This thread is privately moderated by EASpec, who may elect to delete unwanted replies.
Old Dec 31, 2012, 12:18 AM
EASpec is offline
Find More Posts by EASpec
Joined Dec 2012
New Product
EASpec on iTunes
EASpec stands for Electric Aircraft Specification, and is a new iPhone / iPad app. It is intended to make it simple for anyone assembling an electric powered model aircraft to correctly specify a set of equipment that will deliver the intended flying performance.
Electric motors, speed controllers and Lithium Polymer batteries are now abundant, but the problem for any modeller is "how to select the right equipment?". Some people only use the exact equipment recommended by the manufacturer, but this is highly restrictive, with the recommended components possibly unavailable locally, or only available at high cost. A better approach is to utilise this application, where the modeller enters an estimate of the aircraft's weight, the intended flying style (from mild to WILD!), and the target flight time, then the app advises the specifications for the motor, speed controller and battery. The user then looks for equipment approximating these specifications from whichever supplier they choose, with a high degree of confidence that the result will work exactly as intended.
$1.99 from itunes: https://itunes.apple.com/au/app/id578943977?mt=8
Happy specifying and flying!
EASpec
EASpec is offline Find More Posts by EASpec
EASpec is offline
Joined Dec 2012
Note that the power drawn by an electric motor is highly dependent on the selected propeller. The app makes its recommendation on propeller size on the proviso that the motor Kv and resistance are accurate, but manufacturers sometimes struggle to accurately report these figures.
It is recommended that the user employs a watt meter to confirm the selected propeller achieves the target power (which the app advises). If the measured power is lower than intended, a larger propeller should be installed and the power test repeated, and vice versa.
Old Dec 31, 2012, 01:05 AM
EASpec is offline
Joined Dec 2012
Sample screenshots - Top Flite Mustang 60 ARF
Sample aircraft spec #1
Here's the airframe: http://www3.towerhobbies.com/cgi-bin/wti0001p?I=LXTDF5
The completed plane used the following equipment:
  • Motor: Turnigy Aerodrive SK3 - 5065-320kv
  • ESC: Turnigy dlux 120A HV Brushless Speed Control
  • Batteries: Rhino 8S (4S x2) 3700mAh 30C
  • Prop: Turnigy Ultra-light wood propeller 15x10
Peak power was 1600W, with impressive performance. Excellent aerobatic capability (as expected). Takes-off easily at about half throttle, and has enough power to fly almost unlimited vertical. The 10-inch pitch allows for easy slow flight at about 40% throttle, which is very scale-like but has enough pitch speed at low rpm to maintain flight speed.
Note that the 120A ESC was selected simply because the user had one. Peak current is only 57A, so a 70A - 80A ESC would have been adequate.
Old Dec 31, 2012, 01:28 AM
EASpec is offline
Joined Dec 2012
Sample screenshots - R2 Hobbies Passer-X
Sample aircraft spec #2
R2 Hobbies Passer-X "Warmliner"
Here's the airframe: http://www.r2hobbies.com/rc-aircraft...ilplane-2.html
  • Motor: KD A22-20L
  • ESC: Turnigy Plush 30A ESC
  • Battery: Rhino 3S 1050mAh 30C
  • Prop: Graupner 11x8 folding prop
Peak power was 270W, with fast vertical climbs to 500+ft in ~15 seconds. The 2.5mins motor run time gives a LOT of climbs to altitude, with one flight lasting over 1 hour.
Sold $100 App store / Itunes gift card allenzee Non R/C Items (FS/W) 2 Aug 07, 2012 01:13 PM
Discussion What is on your iPod / iTunes / CD player now - or lately? craab Life, The Universe, and Politics 13 Jan 19, 2008 04:00 PM
