Old Jan 01, 2013, 04:23 AM
arun.sreelakam is offline
Find More Posts by arun.sreelakam
Joined Jun 2012
@rick
no grassed place over here for me...
i am looking forward for a rubber or foam skid as you mentioned.. but cant find any picture like that for reference..
arun.sreelakam is offline Find More Posts by arun.sreelakam
Old Jan 01, 2013, 09:47 AM
vlatko is offline
Find More Posts by vlatko
vlatko's Avatar
Croatia, Osijek-Baranja County, Osijek
Joined Feb 2006
Here's the photo of the rubber skid.
vlatko is offline Find More Posts by vlatko
Old Jan 01, 2013, 09:59 AM
Joined Jun 2012
@vlatko
man but is it enough to save the birdie from a crash?
i was thinking for a thicker covering..
Old Jan 01, 2013, 01:33 PM
n553302 is offline
Find More Posts by n553302
n553302's Avatar
Northwestern Illinois
Joined Jan 2003
Your bird's air frame is apparently built from fiberglass just as the SK birds are (my SK birds frames are 1.5mm thick) and glass is really quite impact resistant. As for 'crash protection', not crashing is the only way to prevent damage.
When landing always lite as flat as possible, wings straight out or up allowing the frame to take the landing rather than the wing spars. Your more incline to snap a wing spar if a tip connects with the ground than break the frame. Another option would be to catch it.
On this forum in the past I've read post about bearing problems when landing on sand and one fellow carried compressed air with him to clean the gearbox when contaminated. I purchased a SK bird from a group member some time ago and this member flew near sand and must of landed in it at some time because a couple of the bearings were crunchy sounding and needed to be replaced.
n553302 is offline Find More Posts by n553302
Old Jan 01, 2013, 11:23 PM
Joined Jun 2012
@rick
i just made a thermocol covering to protect the bird in my maiden.. lets see what happens...
the material is 1.5 mm thick frp sheet(here in india it is known like this)
will upload the maiden result soon man.. thanks for your help..
Old Jan 02, 2013, 11:11 PM
Kazu-kaku is offline
Find More Posts by Kazu-kaku
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
When I look at a video,
Your clothes are not shaken.
A thrust of ornithopter may be weak.
Look attached file.
Kazu-kaku is offline Find More Posts by Kazu-kaku
Old Jan 03, 2013, 12:03 AM
therealthing691 is offline
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
I think maybe the diagonal batten extends too far along the spar there for too much lift panel not enough thrust panel regards Brian
therealthing691 is offline Find More Posts by therealthing691
Old Jan 03, 2013, 02:29 AM
Joined Jun 2012
@kazu-kaku
Sir let me try it by adding an extra cf rod as you mentioned..
will check it and update the results..
Old Jan 03, 2013, 02:35 AM
Joined Jun 2012
@brian
sir actually I got this image from rcgroups (don't remember from where)
this was what my wing reference not the same dimensions but my own calculations..
that's why I extended the diagonal spar that much.. will it harm my bird?
Old Jan 03, 2013, 07:24 AM
australia
Joined Apr 2007
@brian
it will give less thrust but what DR kazu says will give more in my opinion cheers Brian
Old Jan 03, 2013, 08:36 PM
Joined Jun 2012
@brian
i am working on it right now.. lets see the difference..
Old Jan 03, 2013, 11:46 PM
samwei1950 is online now
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
Suggest to have 10-15 degree attack angle after CG determined when maiden your lovely scratchbuilt orni,or the bird may not be able to lift
have great flapping fun
regards
Sam
samwei1950 is online now Find More Posts by samwei1950
Old Jan 04, 2013, 05:00 AM
Joined Jun 2012
@sam
regards
Sam
sam i didnt get you..
what you mean by an attack angle?
Old Jan 04, 2013, 06:23 AM
Taiwan
Joined Aug 2011
Means 10-15 degree tail tilt upward
regards
Sam
Old Jan 04, 2013, 10:26 AM
Joined Jun 2012
@sam
sir actually i already done that and set it to 20 degrees now..
thanks for your suggestion..
Gallery RC Ornithopters Videos For those that want to see what rc Ornithopters flying[Part1] massimo Ornithopters 13 Feb 14, 2014 02:37 PM
Discussion 15" RC Ornithopter mrexcel Scratchbuilt Indoor and Micro Models 15 Jun 11, 2012 09:40 PM
Discussion Slow Hawk RC Bird- SK Ornithopter RobscoRC Ornithopters 2 Jun 04, 2012 11:00 PM
Discussion Scale Homebuilt RC Trucks and Cars That can fly?!? Car Talk 3 Oct 02, 2008 01:38 AM
