Old Dec 31, 2012, 08:22 AM
rcpaintfx is offline
Find More Posts by rcpaintfx
Kev Waite
Plymouth UK
Joined Nov 2005
AR635 First Stand Alone Spektrum RX with AS3X
Just found out today that next week a SPMAR635 Spektrum 6ch Sport Receiver will be released with AS3X technology. RRP is £79.99.
See Below full information now available:
Product Description
Key Features
Combines the security of DSM2®/DSMX® technology with the precision of the AS3X® System
Designed for park flyers, sport planes, and 3D airplanes
Compatible with all Spektrum™ DSM2/DSMX and JR® DSM® transmitters
Three AS3X System settings: Sport, 3D with non-computer transmitter, 3D with computer transmitter
Fully-adjustable, dual gain settings for aileron, elevator and rudder
Overview
Bring a whole new dimension of precision and stability to your 3D or sport flying experience with the first 6-channel full-range receiver with AS3X® technology for park flyers, sport aircraft and 3D planes—the Spektrum™ AR635 sport receiver. Its built-in AS3X (Artificial Stabilization – 3-aXis) System counters the effects of wind and turbulence using 3-axis sensing and exclusive flight control software tuned by world-famous RC pilot, Quique Somenzini. There is no delay in control response or limits on the control throws. You'll simply feel like you're flying an expertly tuned model that does exactly what you want it to.
No special interface or transmitter programming is required. All adjustments to the type and amount of stability the AS3X System provides are made using LED indicators on the receiver and your transmitter's control sticks. You also have the option of flying with the AS3X System off, but even expert pilots will find flying with it on feels completely natural.
Model Type: Airplane
Telemetry: Yes
Number Of Channels: 6
Range: Full
Band: 2.4GHz
Modulation: DSM2/DSMX
Length: 2.2 in (56mm)
Width: 0.8 in (21mm)
Height: 0.5 in (14mm)
Weight: 0.5 oz (13.2 g)
Voltage Range: 3.5–8.5V
Antenna Length: 230mm
Type: Full-range AS3X sport receiver
Flight Log Compatible: Yes
Resolution: 2048
rcpaintfx is offline Find More Posts by rcpaintfx
Old Dec 31, 2012, 10:00 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Cool, it's been asked for for sometime.
freechip is offline Find More Posts by freechip
Old Dec 31, 2012, 04:14 PM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Is that full size or micro like the:
http://www.horizonhobby.com/products...c-SPMAS6410NBL
Petefoss is online now Find More Posts by Petefoss
Old Dec 31, 2012, 05:00 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
People have been asking for a full size similar to the AR600 (c)
Old Jan 01, 2013, 07:50 AM
Kev Waite
Plymouth UK
Joined Nov 2005
Going by the part number, I should imagine it is a AR600 receiver with AS3X built in.
Old Jan 03, 2013, 07:24 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
http://www.spektrumrc.com/Products/D...rodID=SPMAR635
Old Jan 03, 2013, 10:41 AM
Petefoss's Avatar
Joined Aug 1999
Cool!
Old Jan 03, 2013, 12:02 PM
Pouncer is offline
Find More Posts by Pouncer
Wanton construction
Pouncer's Avatar
Stockholm Sweden
Joined Sep 2006
Wonder which servos they recommend for it?
Would digital metal-geared be up to the task?
Pouncer is offline Find More Posts by Pouncer
Old Jan 03, 2013, 01:42 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by AR635 manual
Servo Selection
Select servos that are adequate for AS3X operation. The servos must be
digital, high speed and high resolution
. A poor servo/linkage geometry
combination will cause several issues, including oscillations and
unwanted reaction.
http://www.spektrumrc.com/ProdInfo/F...-Manual_EN.pdf
Old Jan 03, 2013, 10:47 PM
jmwalsh is offline
Find More Posts by jmwalsh
Joined Nov 2011
so, will dual channel ailerons possible? ie. will we be able to set up our own dual aileron config or limited to mirrored aileron ch like the micro bricks?
Differential, spoilerons, flaperons etc.
jmwalsh is offline Find More Posts by jmwalsh
Old Jan 03, 2013, 10:53 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
manual is pretty helpful in answering questions like this.
Originally Posted by manual
CAUTION: The AR635 is not compatible with Delta, V-tail, or Flaperon
mixing. If using dual ailerons, elevator or rudder, a Y harness must be used
Old Jan 03, 2013, 11:05 PM
jmwalsh is offline
Joined Nov 2011
Thanks, I must have missed that.
That is disappointing.
The manual does say that mirrored/reversed aileron channel is an option, so strictly speaking a Y harness wouldn't always be required.
Old Jan 04, 2013, 02:47 AM
Elios000 is offline
Find More Posts by Elios000
United States, MO, Springfield
Joined Jul 2010
well that kills most of the uses i had in mind for it >.>
Elios000 is offline Find More Posts by Elios000
Old Jan 04, 2013, 03:26 AM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
Looks great, I would prefer independant wing/elevon control but maybe that will come in a future release. Will give one of these a run in a turbo raven I am building for Spring.
Quandry is offline Find More Posts by Quandry
Old Jan 04, 2013, 07:33 AM
lord chris is offline
Find More Posts by lord chris
RAFMAA
United Kingdom, Marham Airfield
Joined Jun 2005
does £80 not seem a little pricey?
lord chris is offline Find More Posts by lord chris
Wanted Immersion stand alone receiver goldsworthy FPV Equipment (FS/W) 0 Nov 24, 2012 06:20 AM
Wanted Immersion stand alone receiver goldsworthy FPV Equipment (FS/W) 2 Nov 21, 2012 09:47 AM
Idea Stand alone on-board GPS logger for Google Earth iskess DIY Electronics 20 Sep 19, 2012 01:20 AM
Idea DIY - stand alone receiver test module midelic DIY Electronics 0 Sep 15, 2012 08:23 AM
Question Stand alone balancer question kscheck Batteries and Chargers 16 Mar 27, 2012 11:30 PM
