010
Odds of it are better than him making a full fledged autopilot
Old Jan 25, 2013, 11:21 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
good call. actually that is already available on one of the half gram versions i was playing with. 1 motor pwm pin, 3 servo pwm, 4 actuator. havent really tested this on a plane but it looks good on the scope. added to the list in post #1.
Old Jan 25, 2013, 11:30 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
not necessarily true. ive already succeeded in writing basic rudder controlled rtl code which seems to be working so far. turns out parsing nmea strings and basic waypoint sequencing are much easier to implement than those gyro/accel algorithms. none of that tricky pid stuff. maybe some day incorporate it into the rx firmware as a option to minimize lost planes. maybe.
Old Jan 25, 2013, 11:32 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
dupitty dup.
Old Jan 25, 2013, 01:31 PM
msev is offline
Joined Sep 2010
That would be awesome,...plane stabilization could be done with other boards (like the kk2 or naze32 with openaero2 or openaero32 software)...so the receiver would just control the rudder when it goes into failsafe..That would be really awesome!
Old Jan 26, 2013, 11:54 AM
joker24458 is offline
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Hi Dave, I am very interested in this, but unfortunately I do not have a Turnigy or FlySky transmitter, and as mentioned before, they are cheap, but I prefer my DX7s. Also I dont want to spend money on another transmitter that I am not going to use for anything else (most likely), and I am a kid (11 yrs old) so I do not have that much money in the first place. Is it possible to make a little reciever like the deadbug one that is DSM2 or DSMX compatable? Thanks.
-joker
joker24458 is offline Find More Posts by joker24458
Old Jan 26, 2013, 12:15 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
-joker
There are not any 'DIY' DMS2/DMX nano RX but save your penny's http://www.deltang.co.uk/
SadSack is offline Find More Posts by SadSack
Old Jan 26, 2013, 12:57 PM
joker24458's Avatar
Joined Mar 2012
Ugh, I was afraid of that. I have already seen the DelTangs, but they are quite expensive.
-joker
Old Jan 26, 2013, 01:26 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
-joker
Maybe Lemon-RX is interesting for you . LightWeight and cheap DSM2 rx.
http://www.lemon-rx.com/
mystman is offline Find More Posts by mystman
Old Jan 26, 2013, 01:51 PM
joker24458's Avatar
Joined Mar 2012
Yep, I know about Lemon RX too. In fact I was looking at this one (link below) a couple of days ago, but at 1.41 grams, it is still a bit too heavy and too big for what I was looking for. Thats why the deadbug reciever caught my attention - a cheap, small, lightweight reciever. I am thinking about buying a DT rx used to save money.
-joker
EDIT: Whoops, totally forgot to add the link. Here it is: http://www.lemon-rx.com/shop/index.p...&product_id=94
Mini-HowTo TH9X Turnigy FlySky IMax modify module to SMA and 1W booster DIY FPV rotaryboots Radios 5 Feb 03, 2015 04:46 AM
Sold iMAX/Turnigy/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 12, 2011 12:33 PM
For Sale iMAX/Turnigy/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 2 Dec 09, 2010 11:15 AM
For Sale Turnigy/iMAX/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 0 Oct 27, 2010 11:03 AM
