Old Dec 30, 2012, 11:44 PM
gggval is offline
Find More Posts by gggval
gggval's Avatar
Joined Dec 2012
my new RC nitro car awd want to lift it
hey guys,
i got this today on a trade.
i want to lift it up as high as it will go, and put some off-road tires on it.
I'll keep you guys protested but I have never owned a nitro RC so this will be fun!
i was told it goes extremely fastbut I haven't even heard it run.
what do you guys think!?
questions?
comments for a newb?
gggval is offline Find More Posts by gggval
Old Dec 31, 2012, 08:16 AM
mredzadventure is offline
Find More Posts by mredzadventure
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
Off road tires are not going to work so hot on an on-road car. I might have wanted to hear it run before I did any trading. Nitro can be a bit of a pain for a new guy/gal. There is a bit of a learning curve. If you have a manual read it cover to cover. Especially on the engine tuning part. I would go out an buy a new glow plug fuel tubing and clean and re-oil the air cleaner before I got to far into it.
good luck
mredzadventure is offline Find More Posts by mredzadventure
Old Jan 02, 2013, 11:23 AM
gggval is offline
gggval's Avatar
Joined Dec 2012
sorry it took so long to post back, i wrote a bunch the other day and it didnt post so i gave up.
i am a guy, but small engines are my thing because im a motorcycle mechanic so I will have no problem tuning it in once I get a glow plug and fuel.
the tires are about 50-65mm and im going to 87mm buggy tires and 130mm monster truck tires so I will definitely need to change the gearing or this thing ain't going anywhere.
it doesnt have an air filter but those are only 3 bucks, and it needs a new battery casing because the one on it doesn't get any power to it.
i also found a cool new body for $16 New.
besides all that fun stuff I will be on the road soon.
for some reason im not able to get the ground clearance any higher by messing with the suspension.
Old Jan 02, 2013, 01:49 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Even if you get bigger tires on there, it won't have lots of suspension travel and the tires (fronts especially) will likely rub on something.
wparsons is offline Find More Posts by wparsons
Old Jan 02, 2013, 02:03 PM
gggval is offline
gggval's Avatar
Joined Dec 2012
i will carve it out so that it will turn. im on a mission.
Old Jan 02, 2013, 03:43 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You would be MUCH happier with how a proper off road vehicle handles compared to a touring car with big tires.
Old Jan 02, 2013, 06:40 PM
gggval is offline
gggval's Avatar
Joined Dec 2012
honestly i would have bought one but i have no cash which is why i traded it for a compound miter saw that I didn't need. he was the only person that would trade out of the like 20 people selling theirs.
i got it running today, its a two speed with bake.
when I give it full throttle the tires spin like there is no tomorrow!!!
it is super fast!
the next thing I will do is get the tires but they will take 15-25 days to get here.
i also have spare gears and clutch bell that is to gear it down for the tires.
how can I tell the size of the motor?
I'll put more pictures up soon.
Old Jan 02, 2013, 11:15 PM
gggval is offline
gggval's Avatar
Joined Dec 2012
i just found out what it is, its a team associations car. has a .15 motor.
super fast! you are right through I can't really put bigger ties on it so im trying to find someone to trade with for a truck.
Old Jan 03, 2013, 08:26 PM
USA, MI, Hastings
Joined Jan 2007
Looks like an NTC3 that is a good car you should have no trouble trading.
Old Jan 03, 2013, 08:34 PM
gggval is offline
gggval's Avatar
Joined Dec 2012
sweet! i bought all the parts for it, its got a new air filter, glow plug, body, tires(same size), and a few other misc things on their way.
today I cleaned the carb and cylinder now it starts 5 times easier!
for some reason it eats gas down like there is no tomorrow.
i don't think I even get a minute on a full tank? it seems to only suck it down when the throttle is at full blast though.
this car is SUPER FAST! and REALLY low to the ground!
how much do you think its worth?
Old Jan 04, 2013, 11:15 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You should be getting at least 6-10 minutes out of a tank, I would check to see if you have any leaks in the tank itself.
Old Jan 04, 2013, 02:57 PM
gggval is offline
gggval's Avatar
Joined Dec 2012
okay after i timed it it turned out to be around 10 minutes. i guess time flys when your having fun.
another thing i noticed was that the idle screw doesnt stay put so i have to adjust it at least once every run so
should i put a little thread lock or what?
Old Jan 04, 2013, 03:54 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Is there a spring on the screw? You can try stretching the spring so it's under a bit more tension, but if that doesn't work try a tiny bit of thread lock.
Old Jan 04, 2013, 06:00 PM
USA, MI, Hastings
Joined Jan 2007
I would do some looking on Ebay on the completed items it will give you a good idea what they are going for.
Old Jan 05, 2013, 12:35 AM
gggval is offline
gggval's Avatar
Joined Dec 2012
i should have thought about the stretching of the spring but yea that should work. most of the springs I work with are industrial and can't be stretched because they are usually 1/4" hardened steel coils.
i think its worth around $150? what do you think?
its so dang fast!!!
Discussion why does my rc nitro car move without the transmitter Jack cole Nitro and Glow Power Cars 3 Sep 21, 2012 06:44 PM
Question the parameter of Brushless servo for my 1/8th nitro gas rc cars ? Bz6wbf Radios 0 Jun 30, 2012 04:47 AM
Sold Thunder Tiger TS4N AWD Nitro Rally Car - OS MAX .15 - Lancer Evo Body - RTR - $60 bulletfast Cars - Cars and Parts (FS/W) 9 Jun 27, 2010 12:29 AM
Off Site SUPER NICE Traxxas Nitro 4-Tec 3.3 AWD SUPER CAR sdstick Cars - Cars and Parts (FS/W) 2 Jan 13, 2010 12:14 PM
Wanted Wanted RTR nitro car or truck... new nitro heli to trade!!! FlybyPDX Cars - Cars and Parts (FS/W) 6 May 29, 2006 12:20 PM
