Old Jan 09, 2013, 07:30 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by Quandry View Post
Reading through the manual it seems that the AR635 has two gain modes - sport & 3d. The programming looks a little complicated for field adjustments, also the gain can only be adjusted in increments of 10% which back in my heli days 10% is massive.
Still I've had good experience with my Beast 3D and Hyper Taxi so can't loose faith at this early stage
I wonder will the gain be sufficient to hold a hover hands off?
I know the mechanical setup of the plane has to be condusive but just wondering..
Quandry,
I think that would require a heading-hold mode. As set up on the UMX planes, AS3X operates in rate mode.
Joel
turboparker is online now Find More Posts by turboparker
Old Jan 09, 2013, 09:46 AM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
Originally Posted by turboparker View Post
Quandry,
Joel
On their Blade series helis they achieve Heading Hold with AS3X so it seems to be capable. That's why I was wondering if maybe a high gain will give heading hold, could be interesting.
Quandry is offline Find More Posts by Quandry
Old Jan 15, 2013, 11:37 AM
Sophisticat is offline
Find More Posts by Sophisticat
Sophisticat's Avatar
United Kingdom, Northern Ireland, Newtownards
Joined Mar 2012
The Spektrum website says the receiver is suitable for '90-size electric airplanes (not designed for nitro or gas aircraft)'.
I haven't got a clue what 90 size means. Would someone enlighten me, please?
Sophisticat is offline Find More Posts by Sophisticat
Old Jan 15, 2013, 12:42 PM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
90 size means an airplane with a 90 size motor like E flite's Power 90 http://www.e-fliterc.com/Products/De...odID=EFLM4090A
The Power 90 is rated for sport/scale planes 8-13 lbs or 3D planes up to 10 lbs.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Jan 15, 2013, 12:47 PM
Joined Jul 2009
Expanding a bit on Mugen's post...
For a number of decades, recommended 2-stroke glow-engine displacement was the standard measurement of RC plane sizes. For instance, a '40-size' plane typically requires a .40-.46 cubic-inch two-stroke glow engine, and AUW is usually around 4-5 pounds for a purpose-built aerobatic model.
Larger electrics adopted the same nomenclature, as it simplified the electric conversion process. So, '90-size electric' is a reference to ICE power, in which the plane would require an electric motor with power similar to a .90 cubic-inch 2-stroke glow engine.
Joel
Old Jan 16, 2013, 11:27 AM
Joined Mar 2012
Mugen4Lfe and turboparker, thank you, that's very helpful.
90 is much more than adequate for the planes I fly.
I like AS3X, so I'll definitely give this receiver a try.
Old Feb 12, 2013, 09:54 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
A Eagletree Guardian is a better system with 2D and 3D modes if you have the space to fit it in your plane. Price for the Guardian is about $75 shipped plus your receiver.
Prof100 is offline Find More Posts by Prof100
Old Feb 12, 2013, 10:51 PM
Mugen4Lfe's Avatar
Joined Sep 2011
Having never used an Eagletree Guardian myself, what makes it better?
Old Feb 12, 2013, 11:39 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
It has both a 3 axis gyro that can be programmed to have heading hold or simple rate mode. In addition, it has 3 accelerometers (2 D) that will right the plane to level flight if you release the sticks. Pretty amazing. I have 6 of them and fly a 17 ounce foam delta in 25 mph winds (flag sticking straight out). Other planes are grounded and I am flying.
Old Feb 13, 2013, 07:43 AM
Joined Jul 2009
Another huge difference between the two - the AR635 can't be used in any ICE-powered planes. There is a big caution about using it only in electrics, and then only in 90-size and smaller electrics. In contrast, the Guardian can be used in 200 MPH turbines & giant-scale gassers.
Also, the Guardian has automatic gain-induced oscillation detection & auto gain reduction, and you can freely adjust the master gain from your tx. Both are extremely important features for fast planes with wide speed envelopes.
Joel
Old Feb 13, 2013, 09:54 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Another huge difference between the two - the AS635 can't be used in any ICE-powered planes. There is a big caution about using it only in electrics, and then only in 90-size and smaller electrics. In contrast, the Guardian can be used in 200 MPH turbines & giant-scale gassers.
Joel
Joel,
And the the list goes on and on about the features and functions of the Guardian.
Bill
Old Mar 06, 2013, 05:51 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
So are analog servos a no-no with this receiver?
DamonH is offline Find More Posts by DamonH
Old Mar 06, 2013, 07:41 PM
Mugen4Lfe's Avatar
Joined Sep 2011
It depends on whether you choose to listen to the manual, or the "experts" in this thread.
Old Mar 06, 2013, 10:39 PM
Denile is offline
Find More Posts by Denile
M16 CIII/AR15/FN 2000 and PS90
Denile's Avatar
United States, AR, Waldron
Joined Jan 2005
90 size and 17oz planes, not to mention a 13gr rcvr I thought this was a micro forum???
Denile is offline Find More Posts by Denile
Old Mar 11, 2013, 06:03 PM
Joined Jul 2009
This may be a micro forum, but the product is clearly being marketed for use in planes that are way larger than micro-size. In fact, the specs say that it's intended for electrics up to 90-size. The smallest plane in which HH currently uses this rx is the Vision Aire - a 2.75-pound, 3s 2200-powered, 10-size 3D plane. It is also used in the Carbon-Z Splendor - a 5.5-pound, 6s 3200-powered, 50-size pattern ship.
Joel
Wanted Immersion stand alone receiver goldsworthy FPV Equipment (FS/W) 0 Nov 24, 2012 06:20 AM
Wanted Immersion stand alone receiver goldsworthy FPV Equipment (FS/W) 2 Nov 21, 2012 09:47 AM
Idea Stand alone on-board GPS logger for Google Earth iskess DIY Electronics 20 Sep 19, 2012 01:20 AM
Idea DIY - stand alone receiver test module midelic DIY Electronics 0 Sep 15, 2012 08:23 AM
Question Stand alone balancer question kscheck Batteries and Chargers 16 Mar 27, 2012 11:30 PM
