Old Dec 31, 2012, 12:15 AM
Joined Jun 2012
rc ornithopter homebuilt
SO its time to upload my dream build now... started my rc hobby just few months before but.. more than anything ornithopters are my favorate and i didnt go for buying one.. instead i decided to make one..
gone through all the website as possible.. didnt find any build log..
finaly decided to build my own so that i can make a build log later..
selected kinkade's slowhawk as my model and started to download as many pictures of that.. using my ideas and stuffs available locally and started my build few monts back..
the main problem was the gear assembly.. and searching for proper gears.. i dont want to spent more by getting gears online..
got some help from kazuhiko Kakuta(rcgroups) and models previously submitted in RCIndia as well..
now the wing action is almost good in my calculation getting enough trust..
see my video of wings test... and please give your valuable suggestions...
http://www.youtube.com/watch?feature...&v=JGTNA9Vc5r4
arun.sreelakam is offline Find More Posts by arun.sreelakam
Old Dec 31, 2012, 12:19 AM
Joined Jun 2012
some pics of main body and tail assembly..
will upload the vid later
Old Dec 31, 2012, 03:32 AM
KOROBELNIK's Avatar
PARIS
Joined Oct 2002
The two front wheels must rotate clockwise
KOROBELNIK is offline Find More Posts by KOROBELNIK
Old Dec 31, 2012, 03:51 AM
Joined Jun 2012
why so?
what changes it will make..?
Old Dec 31, 2012, 03:54 AM
Joined Jun 2012
ornithopter tail completed
here comes the entire orni tail assembly also done..
please give me your suggestions friends...
rc ornithopter homebuilt testing (1 min 48 sec)
Old Dec 31, 2012, 05:58 AM
KOROBELNIK's Avatar
PARIS
Joined Oct 2002
http://ovirc.free.fr/GLDAB_JAPAN.php
Old Dec 31, 2012, 07:48 AM
Joined Jun 2012
but sir i didnt get you..
the gears must round clockwise only if i am using GLDAB system right?
please explain the thing.. i am really new to this.. this is my first build..
Old Dec 31, 2012, 08:47 AM
Joined May 2011
For the GLDAB doesn't matter in which direction gears rotate but for the ratchet ( the wings glide position locking device) does. The orientation of the ratchet determine the direction of the gears rotation. If you don't have ratchet mounted don't worry about the direction of gears rotation. If you have it then the gears must rotate in the direction which allow their free turning when the motor is on and locking when the motor is off.
seagull10 is offline Find More Posts by seagull10
Old Dec 31, 2012, 09:12 AM
Joined May 2011
Bravo Arun , Good job !
I suppose it will fly as it is, just find some flying field with taller grass for minimizing ground strikes impact . Also some play with center of gravity will be probably necessary too.
If it doesn't fly then increase the flapping angle.Your one look like 30 degree ,most common is between 45-60 degree .This will lower the necessary flapping frequency as well.
Also if it is not stable enough make flapping angle asymmetric regarding the horizontal neutral line or for example if your total flapping angle is 50 degree make it flap 40 degree over that imaginary horizontal line and 10 degree down.
I wish you success and Happy New Year !
Old Dec 31, 2012, 11:14 AM
Joined Jun 2012
@seagull
thanks a lot for your critiques sir... will try it...
the flapping angle is 30 up and ~15 down...
if the thrust is not enough will try to increase the angle...
and sure will upload the results..
Old Dec 31, 2012, 12:01 PM
n553302's Avatar
Northwestern Illinois
Joined Jan 2003
Looks like a flying machine arun.sreelakam.
When balancing the bird for it's first flight nose heavy will be to your advantage especially if the wind speed is very high. Also you mentioned this build is fabricated based on a SK Slowhawk. From the Slowhawk setup manual Sean suggest the neutral pitch angle of the tail should be about 20-25 degrees from the horizontal, my Slowhawk is set at this amount and fly's well. Yours is somewhat less that this I believe. Sometimes if one of these birds will not turn as quickly as you wish extra 'up elevator' is required to help push the tail in the desired direction. His manuals are available free online if you look around.
Have luck, looks great so far
Rick
n553302 is offline Find More Posts by n553302
Old Dec 31, 2012, 08:54 PM
Joined Jun 2012
@rick
thanks rick, and i noticed that yesterday from some site(http://sgdrone.com/Content/Images/uploaded/Assemble.pdf)....
i can change the angle when ever i want so now its been set to about 20 degree.. but i am confused, if i make it to 30 degree or so will the down elevator work?
i mean will a 10 degree of elevator change takes the birdie down?
Old Dec 31, 2012, 09:24 PM
n553302's Avatar
Joined Jan 2003
Down is easy, very little down elevator is required.
During forward level flight you will probability holding the elevator stick slightly forward and the tail will be more or less level with the wing. If you are using a computer radio you may want to set the control movements to their max, no such thing as to much throw.
Old Dec 31, 2012, 10:37 PM
Joined Jun 2012
@rick
anyway i had lifted the tail part to 25~30 degree up.. and going for a maiden soon...
thinking upon to cover the body using foam.. to prevent damage in case of crash..
will update the result dude.. thanks a ton for your help...
Old Jan 01, 2013, 01:47 AM
n553302's Avatar
Joined Jan 2003
As mentioned a few post ago, deep soft grass,weeds make for a good landing zone.
I've seen pictures of a length of rubber or silicon hose slit and mounted as a skid plate.
Discussion 15" RC Ornithopter mrexcel Indoor and Micro Models 15 Jun 11, 2012 08:40 PM
Discussion Slow Hawk RC Bird- SK Ornithopter RobscoRC Ornithopters 2 Jun 04, 2012 10:00 PM
Gallery RC Ornithopters Videos For those that want to see what rc Ornithopters flying[Part1] massimo Ornithopters 12 Mar 10, 2010 03:03 PM
Discussion Scale Homebuilt RC Trucks and Cars That can fly?!? Car Talk 3 Oct 02, 2008 12:38 AM
